I am a new Linux user, I switched to Garuda, but my audio is not working. In Fedora, Kubuntu and Windows 11, my audio used to work perfectly. However, when I switched to Garuda, there was no audio. I can still adjust volume, and stuff like that, but there is no output. One thing that I have noticed is that in Garuda, my audio is recognized as “Intel Tiger Lake”, whereas in Windows and other distributions, it used to be something along the lines of “Realtek Audio Speakers”
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d2738597-2b66-4933-8a4f-0453bbdcea7e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: HUAWEI product: NBD-WXX9 v: M1010 serial: <filter>
Mobo: HUAWEI model: NBD-WXX9-PCB-B3 v: M1010 serial: <filter>
part-nu: C100 uuid: 25ae741b-4fd7-4e92-ba2f-75e0f7dd22ab UEFI: HUAWEI
v: 2.31 date: 11/02/2022
ID-1: BAT1 charge: 50.5 Wh (100.0%) condition: 50.5/54.9 Wh (91.9%)
volts: 8.6 min: 7.6 model: Sunwoda-H HB4692Z9ECW-22T type: Li-ion
serial: <filter> status: full cycles: 223
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xB6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2860 high: 4372 min/max: 400/4700 base/boost: 2800/4700
ext-clock: 100 MHz cores: 1: 1910 2: 400 3: 400 4: 4100 5: 3578 6: 4325
7: 3795 8: 4372 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 13d3:5476
Display: server: X.Org v: 24.1 with: Xwayland v: 24.1.0
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: BOE Display 0x0877 built: 2019 res: 1920x1080
hz: 60 dpi: 157 gamma: 1.2 size: 310x170mm (12.2x6.69") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.53 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.7 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 22.26 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: 311CD0512GB size: 476.94 GiB
tech: SSD serial: <filter> fw-rev: EDFOB0.7 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 142d 7h cycles: 1,304
read-units: 29,097,491 [14.8 TB] written-units: 28,477,185 [14.5 TB]
used: 22.26 GiB (4.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Memory: total: 16 GiB available: 15.42 GiB used: 3.39 GiB (22.0%)
igpu: 60 MiB
Processes: 285 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1904 libs: 569 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date: 2024-06-09
Last full system update: 2024-06-09
