Hello Everyone. I run Garuda Dragonized on 2 computers. My only internet comes from my android phone. In America, our mobile hotspots are limited (mine was limited to 15gigs a month) and i've learned to get around that with the PDANet+ Android app but still limited to only 40 gigs a month before I get slowed to 2G Data. To make a long story short, I'm hoping to find a way the 2 computers could share an update; or any other way anyone can think of to use less bandwidth. I'd love to hear any ideas, whatever they are. Thank you.
inxi #1
â•─user@garudabox in ~ took 1h7m43s
╰─λ sudo inxi -Famz
[sudo] password for user:
System: Kernel: 5.14.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5634b16a-e443-4173-b485-8bda91837d75 rw
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 427639U v: ThinkPad W520 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 427639U serial: <filter> UEFI: LENOVO v: 8BET62WW (1.42 ) date: 07/26/2013
Battery: ID-1: BAT0 charge: 64.5 Wh (98.3%) condition: 65.6/71.3 Wh (92.1%) volts: 12.4 min: 10.8 model: SANYO 42T4763
type: Li-ion serial: <filter> status: Unknown
Memory: RAM: total: 17.46 GiB used: 2.93 GiB (16.8%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: 0000 part-no: Not Specified serial: N/A
Device-2: ChannelA-DIMM1 size: 8 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: 85F7 part-no: H641GU67G1600G serial: N/A
Device-3: ChannelB-DIMM0 size: 2 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: Hynix/Hyundai part-no: HMT425S6CFR6A-PB serial: <filter>
Device-4: ChannelB-DIMM1 size: No Module Installed
CPU: Info: Quad Core model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L1: 64 KiB L2: 8 MiB L3: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36681
Speed: 2238 MHz min/max: 800/3400 MHz base/boost: 2300/2300 volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz):
1: 2238 2: 2370 3: 2590 4: 2901 5: 2920 6: 3079 7: 2855 8: 2614
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF108GLM [Quadro 1000M] vendor: Lenovo driver: nvidia v: 390.144 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:0dfa class-ID: 0300
Device-3: Chicony Lenovo Integrated Camera (0.3MP) type: USB driver: uvcvideo bus-ID: 1-1.6:6 chip-ID: 04f2:b217
class-ID: 0e02
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0 screens: 1
Monitor-1: LVDS-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Quadro 1000M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.144 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Lenovo ThinkPad T520
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.14.15-zen1-1-zen running: yes
Network: Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520 driver: e1000e v: kernel port: 6080
bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:0085
Device-3: D-Link System DWA-140 RangeBooster N Adapter(rev.B2) [Ralink RT3072] type: USB driver: rt2800usb
bus-ID: 1-1.2:3 chip-ID: 07d1:3c0a class-ID: 0000 serial: <filter>
IF: wlp0s26u1u2 state: up mac: <filter>
Bluetooth: Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8 bus-ID: 1-1.4:5 chip-ID: 0a5c:217f
Drives: Local Storage: total: 1.17 TiB used: 264.24 GiB (22.1%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 family: Travelstar 7K1000
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: A3U0 temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 68d 23h cycles: 3757
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD1600BEVT-60ZCT1 family: Scorpio Blue Serial ATA
size: 149.05 GiB block-size: physical: 512 B logical: 512 B sata: 2.5 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A13 temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 105d 7h cycles: 1445 Old-Age: write error rate: 100 threshold: 100
Partition: ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 28.23 GiB (44.1%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%) used: 36.6 MiB (37.2%) fs: vfat block-size: 512 B
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 827.41 GiB size: 827.41 GiB (100.00%) used: 235.98 GiB (28.5%) fs: btrfs block-size: 4096 B
dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 64 GiB size: 64 GiB (100.00%) used: 28.23 GiB (44.1%) fs: btrfs block-size: 4096 B
dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 64 GiB size: 64 GiB (100.00%) used: 28.23 GiB (44.1%) fs: btrfs block-size: 4096 B
ID-1: swap-1 type: zram size: 17.46 GiB used: 2.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (RPM): cpu: 2501
Info: Processes: 281 Uptime: 1h 35m wakeups: 1 Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 1373 lib: 343 Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
Inxi #2
â•─user@kde in ~
╰─λ sudo inxi -Famz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0f530c62-8b56-4871-b469-9e17bf15fa1c rw
Machine: Type: Laptop System: LENOVO product: 20AN009CUS v: ThinkPad T440p serial: <filter> Chassis: type: 10
Mobo: LENOVO model: 20AN009CUS v: 0B98401 PRO serial: <filter> UEFI: LENOVO v: GLETA1WW (2.55 ) date: 04/20/2020
Battery: ID-1: BAT0 charge: 42.5 Wh (100.0%) condition: 42.5/56.2 Wh (75.7%) volts: 12.3 min: 10.8 model: LGC 45N1147
type: Li-ion serial: <filter> status: Full
Memory: RAM: total: 7.64 GiB used: 2.36 GiB (30.9%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
total: 64 bits manufacturer: Samsung part-no: M471B5273CH0-CH9 serial: <filter>
Device-2: ChannelB-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
CPU: Info: Quad Core model: Intel Core i7-4700MQ socket: rPGA988B (U3E1) note: check bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L1: 64 KiB L2: 6 MiB L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38310
Speed: 2459 MHz min/max: 800/3400 MHz base/boost: 2400/2400 volts: 0.8 V ext-clock: 100 MHz Core speeds (MHz):
1: 2459 2: 2633 3: 2462 4: 2417 5: 2503 6: 2431 7: 2473 8: 2452
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 730M] vendor: Lenovo driver: nouveau v: kernel bus-ID: 02:00.0
chip-ID: 10de:1290 class-ID: 0300
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9") s-diag: 523mm (20.6")
Monitor-1: VGA1 res: 1680x1050 hz: 60 dpi: 91 size: 470x300mm (18.5x11.8") diag: 558mm (22")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.2.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo ThinkPad T440p driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo ThinkPad T440p driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkPad T440p driver: e1000e v: kernel port: 4080 bus-ID: 00:19.0
chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:08b2 class-ID: 0280
bus-ID: 3-1:4 chip-ID: 07d1:3c0a class-ID: 0000 serial: <filter>
IF: wlp0s20u1 state: up mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-11:3 chip-ID: 8087:07dc
Drives: Local Storage: total: 465.76 GiB used: 97.9 GiB (21.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000LPCX-75VHAT1 family: Blue Mobile size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A05 temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 258d 14h cycles: 5241 read: 20.17 TiB written: 14.13 TiB Old-Age:
g-sense error rate: 4295
Partition: ID-1: / raw-size: 48 GiB size: 48 GiB (100.00%) used: 12.22 GiB (25.4%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%) used: 3.2 MiB (3.2%) fs: vfat block-size: 512 B
ID-3: /home raw-size: 385.66 GiB size: 385.66 GiB (100.00%) used: 85.68 GiB (22.2%) fs: btrfs block-size: 4096 B
ID-4: /var/log raw-size: 48 GiB size: 48 GiB (100.00%) used: 12.22 GiB (25.4%) fs: btrfs block-size: 4096 B
ID-5: /var/tmp raw-size: 48 GiB size: 48 GiB (100.00%) used: 12.22 GiB (25.4%) fs: btrfs block-size: 4096 B
ID-1: swap-1 type: zram size: 7.64 GiB used: 4.2 MiB (0.1%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A gpu: nouveau temp: 48.0 C
Fan Speeds (RPM): fan-1: 2742
Info: Processes: 264 Uptime: 7m wakeups: 1 Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 1225 lib: 305 Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
