Audio cackling/tearing in proton/steam games
So I have been having issues with audio crackling and tearing when playing some steam games. The ones that have it worst is War Thunder and Palworld. War Thunder’s issue seems really spotty where it will happen one game boot up and then not at all on the next. Palworld starts having the issue consistently even after restarts and adjusting the magic launch setting.
PULSE_LATENCY_MSEC=90 %command%
For War Thunder restarting the game or the system a time or two tends to fix the issue with the above set in the launch properties. With Palworld I have even tried taking it up to a ridiculous delay of 250ms. The crackling just occurred as if nothing changed. I did try adjusting pipewire, wireplumber, and ASLA configs however it eventually broke the audio enough to the point I just reinstalled the whole system.
According to ProtonDB both games tend to run out of the box with minimal issues and the sound issues I’m having seem to be easily solved with the pulse_latency command for most people. So now I’m wonder if I missed a configuration or if its a hardware issue for me since I’m currently using the current generation of the MSI Raider gaming laptop.
Kernel: 6.14.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c496e4e3-825c-4f38-af58-4a013ab6f203 rw rootflags=subvol=@
Type: Laptop System: Micro-Star product: Raider GE78HX 13VG v: REV:1.0
Mobo: Micro-Star model: MS-17S2 v: REV:1.0 serial: <superuser required>
part-nu: 17S2.1 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E17S2IMS.108 date: 03/27/2023
ID-1: BAT1 charge: 79.0 Wh (98.4%) condition: 80.3/95.0 Wh (84.5%)
volts: 16.5 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: 13th Gen Intel Core i7-13700HX bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x38
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/4800:5000:3700 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 110592
Device-1: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
vendor: Micro-Star MSI driver: nvidia v: 570.144
alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none off: DP-3,eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2820
Device-2: Bison FHD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:215c
d-rect: 4480x1600 display-ID: 0
Monitor-1: DP-3 pos: primary,left model: MSI G273 serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 83 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: AU Optronics 0x84a6 built: 2022 res:
mode: 2560x1600 hz: 240 scale: 130% (1.3) to: 1969x1231 dpi: 178 gamma: 1.2
size: 366x228mm (14.41x8.98") diag: 431mm (17") ratio: 16:10
modes: 2560x1600
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Laptop GPU driver: nvidia v: 570.144 device-ID: 10de:2820
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0401
Device-2: NVIDIA AD106M High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22bd
Device-3: SteelSeries ApS Arctis Nova 7
lanes: 1 mode: 1.1 bus-ID: 1-13:11 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.14.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:7a70
Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: 4000 bus-ID: 0000:3a:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp58s0 state: down mac: <filter>
rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-9.4:6
IF: enp0s20f0u9u4 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12 chip-ID: 8087:0033
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 4.13 TiB used: 949.84 GiB (22.5%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA001 temp: 48.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVL41T0HBLB-00BTW size: 953.87 GiB block-size: physical: 512 B
fw-rev: HXC70W1Q temp: 46.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
serial: <filter> scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: Portable
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 9300 scheme: MBR
used: 54.34 GiB (11.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 612 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 15.38 GiB used: 2.68 GiB (17.4%)
max-streams: 24 dev: /dev/zram0
System Temperatures: cpu: 52.8 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.38 GiB used: 6.73 GiB (43.8%)
Processes: 523 Power: uptime: 1h 46m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1452 libs: 438 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.2
System install date:     2025-04-25
Last full system update: 2025-04-30
Not your issue …
but not the latest bios
https://www.msi.com/Laptop/Raider-GE78-HX-13VX/support
  • you use your bluetooth headset over the dongle with 2,4 ghz connection
  • with usb cable connected ? (if it works)
  • and with headset (jack) + onboard sound ?
and last but not least: Do you have headsetcontrol-git installed ? (to control your device)
Its a wireless headset not operated over bluetooth. USB as far as I am aware is charging only and I currently do not have audio jack. But i want to clarify that its only SOME games being run through proton. There are many I have tried setting the audio latency to 30/60 and have it work seamlessly. But palworld is and Monster Hunter Wilds (was testing it today) have crackling after a few minutes. I have set the delay to audaciously high levels (upwards of 600) just to see what happens.
The audio will still pop and crackle after just a bit of time. I’m honestly not sure if its just due to the game(s) interaction with the different version of proton or something else.
Also audio is perfect and crisp in all other applications. Even with spotify running with high quality sound + easyeffects.
