Hello there people. I’m relatively new to using Arch Linux. This is a problem I’ve only been facing very recently. This issue started after I ran “update” as part of a Garuda announcement that there was now a dependency conflict
The issue itself:
Audio playback DOESNT WORK AT ALL when I’m using speakers. This prevents me from watching YouTube videos or playing any kind of audio at all. When I connect my Bluetooth headphones everything works fine but, the speakers do not.
inxi -Faz Output:
System: Host: msreddy-G3-3500 Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=721db9d0-601f-4e5a-972d-402b157edef8
systemd.unified_cgroup_hierarchy=1 resume=UUID=22b6b363-82a8-42bd-be47-7314726701c3 loglevel=3
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: G3 3500 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 0Y7260 v: A00 serial: <superuser required> UEFI: Dell v: 1.10.1
date: 08/13/2021
Battery: ID-1: BAT0 charge: 50.1 Wh (100.0%) condition: 50.1/51.0 Wh (98.2%) volts: 13.0 min: 11.4
model: BYD DELL M4GWP06 type: Li-poly serial: 1634 status: Full
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4803 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4803 2: 4868 3: 4801 4: 4743
5: 4793 6: 4800 7: 4773 8: 4618 9: 4634 10: 4859 11: 4785 12: 4735
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0c45:671f class-ID: 0e02
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8
class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.39 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: 9c:fc:e8:41:a9:d8
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: 8c:47:be:20:0c:cd
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: 9C:FC:E8:41:A9:DC
Drives: Local Storage: total: 1.14 TiB used: 28.89 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM991 NVMe 256GB size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: S50ANF2N620886 rev: 25309039 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: 70CRTEL5T rev: 01
Partition: ID-1: / raw-size: 221.38 GiB size: 221.38 GiB (100.00%) used: 28.89 GiB (13.0%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 221.38 GiB size: 221.38 GiB (100.00%) used: 28.89 GiB (13.0%) fs: btrfs
ID-4: /var/log raw-size: 221.38 GiB size: 221.38 GiB (100.00%) used: 28.89 GiB (13.0%)
ID-5: /var/tmp raw-size: 221.38 GiB size: 221.38 GiB (100.00%) used: 28.89 GiB (13.0%)
ID-1: swap-1 type: partition size: 16.83 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.3 GiB used: 2.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A
Info: Processes: 363 Uptime: 15m wakeups: 1313 Memory: 15.3 GiB used: 3.85 GiB (25.1%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2075 lib: 535
I’ve tried to find a solution but, I didn’t find many. And the ones that turned up were basically asking me to install packages which were already installed on my system. So, I decided I’d ask here before breaking my system.
