I just did a fresh install, updated everything but I’m not getting any sound, the bar is going up and down in pavucontrol but no sound is outputting on my headphones or speakers
Welcome
Please, follow the template. Minimum, post garuda-inxi.
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
It seems to have fixed itself after trying some stuff I found online but I’m gonna post anyway because when I start my pc it doesn’t automatically have sound but after fiddling with videos and such it starts producing sound.
Kernel: 6.6.39-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=554bb21f-e0f9-48d7-8dcd-d6bbf23c6fce rw rootflags=subvol=@
quiet resume=UUID=ada99af2-9ed8-4dad-ac80-e417c5b4a625 loglevel=3 ibt=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Multilaser product: UB23X v: SHG47
Mobo: Multilaser model: UB235 serial: <superuser required> part-nu: UB235
uuid: <superuser required> UEFI: American Megatrends v: GM116E.B0.0x15
date: 10/13/2021
ID-1: BAT0 charge: 11.6 Wh (38.2%) condition: 30.4/N/A Wh power: 6.3 W
volts: 7.2 min: 7.6 model: N/A type: Unknown serial: <filter>
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 8 microcode: 0x24
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1388 high: 1613 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1164 2: 1613
bogomips: 4378
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Y Media USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0bdc:0320
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x2e3c built: 2013 res: 1366x768
ratio: 16:9 modes: 1366x768
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 600 (GLK 2)
device-ID: 8086:3185 memory: 1.79 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 600 (GLK 2) driver: mesa intel v: 24.1.3-arch1.1
device-ID: 8086:3185 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 128 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Realtek driver: sof-audio-pci-intel-apl alternate: snd_hda_intel,
snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0401
API: ALSA v: k6.6.39-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Message: No PCI device data found.
IF-ID-1: wlp0s21f0u4i2 state: up mac: <filter>
Device-1: Realtek 802.11n WLAN Adapter driver: btusb,rtw_8723du type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 0bda:d723
Local Storage: total: 126.11 GiB used: 22.46 GiB (17.8%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 103.43 GiB size: 103.43 GiB (100.00%)
used: 15.61 GiB (15.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 103.43 GiB size: 103.43 GiB (100.00%)
ID-4: /var/log raw-size: 103.43 GiB size: 103.43 GiB (100.00%)
ID-5: /var/tmp raw-size: 103.43 GiB size: 103.43 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.66 GiB used: 1.38 GiB (37.5%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2
ID-2: swap-2 type: partition size: 8.06 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: N/A
Memory: total: 4 GiB available: 3.67 GiB used: 2.56 GiB (69.8%)
Processes: 242 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.46 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1364 libs: 460 tools: paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Zsh v: 5.9 running-in: alacritty
inxi: 3.3.35
System install date: 2024-07-12
Last full system update: 2024-07-13 ↻
Ok now I have restarted my laptop and stopped working again, but then I noticed it works whenever I open pavucontrol GUI and it establishes connection with the audio control
Have a similar issue to this on a new install; audio is not working until the speaker is muted and then unmuted from audio volume pull down in top right corner; refreshing videos playing in windows then start working; sometimes start working right away such as in VLC; continue working until system is restarted.
