Hello everyone.
I have a problem with my microphone on the headset. The quality is so bad that all you can hear is crackling and noise. Have tested 2 other headsets, same problem.
Here is my inxi…Headset is plugged in
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=10157110-2cd6-485c-860f-a47c5735c0f1 rw rootflags=subvol=@
quiet resume=UUID=b6306d6a-f89f-48e6-a98a-91af0fb78502 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: ASUSTeK product: ROG Strix G713QR_G713QR v: 1.0
Mobo: ASUSTeK model: G713QR v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: G713QR.327
date: 03/29/2022
ID-1: BAT0 charge: 67.2 Wh (85.1%) condition: 79.0/90.0 Wh (87.8%)
volts: 16.3 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1081 high: 2971 min/max: 400/4890 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1458 2: 400 3: 400
4: 400 5: 400 6: 2971 7: 1578 8: 400 9: 1415 10: 1891 11: 400 12: 400
13: 1913 14: 400 15: 2475 16: 400 bogomips: 105413
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
gpu: nvidia,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 2560x1440 size: N/A modes: N/A
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
renoir LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3070 Laptop GPU driver: nvidia
v: 555.58.02 device-ID: 10de:249d surfaces: xcb,xlib,wayland device: 2
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 1.4 TiB used: 217.36 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HAJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 4L1QEXA7 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
used: 217.36 GiB (23.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-4: /var/log raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 937.02 GiB size: 937.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.04 GiB used: 1.43 GiB (9.5%)
ID-2: swap-2 type: partition size: 16.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
System Temperatures: cpu: 55.4 C mobo: 36.0 C gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.04 GiB used: 4.8 GiB (31.9%)
Processes: 383 Power: uptime: 1h 7m states: freeze,mem,disk
suspend, test_resume image: 5.99 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1508 libs: 469 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-07-14
Last full system update: 2024-07-29 ↻
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio nvidia-dkms
