Hello! I’ve been happily using Garuda for about a year and a half now. Came from Windows 10, and I’m loving the change! I apologize in advance for any amateur mistakes in the formatting of this question or any data I am missing. I appreciate everyone’s help.
How we got here:
A while ago I did something that was perhaps foolish. I was trying to run Rocksmith 2014 on my Garuda system and was having some issues getting the USB to instrument audio cable to work. I never did get it to work properly, but in the meantime I fiddled with so many audio settings that I must have messed something up.
The Situation:
In the course of trying out different ways to get this audio cable to work, I ended up having both Pulse and PipeWire installed at one point. I do not recall all the details of what I did unfortunately. I should remember to document things better next time. My audio seemed fine for the most part, but I started to lose audio (it would go silent) somewhat randomly during games. Some games (Ark) seem to be impacted more frequently than others (WoW) for whatever reason, but that might just be my impression. I can restore audio by going into the Sound settings and changing the sound card from 5.1 Digital Audio to something else and back again. This fix doesn’t always last terribly long though.
Attempted Solutions/Progress:
I have looked up this problem in several places and eventually determined that the issue was probably having Pulse and PipeWire on at the same time at some point. I scrubbed out Pulse as best I could and went with PipeWire. The audio was still randomly going silent (although maybe less frequently? Not sure.)
Another post suggested I should get rid of everything and check on only “ALSA Support” in Garuda Assistant. I attempted that, but even after checking off “PipeWire” and only leaving ALSA support, Pipewire was still on and the same issue persists.
I think I have worked the system to the point where it goes silent much less often than it was, but there must still be an issue because it is still happening. Any assistance would be most welcome!
Here is my result of the garuda-inxi command.
Kernel: 6.17.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=0c445ada-8dfe-4a2b-99b1-ebf4a9892c24 rw rootflags=subvol=@
quiet loglevel=3
Type: Desktop Mobo: ASRock model: X670E Steel Legend
Megatrends LLC. v: 2.02 date: 11/17/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3592 min/max: 426/4201 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3592 2: 3592 3: 3592
4: 3592 5: 3592 6: 3592 7: 3592 8: 3592 9: 3592 10: 3592 11: 3592 12: 3592
13: 3592 14: 3592 15: 3592 16: 3592 bogomips: 134153
ssse3 svm
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 580.95.05 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-08) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2782 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,
DP-5, DP-6, HDMI-A-2, Writeback-1 bus-ID: 16:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 41.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:3
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-3 model: AOC AG274QG serial: <filter> built: 2020 res:
mode: 2560x1440 hz: 200 scale: 100% (1) dpi: 108 gamma: 1.2
size: 603x347mm (23.74x13.66") diag: 696mm (27.4") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 17 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 580.95.05 device-ID: 10de:2782
surfaces: N/A device: 1 type: integrated-gpu name: AMD Radeon Graphics
(RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 25.2.4-arch1.1
device-ID: 1002:164e surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM
Device-1: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster AE-7]
driver: snd_hda_intel v: kernel bus-ID: 07:00.0 chip-ID: 1102:0010
Device-3: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 16:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 16:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Razer USA RC30-026902 Gaming Headset [Nari Essential Wireless
Receiver] driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 1532:051e
Device-6: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
Device-7: C-Media Storm HP-USB500 5.1 Headset
lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 0d8c:0006 class-ID: 0300
API: ALSA v: k6.17.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 08:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: torguard-wg state: unknown speed: N/A duplex: N/A mac: N/A
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:4 chip-ID: 0e8d:0616
Local Storage: total: 33.7 TiB used: 31.46 TiB (93.3%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: P3-2TB size: 1.86 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 840H scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST20000NM007D-3DJ103
size: 18.19 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN01 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion Desk
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9401 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST5000LM000-2AN170
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5526
serial: <filter> fw-rev: 0204 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 1.42 TiB (79.2%)
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.42 TiB (79.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.46 GiB used: 8.9 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.52 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Memory: total: 32 GiB note: est. available: 30.46 GiB used: 4.3 GiB (14.1%)
Processes: 530 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.12 GiB services: org_kde_powerdevil,
Packages: 2489 pm: pacman pkgs: 2464 libs: 639 tools: octopi,paru,trizen
pm: flatpak pkgs: 25 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.1.2 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2024-06-26
Garuda release: 240428
Last full system update: 2025-10-11
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
