Whenever I freshly boot up the computer, it will distort my audio and any program loading/downloading (steam) will lag my mouse.
Kernel: 6.1.64-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c014b45d-506d-4fec-9173-9f4f3c654339 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5003
date: 10/07/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3668 high: 4399 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3514 2: 3760
3: 3712 4: 4337 5: 4399 6: 3518 7: 3517 8: 3519 9: 3518 10: 4398 11: 3518
12: 3519 13: 3520 14: 3518 15: 3519 16: 4266 17: 4398 18: 3822 19: 3506
20: 3518 21: 3518 22: 2200 23: 3518 24: 3518 bogomips: 177689
Device-1: NVIDIA GA102 [GeForce RTX 3080 12GB] vendor: eVga.com.
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1, DP-2, DP-3, HDMI-A-1 empty: none
bus-ID: 08:00.0 chip-ID: 10de:220a class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 6840x1920 s-dpi: 34 s-size: 5110x1434mm (201.18x56.46")
s-diag: 5307mm (208.95")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,2-3 model: VG278
serial: <filter> built: 2020 res: 1920x1080 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: not-matched mapped: DP-3 pos: 1-2 res: 1080x1920 hz: 60 dpi: 94
size: 293x521mm (11.54x20.51") diag: 598mm (23.53") modes: N/A
Monitor-3: not-matched mapped: DP-5 pos: 3-4 res: 1920x1080 hz: 60 dpi: 94
size: 520x290mm (20.47x11.42") diag: 595mm (23.44") modes: N/A
Monitor-4: HDMI-A-1 mapped: HDMI-0 note: disabled pos: 2-1
model: Samsung Q70A serial: <filter> built: 2021 res: 1920x1080 hz: 120
dpi: 34 gamma: 1.2 size: 1420x800mm (55.91x31.5") diag: 1630mm (64.2")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 545.29.06
device-ID: 10de:220a surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
bus-ID: 08:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: b58e:9e84 class-ID: 0300
API: ALSA v: k6.1.64-1-lts status: kernel-api with: aoss
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2526 class-ID: 0280
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.08 TiB used: 1.44 TiB (69.2%)
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 PRO 256GB
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Cruzer Glide
size: 29.25 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
used: 126.72 GiB (53.2%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 62.71 GiB used: 8.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 75.8 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
Processes: 520 Uptime: 10m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.71 GiB used: 10.6 GiB (16.9%) Init: systemd v: 254
Packages: 1825 pm: dpkg pkgs: 1 pm: pacman pkgs: 1824 libs: 556
tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.2.21
running-in: alacritty inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-15
Last full system update: 2023-11-29
I have since updated my bios to ver 5003 which came out 10/23/23, disabled fast boot, tried alternating between Enable Firmware TPM and Discrete TPM (no improvements) and trying Enable/Disable for Erase fTPM NV for factory reset (no dif).
This is my result for systemmd-analyze blame:
4.740s sys-devices-platform-serial8250-tty-ttyS1.device
4.740s dev-ttyS1.device
4.739s sys-devices-platform-serial8250-tty-ttyS12.device
4.739s dev-ttyS12.device
4.739s dev-ttyS13.device
4.739s sys-devices-platform-serial8250-tty-ttyS13.device
4.737s sys-devices-platform-serial8250-tty-ttyS11.device
4.737s dev-ttyS11.device
4.737s sys-devices-platform-serial8250-tty-ttyS10.device
4.737s dev-ttyS10.device
4.736s dev-ttyS15.device
4.736s sys-devices-platform-serial8250-tty-ttyS15.device
4.736s dev-ttyS16.device
4.736s sys-devices-platform-serial8250-tty-ttyS16.device
4.735s sys-devices-platform-serial8250-tty-ttyS17.device
4.735s dev-ttyS17.device
4.735s sys-devices-platform-serial8250-tty-ttyS14.device
4.735s dev-ttyS14.device
4.735s sys-devices-platform-serial8250-tty-ttyS19.device
4.735s dev-ttyS19.device
4.734s dev-ttyS18.device
4.734s sys-devices-platform-serial8250-tty-ttyS18.device
4.733s sys-devices-platform-serial8250-tty-ttyS2.device
4.733s dev-ttyS2.device
4.733s sys-devices-platform-serial8250-tty-ttyS20.device
4.733s dev-ttyS20.device
4.732s dev-ttyS22.device
4.732s sys-devices-platform-serial8250-tty-ttyS22.device
4.732s sys-devices-platform-serial8250-tty-ttyS26.device
4.732s dev-ttyS26.device
4.731s sys-devices-platform-serial8250-tty-ttyS23.device
4.731s dev-ttyS23.device
4.731s dev-ttyS24.device
4.731s sys-devices-platform-serial8250-tty-ttyS24.device
4.730s dev-ttyS25.device
4.730s sys-devices-platform-serial8250-tty-ttyS25.device
4.730s dev-ttyS21.device
4.730s sys-devices-platform-serial8250-tty-ttyS21.device
4.729s dev-ttyS29.device
4.729s sys-devices-platform-serial8250-tty-ttyS29.device
4.729s sys-devices-platform-serial8250-tty-ttyS27.device
4.729s dev-ttyS27.device
4.729s sys-devices-platform-serial8250-tty-ttyS28.device
4.729s dev-ttyS28.device
4.728s sys-devices-platform-serial8250-tty-ttyS31.device
4.728s dev-ttyS31.device
4.728s dev-ttyS3.device
4.728s sys-devices-platform-serial8250-tty-ttyS3.device
4.727s dev-ttyS30.device
4.727s sys-devices-platform-serial8250-tty-ttyS30.device
4.726s dev-ttyS5.device
4.726s sys-devices-platform-serial8250-tty-ttyS5.device
4.726s sys-devices-platform-serial8250-tty-ttyS4.device
4.726s dev-ttyS4.device
4.726s dev-ttyS9.device
4.726s sys-devices-platform-serial8250-tty-ttyS9.device
4.725s sys-devices-platform-serial8250-tty-ttyS6.device
4.725s dev-ttyS6.device
4.725s dev-ttyS7.device
4.725s sys-devices-platform-serial8250-tty-ttyS7.device
4.724s sys-devices-platform-serial8250-tty-ttyS8.device
4.724s dev-ttyS8.device
4.721s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata6-host5-target>
4.721s dev-disk-by\x2ddiskseq-3.device
4.721s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5.0.device
4.721s dev-sdc.device
4.721s dev-disk-by\x2did-ata\x2dSamsung_SSD_850_PRO_256GB_S39KNX0HA64399Y.device
4.721s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5.device
4.721s dev-disk-by\x2did-wwn\x2d0x5002538d4162ca60.device
4.673s dev-ttyS0.device
4.673s sys-devices-pnp0-00:04-tty-ttyS0.device
4.668s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata6-host5-target>
4.668s dev-disk-by\x2did-ata\x2dSamsung_SSD_850_PRO_256GB_S39KNX0HA64399Y\x2dpart1.device
4.668s dev-sdc1.device
4.668s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5.0\x2dpart1.device
4.668s dev-disk-by\x2ddiskseq-3\x2dpart1.device
4.668s dev-disk-by\x2dpartuuid-93868a8a\x2dab1b\x2d014c\x2d991a\x2d851b5f4a35da.device
4.668s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5\x2dpart1.device
4.668s dev-disk-by\x2did-wwn\x2d0x5002538d4162ca60\x2dpart1.device
4.668s dev-disk-by\x2duuid-6947\x2d1883.device
4.629s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5\x2dpart2.device
4.629s dev-disk-by\x2duuid-c014b45d\x2d506d\x2d4fec\x2d9173\x2d9f4f3c654339.device
4.629s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata6-host5-target>
4.629s dev-disk-by\x2dpartuuid-121cb7c6\x2de1bc\x2dfd41\x2db4c9\x2d8922d2b14c07.device
4.629s dev-disk-by\x2did-ata\x2dSamsung_SSD_850_PRO_256GB_S39KNX0HA64399Y\x2dpart2.device
4.629s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d5.0\x2dpart2.device
4.629s dev-disk-by\x2dpartlabel-root.device
4.629s dev-disk-by\x2did-wwn\x2d0x5002538d4162ca60\x2dpart2.device
4.629s dev-disk-by\x2ddiskseq-3\x2dpart2.device
4.629s dev-sdc2.device
4.628s sys-module-configfs.device
4.617s dev-sdb.device
4.617s dev-disk-by\x2did-wwn\x2d0x50014ee261bb16e7.device
4.617s dev-disk-by\x2dpath-pci\x2d0000:074.617s dev-sdb.device
4.617s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d2.0.device
4.617s dev-disk-by\x2did-ata\x2dWDC_WD10EZEX\x2d00BN5A0_WD\x2dWCC3F7XK9D17.device
4.617s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d2.device
4.617s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata3-host2-target>
4.617s dev-disk-by\x2ddiskseq-2.device
4.566s dev-disk-by\x2did-wwn\x2d0x50014ee2b712197b.device
4.566s dev-sda.device
4.566s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata2-host1-target>
4.566s dev-disk-by\x2did-ata\x2dWDC_WD10EZEX\x2d00BN5A0_WD\x2dWCC3F7ZZZL8Y.device
4.566s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d1.0.device
4.566s dev-disk-by\x2ddiskseq-1.device
4.566s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d1.device
4.561s dev-disk-by\x2duuid-4fae2e08\x2d7c66\x2d4564\x2dbea9\x2d047ac215f0ab.device
4.561s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata3-host2-target>
4.561s dev-disk-by\x2dlabel-WildStorage.device
4.561s dev-disk-by\x2dpartuuid-35e945f7\x2d01.device
4.561s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d2\x2dpart1.device
4.561s dev-disk-by\x2did-wwn\x2d0x50014ee261bb16e7\x2dpart1.device
4.561s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d2.0\x2dpart1.device
4.561s dev-sdb1.device
4.561s dev-disk-by\x2did-ata\x2dWDC_WD10EZEX\x2d00BN5A0_WD\x2dWCC3F7XK9D17\x2dpart1.device
4.561s dev-disk-by\x2ddiskseq-2\x2dpart1.device
4.494s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d1.0\x2dpart1.device
4.494s dev-sda1.device
4.494s dev-disk-by\x2did-ata\x2dWDC_WD10EZEX\x2d00BN5A0_WD\x2dWCC3F7ZZZL8Y\x2dpart1.device
4.494s dev-disk-by\x2did-wwn\x2d0x50014ee2b712197b\x2dpart1.device
4.494s dev-disk-by\x2dpartuuid-35e945ff\x2d01.device
4.494s dev-disk-by\x2duuid-a6c1d471\x2ddcb8\x2d4275\x2d9300\x2d6e213c983c82.device
4.494s dev-disk-by\x2ddiskseq-1\x2dpart1.device
4.494s dev-disk-by\x2dlabel-WildStorage2.device
4.494s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:0a.0-0000:07:00.0-ata2-host1-target>
4.494s dev-disk-by\x2dpath-pci\x2d0000:07:00.0\x2data\x2d1\x2dpart1.device
2.527s dev-disk-by\x2dlabel-VTOYEFI.device
2.527s dev-disk-by\x2ddiskseq-4\x2dpart2.device
2.527s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusb\x2d0:4:1.0\x2dscsi\x2d0:0:0:0\x2dpart2.device
2.527s dev-disk-by\x2duuid-7CDB\x2d00D9.device
2.527s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:08.0-0000:05:00.1-usb1-1\x2d4-1\x2d>
2.527s dev-disk-by\x2did-usb\x2dSanDisk_Cruzer_Glide_4C530000040131223125\x2d0:0\x2dpart2.device
2.527s dev-sdd2.device
2.527s dev-disk-by\x2dpartuuid-65e19d81\x2d02.device
2.527s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusbv2\x2d0:4:1.0\x2dscsi\x2d0:0:0:0\x2dpart2.devi>
2.523s dev-sdd1.device
2.523s dev-disk-by\x2duuid-6A0A\x2d0F01.device
2.523s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:08.0-0000:05:00.1-usb1-1\x2d4-1\x2d>
2.523s dev-disk-by\x2did-usb\x2dSanDisk_Cruzer_Glide_4C530000040131223125\x2d0:0\x2dpart1.device
2.523s dev-disk-by\x2dlabel-Ventoy.device
2.523s dev-disk-by\x2ddiskseq-4\x2dpart1.device
2.523s dev-disk-by\x2dpartuuid-65e19d81\x2d01.device
2.523s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusbv2\x2d0:4:1.0\x2dscsi\x2d0:0:0:0\x2dpart1.devi>
2.523s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusb\x2d0:4:1.0\x2dscsi\x2d0:0:0:0\x2dpart1.device
2.387s dev-disk-by\x2did-usb\x2dSanDisk_Cruzer_Glide_4C530000040131223125\x2d0:0.device
2.387s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusb\x2d0:4:1.0\x2dscsi\x2d0:0:0:0.device
2.387s dev-disk-by\x2dpath-pci\x2d0000:05:00.1\x2dusbv2\x2d0:4:1.0\x2dscsi\x2d0:0:0:0.device
2.387s dev-disk-by\x2ddiskseq-4.device
2.387s sys-devices-pci0000:00-0000:00:01.2-0000:01:00.0-0000:02:08.0-0000:05:00.1-usb1-1\x2d4-1\x2d>
2.387s dev-sdd.device
944ms NetworkManager.service
887ms linux-modules-cleanup.service
851ms initrd-switch-root.service
569ms systemd-tmpfiles-setup.service
363ms grub-btrfs-snapper.service
321ms polkit.service
295ms systemd-udev-trigger.service
266ms systemd-remount-fs.service
243ms systemd-modules-load.service
210ms lm_sensors.service
203ms systemd-vconsole-setup.service
192ms mnt-WildStorage.mount
192ms mnt-WildStorage2.mount
178ms systemd-journal-flush.service
159ms avahi-daemon.service
157ms lvm2-monitor.service
156ms modprobe@fuse.service
155ms bluetooth.service
145ms systemd-zram-setup@zram0.service
128ms plymouth-quit.service
125ms systemd-tmpfiles-setup-dev-early.service
123ms dev-zram0.swap
96ms modprobe@drm.service
93ms user@1000.service
90ms systemd-journald.service
89ms systemd-random-seed.service
85ms garuda-pacman-snapshot-reject.service
84ms ModemManager.service
80ms dracut-pre-udev.service
69ms systemd-fsck@dev-disk-by\x2duuid-6947\x2d1883.service
68ms upower.service
67ms boot-efi.mount
63ms modprobe@loop.service:00.0\x2data\x2d2.0.device
68ms upower.service
67ms boot-efi.mount
~~~4.617s dev-sdb.device
68ms upower.service
67ms boot-efi.mount
62ms systemd-rfkill.service
62ms systemd-sysctl.service
60ms plymouth-read-write.service
56ms user-runtime-dir@1000.service
55ms plymouth-quit-wait.service
49ms udisks2.service
44ms kmod-static-nodes.service
43ms garuda-pacman-lock.service
43ms systemd-udevd.service
43ms dbus.service
43ms colord.service
42ms dracut-shutdown.service
42ms systemd-user-sessions.service
40ms systemd-logind.service
39ms systemd-binfmt.service
36ms systemd-tmpfiles-setup-dev.service
23ms systemd-oomd.service
23ms systemd-timesyncd.service
21ms systemd-update-utmp.service
20ms plymouth-switch-root.service
19ms dracut-cmdline.service
15ms plymouth-start.service
12ms wpa_supplicant.service
11ms systemd-fsck-root.service
9ms home.mount
9ms initrd-parse-etc.service
8ms dev-hugepages.mount
8ms dracut-pre-pivot.service
8ms dev-mqueue.mount
7ms sys-kernel-debug.mount
7ms sys-kernel-tracing.mount
7ms root.mount
6ms initrd-cleanup.service
6ms srv.mount
5ms var-cache.mount
5ms sys-fs-fuse-connections.mount
5ms var-log.mount
5ms rtkit-daemon.service
4ms var-tmp.mount
3ms initrd-udevadm-cleanup-db.service
2ms tmp.mount
2ms proc-sys-fs-binfmt_misc.mount
1ms modprobe@configfs.service
1ms modprobe@dm_mod.service
In case my fstab config is incorrect, here’s that as well. My OS is installed on an SSD for the record:
UUID=6947-1883 /boot/efi vfat defaults,noatime 0 2
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /home btrfs subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /root btrfs subvol=/@root,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=c014b45d-506d-4fec-9173-9f4f3c654339 /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
LABEL=WildStorage2 /mnt/WildStorage2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
LABEL=WildStorage /mnt/WildStorage auto nosuid,nodev,nofail,x-gvfs-show 0 0
Lastly, this issue seems to solve itself after the PC has been idle for long enough. Couldn’t give an exact time frame since I leave my computer on over night but this seems to be an issue mainly on a fresh reboot.
