Audio across system is shut down when most applications are launched
Hello, for a few days now on kernels 6.10.9-zen1-1 and 6.10.9-zen1-2, there is an issue on my system where if I launch most applications, all audio sinks for my system vanish, causing my speakers to emit a loud screech, and then shortly later audio is returned but needs to be configured if the system doesn’t auto-default back to the correct settings for the audio sink.
Before continuing, garuda-inxi:
  Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=d04bc699-4389-4e74-8fe2-fc7b2354f103 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
    UEFI: American Megatrends v: 3602 date: 03/05/2021
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3999 high: 4000 min/max: 2200/5352 boost: disabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 4000
    3: 3999 4: 4000 5: 4000 6: 4000 7: 4000 8: 4000 9: 4000 10: 4000 11: 4000
    12: 3998 13: 4000 14: 4000 15: 4000 16: 4000 17: 4000 18: 4000 19: 4000
    20: 4000 21: 4000 22: 4000 23: 4000 24: 4000 bogomips: 191984
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
    vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 0d:00.0
    chip-ID: 1002:744c class-ID: 0300
  Device-2: Logitech BRIO Ultra HD Webcam
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-4:2 chip-ID: 046d:085e
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
    s-diag: 1407mm (55.38")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
    model: Gigabyte G32QC serial: <filter> built: 2020 res: 2560x1440 dpi: 93
    gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: max: 2560x1440 min: 640x480
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Gigabyte G32QC
    serial: <filter> built: 2020 res: 2560x1440 dpi: 93 gamma: 1.2
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
    navi31 LLVM 18.1.8 DRM 3.57 6.10.9-zen1-2-zen) device-ID: 1002:744c
    memory: 23.44 GiB unified: no
  API: Vulkan v: 1.3.295 layers: 18 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.2.2-arch1.1
    device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.2-arch1.1 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
    bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Focusrite-Novation Focusrite Scarlett 2i2 driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
    chip-ID: 1235:8016 class-ID: fe01
  Device-4: Logitech BRIO Ultra HD Webcam
  Device-5: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-3.3.2:6
    chip-ID: 28de:2102 class-ID: 0a00 serial: <filter>
  Device-6: Valve VR Radio & HMD Mic
    lanes: 1 mode: 1.1 bus-ID: 7-3.3.3:7 chip-ID: 28de:2102 class-ID: 0102
  API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pw-jack type: plugin
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:4 chip-ID: 8087:0029
  Local Storage: total: 9.1 TiB used: 1.69 TiB (18.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Reletech
    model: P400 M.2 Pro Q2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: EGFM52.3 temp: 50.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion Desk
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 9401 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 468.96 GiB (25.2%)
    used: 468.96 GiB (25.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 39.0 C mobo: 31.0 C gpu: amdgpu temp: 45.0 C
    mem: 55.0 C
  Memory: total: 32 GiB available: 31.24 GiB used: 6.44 GiB (20.6%)
  Processes: 445 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2091 libs: 575 tools: octopi,paru Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
  System install date:     2024-05-05
  Last full system update: 2024-09-11
Details of problem:
During system runtime at any point, if an application that was not already running before the current wireplumber/pipewire instance was running, the system appears to cause the audio service overall to crash/be terminated, emit a screech, then shortly later audio services are rebooted.
Example A)
I am in a call on Discord with a friend and we go to play Overwatch or Satisfactory, the audio gets cut out, a screech is emitted, Discord hangs, and the application loads. To get sound I must reconfigure my audio sink after it reappears. To fix Discord from it’s frozen state (audio stops, visuals stops, does not fade to show it hung), I must simply reboot it, then it’s working fine and outputting it.
Example B)
I go to watch a video on Youtube in the FireDragon browser, it plays fine. While that is still playing, I open Steam which does not cause the audio to break as described. I then launch any game where the audio now gets shuts down, a screech is emitted, the video buffers until the audio sink returns. If the game has a launcher like Minecraft, Stellaris, Star Citizen, or Wizard101; the audio will become terminated as described for both the launcher and for the game when it too gets launched. In this case, games from launchers are stuck in perma-silent from my testing even once audio is restored.
I am able to restart the user services for pipewire, pipewire-pulse, and wireplumber, all using the command systemctl --user restart <service> but doing this does not resolve the audio being shut down later on if another application triggers it to terminate for whatever reason.
For the screech, I have found it very much is just the sound my speakers make when they become suspended or such. This used to be heard during normal runtime in the past if I did not follow the steps on the following Arch wiki page category to stop the speakers from entering a power saving state: https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture/Troubleshooting#Pops_when_starting_and_stopping_playback. As of this issue, this 1) doesn’t seem to be needed (right now), but 2) the speakers enter power_saving/suspension from the current problem.
When I check log entries for pipewire, pipewire-pulse, and wireplumber, I can see various points where the systems are shutting down and start in relation to me opening software like OBS or Overwatch, but the cause to me doesn’t feel related to them initially. For example in the wireplumber link for it’s journalctl entry, you can find that there are parts where wireplumber is stating “stopped by signal: Terminated”, which makes me think something outside wireplumber/pipewire that is causing this issue here. The journalctl entries for each of those can be viewed in the following:
pipewire: gist:c886b659327405a5575eba3b1abee87e · GitHub
pipewire-pulse: gist:c6aa6bdaffc918b4c8a7fc3c193c4bd3 · GitHub
wireplumber: gist:ade44030182d72ee972aee01e7e6bebf · GitHub
overall, generic: gist:f673dfdb1ad247a58790be2e832d9293 · GitHub
I am still trying to figure out how to find what might be sending a SIGTERM to wireplumber but I’m not fully versed yet with debugging completely still.
I should also add that this issue was not able to be fixed by rolling back to a previous point via Snapper that I had from about 10 days ago before updating initially 3 days ago. For whatever reason, when I went back to a restore point prior to the garuda-update I did that took me to kernel 6.10.9-zen1-1 initially, the issue persisted on that restore point after rebooting despite it not being a thing back then in time. So as of writing this I am now on 6.10.9-zen1-2 with the issue still present and thus wondering on how I can further debug the problem at hand to eventually find a resolution for it.
If there’s other details needed, I can certainly provide them once I’m aware to what is being inquired. In the meantime, thanks in advance!
First, I would update your BIOS to the latest version. v 3603 states that it fixed a USB connectivity issue which might explain some of your I/O errors in your logs. Later versions also note improvements to system compatibility and stability (among other things like security fixes of course).
If that doesn’t fix it itself, I would also test the LTS kernel and see if you still are getting similar errors.
Howdy Kayo, thank you for your reply! I went ahead and did both of what you suggested; despite neither leading to an immediate solution, some steps I tried afterward appear to have solved the issue.
Given that it seems to not be kernel related after testing it in the linux-lts kernel, I went to start checking packages on an individual level:
  • I replaced wireplumber with pipewire-media-session, which of course is depreciated, to test if it was the session manager at fault. When I followed the steps to trigger the issue, the same outcome continued with no deviation thus marking it wasn’t related to wireplumber to begin with.
  • I upped the logging levels for pipewire which to my unsatisfaction still wasn’t giving any immediate “ah-ha” moments for me. So it made me wonder if something was wrong directly with pipewire itself. To test that, I went and reinstalled it using the typical sudo pacman -S pipewire then rebooted. Upon doing this, the issue, just as magically as it appeared, appears to be fixed.
After getting it to work with no issues in linux-lts I switched back to zen and all is fine again with no problem. Guess there was just a small hiccup after updating. I feel silly after running around checking logs and whatever else I could find; all while not even thinking to try testing individual packages to see when the behavior starts to change. Trial and error I suppose, exhaust all options one at a time. Anywho with the fix, however mundane it ended up being, I thank you for your time and suggestions, definitely needed to update the bios in due time anyway, was a good time to do just that.
