When I run yay -Syy
it complains with:
:: packages not in the AUR: itch lib32-openssl-1.0 rootactions-servicemenu
It seems these packages are dropped in about the last year. I'm wondering whether I can remove them or how I can verify the dependencies.
gives:
Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f2f68770-5de0-43ab-adcd-658fbe1eaf8c rw [email protected]
loglevel=3 ibt=off
Type: Desktop System: LENOVO product: 90VA000ACP v: LEGION REN9000K-34IRZ
Mobo: LENOVO model: 376A v: SDK0T76479 WIN 3423069218157
serial: <superuser required> UEFI: LENOVO v: O5UKT17A date: 11/09/2022
ID-1: hidpp_battery_0 charge: 35% condition: N/A volts: 3.8 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
microcode: 0x10E
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 3084 high: 5502 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: performance cores: 1: 2564 2: 1032 3: 2280
4: 3000 5: 3812 6: 3000 7: 4913 8: 3000 9: 5015 10: 3000 11: 5502 12: 3000
13: 2815 14: 3000 15: 2353 16: 3000 17: 2465 18: 2947 19: 3000 20: 3000
21: 3000 22: 3000 23: 3000 24: 3000 25: 3000 26: 3000 27: 3000 28: 3000
29: 3000 30: 3000 31: 3000 32: 3000 bogomips: 191692
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Lenovo driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2684 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-8:2
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
s-diag: 692mm (27.24")
Monitor-1: DP-2 res: 3840x2160 hz: 144 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
API: OpenGL v: N/A renderer: N/A direct-render: N/A
Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 2-8:2
chip-ID: 046d:085e alternate: snd_sof_pci_intel_tgl class-ID: 0300
bus-ID: 00:1f.3 chip-ID: 8086:7a50 serial: <filter> class-ID: 0403
Device-2: NVIDIA AD102 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam type: USB
Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Lenovo driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vethb34809c state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 3.73 TiB used: 63.87 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Lenovo
model: M.2 2280 NVMe SSD 2T size: 1.86 TiB block-size: physical: 512 B
rev: 2.4.8.42 temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCQNRZ-2T00-1001 size: 1.86 TiB block-size: physical: 512 B
rev: 61540101 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 63.84 GiB (3.3%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:7
used: 33.5 MiB (13.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 63.84 GiB (3.3%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:7
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.5 GiB used: 3.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 544 Uptime: 2d 3h 0m wakeups: 248 Memory: 62.5 GiB
used: 9.74 GiB (15.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1895
libs: 518 tools: octopi,paru Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-02-04
Last full system update: 2023-02-12 ↻
