Hello Garuda users.
I am trying to flash firmware on my arduino nano 33 ble sense MCU and have connected it to my laptop running Garuda Linux (inxi below:)
root=UUID=a3eadc67-17e5-4a86-8b24-7b34a01a3003 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: LENOVO product: 82FE v: IdeaPad 5 14ITL05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 14ITL05
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
serial: <superuser required> UEFI: LENOVO v: FKCN42WW(V3.05)
date: 05/16/2022
ID-1: BAT1 charge: 31.3 Wh (59.6%) condition: 52.5/56.5 Wh (92.9%)
volts: 11.8 min: 11.5 model: SMP L19M3PF4 type: Li-ion serial: <filter>
status: not charging cycles: 92
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2225 high: 2400 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 2400
4: 2400 5: 2400 6: 2400 7: 1003 8: 2400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 model: BOE Display 0x08d7 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
bus-ID: 3-10:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 48.91 GiB (10.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
lanes: 4 type: SSD serial: <filter> rev: 0013P6LN temp: 47.9 C scheme: GPT
ID-1: / raw-size: 85.83 GiB size: 85.83 GiB (100.00%)
used: 14.01 GiB (16.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 633 MiB size: 631.8 MiB (99.80%)
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 111.76 GiB size: 109.44 GiB (97.93%)
used: 34.9 GiB (31.9%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 85.83 GiB size: 85.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 85.83 GiB size: 85.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 31.2 MiB (0.2%)
ID-2: swap-2 type: partition size: 2.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
Src: /sys System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 294 Uptime: 13h 16m wakeups: 18448 Memory: 15.41 GiB
used: 3.22 GiB (20.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1224
libs: 308 tools: octopi,paru Shell: fish v: 3.5.1 running-in: tmux:
inxi: 3.3.23
e[1;34mGaruda (2.6.9-1):e[0m
e[1;34m System install date:e[0m 2022-10-16
e[1;34m Last full system update:e[0m 2022-11-13 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m snapper-cleanup.service
Now ideally the arduino should have come up as /dev/ttyACM0 but in my case it is not. It worked for me in my ubuntu previously so I know hardware is not the issue.
dmesg output below shows that the system is indeed correctly even detecting the device.
[47632.161209] audit: type=1110 audit(1668356813.381:472): pid=44642 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo
" hostname=? addr=? terminal=/dev/pts/2 res=success'
[47632.162758] audit: type=1105 audit(1668356813.383:473): pid=44642 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" ex
e="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[47633.984122] audit: type=1106 audit(1668356815.205:474): pid=44642 uid=1000 auid=1000 ses=3 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" e
xe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[47633.984127] audit: type=1104 audit(1668356815.205:475): pid=44642 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo
[47648.488426] usb 3-1: USB disconnect, device number 18
[47650.492404] usb 3-1: new full-speed USB device number 19 using xhci_hcd
[47650.624111] usb 3-1: New USB device found, idVendor=2341, idProduct=005a, bcdDevice= 0.11
[47650.624120] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[47650.624124] usb 3-1: Product: Arduino Nano 33 BLE
[47650.624126] usb 3-1: Manufacturer: Arduino
[47650.624128] usb 3-1: SerialNumber: 0000000000000000894188AAF1E3C4EE
[47650.764525] usb 3-1: USB disconnect, device number 19
[47654.086529] usb 3-1: new full-speed USB device number 20 using xhci_hcd
[47654.217419] usb 3-1: New USB device found, idVendor=2341, idProduct=005a, bcdDevice= 0.11
[47654.217428] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[47654.217432] usb 3-1: Product: Arduino Nano 33 BLE
[47654.217434] usb 3-1: Manufacturer: Arduino
[47654.217436] usb 3-1: SerialNumber: 0000000000000000894188AAF1E3C4EE
[47656.336645] audit: type=1101 audit(1668356837.556:476): pid=44677 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="dgole" exe="/usr/bin/sudo" ho
[47656.336921] audit: type=1110 audit(1668356837.556:477): pid=44677 uid=1000 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/
[47656.338462] audit: type=1105 audit(1668356837.558:478): pid=44677 uid=1000 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" ex
I saw online solutions referring to usergroups and other permission issues but I doubt my case is even related to that. Output of lsusb says that a device is present as well:
λ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 008: ID 04f3:0c4d Elan Microelectronics Corp. ELAN:Fingerprint
Bus 003 Device 002: ID 174f:2459 Syntek Integrated Camera
Bus 003 Device 007: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 003 Device 020: ID 2341:005a Arduino SA Arduino Nano 33 BLE
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
