Audio issues with garuda
Hello Garuda users.
I facing a weird problem , am not getting any audio from my speaker when ever i play music and browse youtube same when i connect any bluetooth headphone ...no audio . Today i run a garuda update , after that it starts coming out of the speaker but after few minutes its gone again....i am using dual boot when i login to windows then , the audio output is working fine....if any one know about this then , kindly help me.
Please provide your garuda-inxi, as requested by the template.
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=231adbe5-cbff-46a0-a133-7b383848afc1 rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706ICB_FA706ICB
Mobo: ASUSTeK model: FA706ICB v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706ICB.307 date: 12/28/2022
ID-1: BAT1 charge: 40.8 Wh (46.4%) condition: 87.9/90.2 Wh (97.4%)
volts: 15.1 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2712 high: 2900 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 1398
3: 2900 4: 2900 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900
12: 2900 13: 1397 14: 2900 15: 2900 16: 2900 bogomips: 92631
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 48.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi,nouveau gpu: amdgpu display-ID: :0
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a11 built: 2021
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
address: <filter>
Local Storage: total: 476.94 GiB used: 13.97 GiB (2.9%)
fw-rev: FXM7201Q temp: 42.9 C scheme: GPT
ID-1: / raw-size: 94 GiB size: 94 GiB (100.00%) used: 13.94 GiB (14.8%)
used: 30 MiB (11.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 94 GiB size: 94 GiB (100.00%)
used: 13.94 GiB (14.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 94 GiB size: 94 GiB (100.00%)
ID-5: /var/tmp raw-size: 94 GiB size: 94 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 55.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): cpu: 0
Processes: 332 Uptime: 31m wakeups: 978 Memory: available: 7.18 GiB
used: 2.65 GiB (36.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 3448 pm: pacman pkgs: 1724
libs: 519 tools: octopi,paru pm: rpm pkgs: N/A note: see --rpm tools: dnf
inxi: 3.3.27
System install date:     2023-05-04
Last full system update: 2023-05-13 ↻
Now audio issue is fixed , now am facing video playback problem in youtube and every where , it say if playback doesnt being shorty try restarting your device....
Did you do anything specific to fix your problem? If so, please share what you did (and be specific about it) so that others who stumble upon this thread in their search for a solution can try the same steps.
You should also open a new thread about your new issue and post your garuda-inxi there, between 3 tildes top and bottom as specified by the issues and assistance template. This helps people with similar issues search and find your thread. The tilde formatting for code/terminal output is to make it easier for mobile users to read your post, and to also keep the page looking clean. All guidelines mentioned on any forum have reasons to be there.
It is also general netiquette to not necro old threads, especially if you just post something like 'same here' (I hope you know what thread I'm talking about). It contributes nothing substantial to the discussion, and wastes moderators' and members' time if you don't mention what you've tried before.
edit: I see your bump got split into a new topic. Please post about your new issue there :slight_smile:
