Audio Cutting Out/ Bluetooth Headphones silent
I’m having a relatively inconsistent issue where the audio will cut out. Sometimes it’s really bad, other times it’s completely fine. I can’t really drawn any conclusions as to what causes it. I was playing a game and it was constantly cutting out, but when I was watching a yt video it took well over thirty minutes for any issues to appear. I’m also having issues with my Bluetooth headphones not working properly with the computer. I can connect them just fine, but when I try to actually use them they’re dead silent. The volume is up and the audio works when they’re not connected, besides the issues listed above. I’ve been using the headphones for 4-5 years now and they’ve been working perfectly fine with my phone.
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6979cba8-2da6-4305-857e-53a090d535f5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: PRIME X670-P WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0823
date: 11/21/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1659 high: 5440 min/max: 400/5453 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5439 2: 5440 3: 400
4: 400 5: 400 6: 5431 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 112592
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:7480 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-2
bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 39.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: D40fM-K09 built: 2022
res: 1920x1080 hz: 60 dpi: 69 gamma: 1.2 size: 708x398mm (27.87x15.67")
diag: 1016mm (40") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (gfx1102 LLVM
16.0.6 DRM 3.54 6.5.5-zen1-1-zen) device-ID: 1002:7480 memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon Graphics (RADV GFX1102) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:7480 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: AzureWave driver: rtw89_8852be v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 0b:00.0
chip-ID: 10ec:b852 class-ID: 0280
IF: wlp11s0 state: up mac: <filter>
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.82 TiB used: 128.29 GiB (6.9%)
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 532 GiB size: 532 GiB (100.00%) used: 128.29 GiB (24.1%)
ID-3: /home raw-size: 532 GiB size: 532 GiB (100.00%)
used: 128.29 GiB (24.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 532 GiB size: 532 GiB (100.00%)
ID-5: /var/tmp raw-size: 532 GiB size: 532 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.2 C mobo: N/A
GPU: device: amdgpu temp: 35.0 C mem: 50.0 C fan: 0 watts: 14.00
device: amdgpu temp: 39.0 C
Processes: 373 Uptime: 20m wakeups: 4 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 3.75 GiB (12.3%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1487 libs: 471
tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-09-15
Last full system update: 2023-10-07 ↻
Failed units:            packagekit.service
Try running alsamixer in the terminal, push F6 to select your soundcard/device then make sure nothing is muted or any settings are incorrect there.
The ‘swoosh’ indicates you need to reboot. Please do so, then see if your problems persist. Please report back. :slight_smile:
