This is a great way to share your terminal input.
You can install it from the repos via sudo pacman -S asciinema
Use asciinema rec to start recording
Finish the recoding by typing exit
You can then upload it with a press on Enter.
You get an URL, that lets you share it.
The whole thing is saved purely in JSON.
So tiny sizes, and all the text can be copied.
Much fun
