Arch default connectivity check - Limited Connectivity after connecting to VPN (openconnect)
Hello, I am hoping someone might have the answer to this simple question.
TL;DR: Where does Garuda Linux store it's URL for testing internet connectivity and can it be changed?
I use the openconnect vpn client to connect to a vpn service that allows me to access local (LAN) resources and remote (VPN) services as well as browse the internet (currently posting from this connection).
The problem I see via notification (NetworkManager) is that my network connection now has limited connectivity. I have multiple devices connected locally (wired & wireless) so I know the issue is not with my network infrastructure hardware.
I have tested and experienced identical behavior on multiple linux distributions with the same vpn connection and client. After researching the issue, I discovered most distributions will attempt to contact a URL to confirm the now established network connection indeed has internet access.
I was wondering if someone might know this URL and where it might be located in the filesystem?
Thanks,
output of command as requested:
λ garuda-inxi
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=159c93a0-fb54-4226-9244-a78d704c36cf rw rootflags=subvol=@
quiet
cryptdevice=UUID=a30f9751-1800-4d79-a969-3c083c87c493:luks-a30f9751-1800-4d79-a969-3c083c87c493
root=/dev/mapper/luks-a30f9751-1800-4d79-a969-3c083c87c493 quiet splash
resume=/dev/mapper/luks-46677273-9ceb-42ca-8365-85fe6d1c09a4 loglevel=3
Type: Laptop System: Dell product: XPS 13 9310 v: N/A
Mobo: Dell model: 0DMPXV v: A00 serial: <superuser required> UEFI: Dell
v: 3.6.0 date: 03/17/2022
ID-1: BAT0 charge: 40.6 Wh (100.0%) condition: 40.6/51.0 Wh (79.6%)
volts: 8.3 min: 7.6 model: BYD DELL FP86V0B type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1586 high: 2828 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 899 2: 2828 3: 1632
4: 963 5: 1510 6: 1429 7: 1480 8: 1954 bogomips: 47923
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel ports: active: DP-5,DP-6 off: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-7, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-4.1:5 chip-ID: 046d:081b class-ID: 0102 serial: <filter>
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 0c45:672a class-ID: 0e02
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (39.96x11.22")
s-diag: 1054mm (41.51")
Monitor-1: not-matched mapped: DP-3-1 pos: primary,left res: 1920x1080
hz: 60 dpi: 93 size: 522x293mm (20.55x11.54") diag: 599mm (23.57")
modes: N/A
Monitor-2: not-matched mapped: DP-3-2 pos: primary,right res: 1920x1080
modes: N/A
Monitor-3: eDP-1 note: disabled model: Samsung 0x414f built: 2020
res: 1920x1080 dpi: 305 gamma: 1.2 size: 288x180mm (11.34x7.09")
diag: 340mm (13.4") ratio: 16:10 modes: 3456x2160
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.0
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
chip-ID: 8086:a0c8 class-ID: 0401
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.3.1:8
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 72:00.0 chip-ID: 17cb:1101 class-ID: 0280
IF: wlp114s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-3.4:6 chip-ID: 0bda:8153 class-ID: 0000
IF: enp0s13f0u3u4 state: down mac: <filter>
IF-ID-1: vpn0 state: up speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 1.86 TiB used: 31.38 GiB (1.6%)
model: PM9A1 NVMe 2048GB size: 1.86 TiB block-size: physical: 512 B
rev: 36308129 temp: 54.9 C scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 31.38 GiB (1.7%)
mapped: luks-a30f9751-1800-4d79-a969-3c083c87c493
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 31.38 GiB (1.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 31.07 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
mapped: luks-46677273-9ceb-42ca-8365-85fe6d1c09a4
System Temperatures: cpu: 61.0 C mobo: 52.0 C
Fan Speeds (RPM): cpu: 6105 mobo: 5791 fan-2:
Processes: 350 Uptime: 1h 2m wakeups: 7 Memory: 31.07 GiB
used: 9.06 GiB (29.1%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1235 lib: 292 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-06-01
Last full system update: 2022-06-02
I cannot answer your question in bold above in your OP.
However,
I also have that notification when I connect to my VPN, but it does not affect in any way internet speed nor any other features the VPN is not supposed to block or hinder.
My question to you is "Have you benchmarked and identified that you have speed issues or is speed and any other features considered normal?"
Hello @FGD , thanks for your reply.
I have done multiple speed tests through my ISP and speedtest.net from a number of different available hosted locations. I also have transfered multiple large files (8GB+) to the VPN site and consistently see the advertised speed.
I don't believe it is related to speed as I've seen reports of similar issues elsewhere related to not being able to access a site that's hosting a 'check_network_status.txt' like this post here:
following the suggested course of action does not appear to resolve the issue even though I am able to access the indicated URL without error in a web browser of my choice
The solution of that Manjaro thread is pretty interesting to say the least. :smiley:
  • Are you also experiencing that yellow overlay icon on the bottom right of NetworkManager's systray icon?
  • Then when you click on the NM systray icon, what do you see inside?
    In my case I see my wired connection as CONNECTED and I also see my VPN Provider as being CONNECTED to.
    That Manjaro guy was not seeing the VPN connection. How about you?
  • Also, what exactly does your "limited connection" notification say?
    This?
Limited Connectivity                                           4:47PM
This device appears to be connected to a network but is unable to reach the internet.
Personally, I have always thought this was normal behavior when connecting to VPN as nothing is affected by it.
Now if there is such a file or something pinged by Garuda, like for Manjaro, there are a few people with much better network knowledge here that might know.
It seems to make sense that NetworkManager simply refers to a website for checking internet connectivity. I will have to read more about the configuration options.
I actually don't see any specific coloring of the icons that appear to indicate a problem, but I'm running the KDE Dr460nized edition which has a great number of customization to the theme.
I actually do see both connections with status connected as I'm using the NetworkManager plugin for openconnect.
Mine reports:
Wired Ethernet: Connected to Wired connection 1 (limited connectivity)
VPN: Connected to vpn (limited connectivity)
this was also somewhat of interest:
> nmcli general
STATE                  CONNECTIVITY  WIFI-HW  WIFI      WWAN-HW  WWAN
connected (site only)  limited       enabled  disabled  missing  enabled
The connectivity check file is located at /usr/lib/NetworkManager/conf.d/20-connectivity.conf, with the following contents:
[connectivity]
uri=http://ping.archlinux.org/nm-check.txt
Fabulous! Thanks @tbg
Just in case anyone happens to stumble across this, I did "solve" my problem by creating the following:
File: /etc/NetworkManager/conf.d/20-connectivity.conf
[connectivity-vpn0]
enabled=false
vpn0 was the name of my vpn interface that didn't support connectivity checking
I have not experienced the same notification since
