Hi I installed garuda last night and today I realized, that the speakers emit a slight hissing noise. Checked back in Windows they don't. I previously had pop_os and it didn't hiss either, so I'm guessing it's some wierd configuration / driver issue (mainline arch did not hiss as well)
My Laptop's inxi
System: Kernel: 5.11.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=dbc01305-ecc2-4f40-a9f4-fc4e54f256db
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Convertible System: LENOVO product: 20JES01U2P v: ThinkPad X1 Yoga 2nd serial: <filter>
Chassis: type: 31 serial: <filter>
Mobo: LENOVO model: 20JES01U2P v: SDK0K17763 WIN serial: <filter> UEFI: LENOVO
v: N1NET51W (1.38 ) date: 06/10/2020
Battery: ID-1: BAT0 charge: 19.5 Wh (52.3%) condition: 37.3/56.0 Wh (66.6%) volts: 14.7 min: 15.2
model: LGC 01AV457 type: Li-poly serial: <filter> status: Discharging cycles: 547
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
CPU: Info: Dual Core model: Intel Core i7-7600U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: DE cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23199
Speed: 3701 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3701 2: 3863 3: 3700 4: 3899
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:5 chip-ID: 04f2:b5ce
class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
Monitor-1: eDP1 res: 2560x1440 hz: 60 dpi: 210 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.11.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Network: Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel port: efa0
bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus-ID: 04:00.0
chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: wwp0s20f0u6i12 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:4
chip-ID: 8087:0a2b class-ID: e001
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 465.76 GiB used: 187.85 GiB (40.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 2B2QEXE7 temp: 31.9 C scheme: GPT
Partition: ID-1: / raw-size: 93.42 GiB size: 93.42 GiB (100.00%) used: 17.38 GiB (18.6%) fs: btrfs
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.80%) used: 54.9 MiB (11.1%) fs: vfat
ID-3: /home raw-size: 93.42 GiB size: 93.42 GiB (100.00%) used: 17.38 GiB (18.6%) fs: btrfs
ID-4: /var/log raw-size: 93.42 GiB size: 93.42 GiB (100.00%) used: 17.38 GiB (18.6%) fs: btrfs
ID-5: /var/tmp raw-size: 93.42 GiB size: 93.42 GiB (100.00%) used: 17.38 GiB (18.6%) fs: btrfs
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: swap-2 type: zram size: 3.88 GiB used: 4.1 MiB (0.1%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 3.88 GiB used: 4.2 MiB (0.1%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 3.88 GiB used: 4.2 MiB (0.1%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 3.88 GiB used: 4 MiB (0.1%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 259 Uptime: 2h 34m wakeups: 13 Memory: 15.51 GiB used: 6.67 GiB (43.0%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1438 lib: 344 Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.03
