Many years ago I used various flavors of Ubuntu and they all had built-in support for mounting Atari disk partitions, which was extremely convenient for transferring files between Ataris and Linux PCs using SD cards. Ever since I left Ubuntu I haven’t been able to do this. It seems the ability is still in the kernel source but it’s not enabled in most distros. I can see the source files in the Zen repo, but I don’t know how to enable them to recompile them into the kernel. From what I’ve been able to gather, it doesn’t seem to be a kernel module. Here is what I found looking at the source repo:
There’s so little information on this, I don’t really know where to look for help on how to do this… but I’d really like the ability to just pop Atari formatted SD cards into my computer and mount them with Dolphin like I used to.
Any assistance would be appreciated.
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 897 high: 1100 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1033 2: 800 3: 1100
4: 1099 5: 1100 6: 800 7: 1100 8: 1100 9: 800 10: 800 11: 800 12: 800
13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 1098
22: 800 23: 1099 24: 800 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:8
chip-ID: 1532:0e03 class-ID: 0102
Device-3: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.2:9
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:13 chip-ID: 534d:2109
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:4
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.57 6.7.4-zen1-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.5-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: PreSonus Audio AudioBox USB driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.3:21
chip-ID: 194f:0302 class-ID: 0103
Device-4: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-5: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-6: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
Device-7: KORG microKEY driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.3.2:14 chip-ID: 0944:0111
class-ID: 0103
Device-8: MacroSilicon USB Video
Device-9: Emagic Soft- und Hardware GmbH Unitor8 driver: snd-usb-audio
type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.4.2:26
chip-ID: 086a:0001 class-ID: ff00
Device-10: Elgato Systems GmbH Game Capture HD60 X
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3an Ethernet [Marvell
Scalable mGig] vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0
class-ID: 0200 temp: 43.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:24 chip-ID: 8087:0033
Local Storage: total: 16.61 TiB used: 1.53 TiB (9.2%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 56.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
ID-4: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HUS724040ALA640
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AA70 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HUS724040ALA640
tech: HDD rpm: 7200 serial: <filter> fw-rev: AC50 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-8: /dev/sde maj-min: 8:64 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.01 TiB (55.3%)
used: 2.1 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 1.01 TiB (55.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.61 GiB used: 753.5 MiB (1.2%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 50.0 C
Processes: 585 Uptime: 9h 47m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 10.1 GiB (16.1%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2230 libs: 603 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.23-1):
System install date: 2023-05-03
Last full system update: 2024-02-09 ↻
