Orko
November 26, 2022, 9:01am
1
I would love to get Assassin's Creed Valhalla running, but since a game update some months ago I can't get it to work anymore. Maybe someone can help here?
I've tried to install Ubisoft Connect with Lutris and Bottles. I have read in many forums and tried the weirdest hints given there. I have tried to get it to run under Garuda, EndeavourOS, Linux Mint and Ubuntu. Not only that, but I tried different versions of GE Proton on each os. DXVK and VKD3D enabled. I have tried to turn esync and fsync on and off. I have added d3dx11 and d3dx12 libraries. Now I don't have any more ideas how I could get it to work.
Does anyone play Valhalla under Garuda and can help me with that?
SGS
November 26, 2022, 9:21am
2
Please do not post help requests under Community, as they are off-topic.
You can post there again but without the gaming problem. Thank you.
filo
November 26, 2022, 11:51am
3
I'm not a gamer , but checking on protondb I've found this comment. It seems recent, so, if you want, give a look at it...
https://www.protondb.com/app/2208920
Oh well, I see now you probably already tried it...
Orko
November 26, 2022, 12:49pm
4
Hey, this post is new, thank you! I have searched protondb several times in the past, but there was no entry for Valhalla.
Unfortunately this doesn't work for me. Same problem as always. The small splash screen appears and after a few seconds it closes and the game doesn't start.
I think there must be an issue with DX12. All DX11 games are working fine. Valhalla is the only DX12 game I want to play so far. Or it is caused by version 1.6 and later of the game. I had running with 1.5x a few months ago.
filo
November 26, 2022, 1:19pm
5
I think it's time to provide your garuda-inxi.
Do you know if your GPU fully supports DX12?
Orko
November 26, 2022, 1:28pm
6
I have a RTX2080. It supports DX12 for sure. I have played some DX12 games on Windows before I switched over to Linux last year.
Here is my garuda-inxi, hope it helps :
Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=*** rw rootflags=subvol=@
quiet
cryptdevice=***
root=/dev/mapper/*** quiet splash
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop System: Gigabyte product: Z390 AORUS PRO WIFI v: N/A
Mobo: Gigabyte model: Z390 AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F12k
date: 01/19/2021
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4398 high: 4406 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4398 2: 4389 3: 4400
4: 4394 5: 4400 6: 4394 7: 4400 8: 4400 9: 4400 10: 4406 11: 4399 12: 4400
bogomips: 88796
vulnerable
PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e82 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 60 s-size: 1626x914mm (64.02x35.98")
s-diag: 1865mm (73.44")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 61
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.27") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX
2080/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASUSTek ROG STRIX IMPACT II WIRELESS type: USB
driver: hid-generic,usbhid bus-ID: 1-10:3 chip-ID: 0b05:1949 class-ID: 0301
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 2.39 TiB used: 656.68 GiB (26.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-ASM2NE2512GTTDR size: 476.94 GiB block-size: physical: 512 B
rev: ECFM12.2 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Sabrent model: Rocket Q
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: RKT30Q.1 temp: 26.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: IBM model: ESA3SF1120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: GPT
used: 137.13 GiB (28.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-***
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
mapped: luks-***
mapped: luks-***
mapped: luks-***
ID-1: swap-1 type: zram size: 31.3 GiB used: 25.8 MiB (0.1%) priority: 100
System Temperatures: cpu: 39.0 C pch: 36.0 C mobo: N/A gpu: nvidia
temp: 58 C
Processes: 393 Uptime: 5h 30m wakeups: 1 Memory: 31.3 GiB
used: 10.98 GiB (35.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1934
pm: pacman pkgs: 1929 libs: 516 tools: gnome-software,pamac,paru pm: flatpak
pkgs: 5 Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-18
Last full system update: 2022-11-26 ↻
