Audacious is opening whenever a drive is added
Audacious is opening whenever a drive is added; seems to be a known issue; happens on every system after setting folders to be opened by Audacious. ~ mount - Why opening a folder via a shortcut makes Audacious to start? - Ask Ubuntu
Dolphin is also having issues removing drives; takes a really long time; closing the window seems to speed it up so could be a memory leak issue.
Much appreciated.
Kernel: 6.5.7-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc available: hpet,acpi_pm parameters: pti=on
root=UUID=ee9d8e46-88f6-40bb-a345-3b374ebb4edb rw rootflags=subvol=@
quiet rd.luks.uuid=5d766ada-bbea-4479-b984-c5950293753b quiet
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: A88XM-PLUS v: Rev X.0x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 3004
date: 04/14/2017
Info: model: AMD A10-7850K Radeon R7 12 Compute Cores 4C+8G bits: 64
type: MT MCP arch: Steamroller level: v2 built: 2014 process: GF 28nm
family: 0x15 (21) model-id: 0x30 (48) stepping: 1 microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 3276 high: 3910 min/max: 1700/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3910 2: 3881
3: 2316 4: 3000 bogomips: 29537
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: XFX Pine
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:687f
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 358x202mm (14.09x7.95")
s-diag: 411mm (16.18")
Monitor-1: DP-3 mapped: DisplayPort-2 model: Sharp HDMI built: 2008
res: 1360x768 hz: 60 dpi: 42 gamma: 1.2 size: 820x460mm (32.28x18.11")
diag: 940mm (37") ratio: 16:9 modes: max: 1920x1080 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Vega (vega10 LLVM
16.0.6 DRM 3.54 6.5.7-hardened1-1-hardened) device-ID: 1002:687f
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.264 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX Vega (RADV VEGA10) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:687f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD FCH Azalia vendor: ASUSTeK AM1I-A driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aaf8 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i2 3rd Gen
driver: snd-usb-audio,usb-storage type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 2-3:4 chip-ID: 1235:8210 class-ID: 0806
API: ALSA v: k6.5.7-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.14 TiB used: 24.72 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
tech: SSD serial: <filter> fw-rev: 3B0Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdc maj-min: 8:32 model: Scarlett Welcome Disk size: 192 KiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 0.10 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Transcend model: N/A size: 1.87 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: TS37
scheme: MBR
ID-1: / raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
used: 24.72 GiB (10.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5d766ada-bbea-4479-b984-c5950293753b
ID-2: /home raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-3: /var/log raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 16.2 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 24.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 828
Processes: 249 Uptime: 8m wakeups: 0 Memory: total: 32 GiB
available: 31.3 GiB used: 2.42 GiB (7.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1440 libs: 470 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-03-11
Last full system update: 2023-10-12
Well, don’t do that then :man_shrugging: . Honestly, I do not understand the problem, if you have set the folders to be opened with audacious, then it’s normal that when you add a device, it tries to show the contents and therefore opens audacious…
The intent of opening a folder with Audacious; is to do so once when clicked; auto all folders opening with Audacious on drives being added to the system is (hopefully not working as intended) or an exploit.
Much appreciated.
It works as expected, when you set a default program to open your folders, it will be used for anything that has to do with folders and that includes opening devices attached to the device.
Again, just don’t do that, the default program to open folders should be your file manager, not Audacious.
Should be a way to open a folder of music files with Audacious not set to default.
Did you try the solution in the thread you linked?
Here is the very subtle fact I had not any vision of. I had used Open with other application... on a folder by a right click to make Audacious enqueu the music files inside of it and start playing them. It must have been one of the times that I had forgotten to remove Remember this application for "folder" files option and the system started to open Audacious every time I tried to mount a drive.
To fix the issue I ordered the system to open folders by Caja and the system is now working perfectly fine.
Of course replace Caja for whatever file explorer you are using.
Another way you could approach this is to edit ~/.config/mimeapps.list and remove Audacious from any unwanted file association.
Guess could submit a feature request for Dolphin at some point; not too crucial just seemed like a bug; interesting as always to learn more about Linux. Much appreciated.
