I've tried a lot of distros, but internet speed barely reaches 500kb while it reaches 30 mbps on windows on the dual boot.
As of now I've tried Power management settings.
Dell i5 3567
Qualcomm athenos wireless wifi network chip.
Dell i5 3567
Hi there, welcome!
Please provide your system specs via inxi -Fza as text, formatted with 3 ~ before and after the text block.
We neither have any influence on the download speed nor do we install brakes.
If the servers are in high demand, as is the case with Arch or Garuda, traffic jams can occur
Several common Atheros cards have a multitude of different fixes.
Without knowing your specs we really can only make general recommendations.
As your wifi driver module(s) are included in the kernel the first place to start is with testing alternate kernels. Have a look at other posts on the forum in the Networking category to see which kernels are most often reccomended for troubleshooting purposes.
Run inxi -Faz in the terminal. Find your Atheros wifi chip model and search the forum for fixes for your specific model. Post all fixes you have attempted and the results.
Be sure to post the output of inxi -Faz.
Welcome to Garuda.
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=03687889-237e-45ad-a9bf-d6c6f7aff21b
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9
Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.10.0 date: 05/10/2019
Battery: ID-1: BAT0 charge: 19.9 Wh (94.3%) condition: 21.1/41.4 Wh (51.0%) volts: 17.2 min: 14.8
model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Charging
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21599
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3100 2: 3101 3: 3101 4: 3102
Graphics: Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660
class-ID: 0380
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:32
chip-ID: 1bcf:28c0 class-ID: 0e02
Display: x11 server: X.Org 1.20.12 compositor: gnome-shell driver: loaded: ati,intel,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.5-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:9 chip-ID: 0cf3:e009
Drives: Local Storage: total: 946.35 GiB used: 7.15 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-75JC3T0 size: 931.51 GiB
serial: <filter> rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC size: 14.84 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 93.48 GiB size: 93.48 GiB (100.00%) used: 7.11 GiB (7.6%) fs: btrfs
dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 41.9 MiB (43.6%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 93.48 GiB size: 93.48 GiB (100.00%) used: 7.11 GiB (7.6%) fs: btrfs
ID-4: /var/log raw-size: 93.48 GiB size: 93.48 GiB (100.00%) used: 7.11 GiB (7.6%) fs: btrfs
ID-5: /var/tmp raw-size: 93.48 GiB size: 93.48 GiB (100.00%) used: 7.11 GiB (7.6%) fs: btrfs
ID-1: swap-1 type: zram size: 5.67 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 44.0 C mobo: 41.0 C gpu: radeon temp: 34.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 245 Uptime: 11h 15m wakeups: 2 Memory: 5.67 GiB used: 2.12 GiB (37.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1124 lib: 301
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06~~~
These is my setup
Many fixes you could test on this thread:
Kernel boot parameters are likely your best bet.
Try these options individually or in combination.:
ath10k_core.skip_otp=y
or
ath10k_core.nohwcrypt=1
or
pcie_aspm=off
I would also disable IPv6 and test alternate kernels.
Welcome to Garuda, I hope you don’t mind I edited your thread title to include your adapter model.
