Hi, a lot of apps open up on my second monitor instead of on my main one even though it is set up properly (as the main monitor)
Is there anything I should further do to prevent this from happening?
Thanks!
Thanks!
It seems to develop a memory of where you most commonly use an application(or where you last used it)
For example, KDE always opens Spotify on my second monitor.
It does not look like there is way to configure to open applications on the main monitor. It's just a little idiosyncrasy you have to get used to
