Hello community I installed Garuda on my iMac 2015 on an external SSD few hours ago, so now here's the issue
Sound didn't work at first so i went through the settings and changed the soundcard to surround 4.0 and it worked except the volume was up all the way to 100%
https://i.imgur.com/BuuNyof.png
ok so issue #1 solved, now to control the volume (issue #2)
i looked around did a lot of research and ended up with alsamixer, i installed it and now im able to control the volume, but
- the settings don't change
- master volume is different from PCM volume
https://i.imgur.com/f5uuy2l.png
I would like to set master volume to match with PCM volume (or rather mirror master volume to PCM) so i can control it with my keyboard and also via the menu bar icon
Thanks in advance
