First, do refresh, I have many kernel in the list
Second, do not post pictures.
Third, I said "maybe" it is the kernel.
Fourth
do not think you got a solution in 2 min. it can be two days until the right person read your problem and help.
Fifth, did you try what libre wrote in telegram?
Sir how I'll ask the manufacturer?
It's a 10 years old pc
is alive, or?
Maybe you start with 5.
Bro plz try to degrade kernel to old versions and check your problem solved or not if not submit logs we will help you
