czrpb
April 29, 2022, 5:46pm
1
Hi!
tl;dr: I have a BT speaker which my system finds as a device, but doesnt always "find"/create a sink for, thus I dont have audio.
i think my question fundamentally is: who/what creates audio sinks?
links and resource so i can learn would be great! (i must suck at searching cause i couldnt figure it out...)
THINGS IVE TRIED / DONE
Hope some of this stuff helps!!
Wrote a small/dumb script for myself that i use to connect my speaker on BT and then sent the sink; often/generally its good:
ββ ο
Ό ξ° ο ~ ξ° ξ² 1 β ξ² took 11s ο ξ² at 10:29:47 ο
β°β sound.sh
Connecting bose speaker...
Attempting to connect to 4C:87:5D:4C:B3:66
Failed to connect: org.bluez.Error.Failed br-connection-busy
Setting sink...
Failure: No such entity
ββ ο
Ό ξ° ο ~ ξ° ξ² 1 β ξ² took 10s ο ξ² at 10:34:34 ο
β°β cat $(which sound.sh)
#!/usr/bin/env bash
echo "Connecting bose speaker..."
bluetoothctl connect 4C:87:5D:4C:B3:66
sleep 10
echo "Setting sink..."
pactl set-default-sink bluez_output.4C_87_5D_4C_B3_66.a2dp-sink
but now/recently, according to wpctl
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² at 10:36:06 ο
β°β wpctl status
Audio
ββ Devices:
β 45. Anker PowerConf C300 [alsa]
β 46. GK208 HDMI/DP Audio Controller [alsa]
β 47. Family 17h (Models 00h-0fh) HD Audio Controller [alsa]
β 83. sndbox [bluez5]
β
ββ Sinks:
β * 32. Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958) [vol: 0.89]
β 55. GK208 HDMI/DP Audio Controller Digital Stereo (HDMI 2) [vol: 0.74]
so no sink for it. why?
pactl
says the same:
ββ ο
Ό ξ° ο ~ ξ° ξ² INT β ξ² at 10:41:07 ο
β°β pactl list sinks short
57 alsa_output.pci-0000_0b_00.3.iec958-stereo PipeWire s32le 2ch 48000Hz SUSPENDED
4575 alsa_output.pci-0000_09_00.1.hdmi-stereo-extra1 PipeWire s32le 2ch 48000Hz SUSPENDED
pactl info
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² at 10:41:09 ο
β°β pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 4585
Tile Size: 65472
User Name: ***
Host Name: ***
Server Name: PulseAudio (on PipeWire 0.3.50)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_0b_00.3.iec958-stereo
Default Source: alsa_output.pci-0000_0b_00.3.iec958-stereo.monitor
Cookie: 5f44:fa45
i think i have got pipewire
and pulse
all good/connected up, but obviously not perfectly:
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² at 10:41:59 ο
β°β ps auxwww | rg -i pipewire
*** 3290 0.1 0.0 117432 21192 ? S<sl Apr15 24:44 /usr/bin/pipewire
*** 3293 0.2 0.1 66196 52160 ? S<Lsl Apr15 48:30 /usr/bin/pipewire-pulse
*** 421660 0.0 0.0 9436 6676 pts/0 S<+ 10:44 0:00 rg -i pipewire
czrpb
April 29, 2022, 5:53pm
3
Sorry, done:
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² at 10:44:33 ο
β°β garuda-inxi
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=128122b3-8c17-42c1-97cd-f2cc106196a1 rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2607
date: 08/14/2020
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2669 high: 3208 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2506 2: 2325
3: 2893 4: 3208 5: 3071 6: 2389 7: 2410 8: 2678 9: 3009 10: 2572 11: 2586
12: 2390 bogomips: 81449
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Micro-Star MSI
driver: nouveau v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 ports:
active: HDMI-A-1 empty: DVI-D-1,VGA-1 bus-ID: 09:00.0 chip-ID: 10de:128b
Device-2: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4:6 chip-ID: 291a:3361 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau display-ID: :0
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung S34J55x
serial: <filter> built: 2020 res: 3440x1440 hz: 50 dpi: 110 gamma: 1.2
size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
bus-ID: 09:00.1 chip-ID: 10de:0e0f class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Anker PowerConf C300 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.50 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 bus-ID: 3-5:5 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.74 TiB used: 79.86 GiB (2.9%)
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 7.22 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00
used: 25.08 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.32 GiB used: 6.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nouveau temp: 38.0 C
Processes: 414 Uptime: 14d 52m wakeups: 0 Memory: 31.32 GiB
used: 13.76 GiB (43.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1385 lib: 337 Shell: Zsh
v: 5.8.1 running-in: alacritty inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-10-20
Last full system update: 2022-04-27 β»
czrpb
April 29, 2022, 6:08pm
4
ok, ive garuda-update
d and rebooted and my dumb script worked and so the sink is now around, but i dont know why.
sndbox
is my external BT audio speaker . . .
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² took 10s ο ξ² at 11:02:15 ο
β°β wpctl status
Audio
ββ Devices:
β 44. Anker PowerConf C300 [alsa]
β 45. GK208 HDMI/DP Audio Controller [alsa]
β 46. Family 17h (Models 00h-0fh) HD Audio Controller [alsa]
β 62. sndbox [bluez5]
β
ββ Sinks:
β 32. Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958) [vol: 0.89]
β * 63. sndbox [vol: 0.13]
ββ ο
Ό ξ° ο ~ ξ° ξ² β ξ² at 11:02:22 ο
β°β garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
date: 08/14/2020
Speed (MHz): avg: 3227 high: 3598 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2951 2: 3410
3: 2407 4: 3586 5: 3598 6: 2672 7: 3596 8: 3336 9: 2866 10: 3541 11: 3347
12: 3420 bogomips: 81441
bus-ID: 3-4:5 chip-ID: 291a:3361 class-ID: 0e02 serial: <filter>
min: 720x400
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
v: 0.8 bus-ID: 3-5:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.74 TiB used: 81.17 GiB (2.9%)
rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
used: 26.46 GiB (2.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.32 GiB used: 2.8 MiB (0.0%)
Processes: 358 Uptime: 3m wakeups: 0 Memory: 31.32 GiB
used: 3.28 GiB (10.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1386 lib: 338 Shell: Zsh
Garuda (2.6.2-1):
Last full system update: 2022-04-29
No sink? You buying bottled water then? Sorry guys I had toβ
tbg
May 1, 2022, 3:22pm
6
Maybe by the time they have developed the cranial implant for wireless sound, bluetooth technology will be working correctly. Until then just say no to bluetooth.
system
Closed
May 15, 2022, 3:22pm
7
