Yesterday, While i was at work my girlfriend was playing a game i had downloaded for her with hdmi connected to the TV. This garuda install is only about a week old with some steam games installed. She said at one point she disconnected the hdmi and then at some point the laptop crashed, but then she just logged in and kept playing the game as normal. However, since she does not like audio apparently, she does not know when the audio stopped working. All i know is today when i try to use it, the audio does not output at all anymore.
I have tried following a few other similar topics, no avail. I have tried messing with the garuda assist to uninstall pulseaudio → install pipewire. At one point while trying to fix it the “sound” option in system settings disappears completely. So i try to do a system rollback after i cant figure out how to fix that now. Then the dang thing starts freezing at the MSI bois logo at startup every time, i have to completely reinstall from usb. All very frustrating, but luckily everything on this install were just steam games i can reinstall pretty quickly
Now with the story out of the way, my “sound” button in the system settings is back, but still no audio output at all. No clue why at this point
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=24ab3d31-5e91-45d9-9a60-184512a8aef2 rw rootflags=subvol=@
quiet resume=UUID=b03dc028-2672-46fb-ba46-4745a53cc3ef loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: Micro-Star product: Cyborg 15 A12VE v: REV:1.0
Mobo: Micro-Star model: MS-15K1 v: REV:1.0 serial: <superuser required>
part-nu: 15K1.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E15K1IMS.306 date: 12/30/2022
ID-1: BAT1 charge: 40.2 Wh (79.0%) condition: 50.9/52.0 Wh (97.8%)
volts: 12.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: charging
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x436
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Micro-Star MSI
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a3 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Micro-Star MSI driver: nvidia v: 570.86.16
alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:28a1
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 5986:211b
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xd0a2 built: 2022 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
modes: 1920x1080
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 15.16 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: N/A device-ID: 8086:46a3 surfaces: xcb,xlib
device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 4050 Laptop GPU
driver: N/A device-ID: 10de:28a1 surfaces: xcb,xlib device: 2 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
surfaces: xcb,xlib
vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: Micro-Star MSI
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 25.43 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA001 temp: 38.9 C
ID-1: / raw-size: 442.48 GiB size: 442.48 GiB (100.00%)
used: 25.42 GiB (5.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 442.48 GiB size: 442.48 GiB (100.00%)
ID-4: /var/log raw-size: 442.48 GiB size: 442.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.48 GiB size: 442.48 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.16 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 4.04 GiB (13.0%)
Processes: 338 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1959 libs: 585 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date: 2025-02-25
Last full system update: 2025-02-26
