Issue Trying to find an application to map mouse buttons
Mouse: Inland GM98 Wired/ Wireless Optical Gaming Mouse – International Products Sourcing Group
Troubleshooting: Suggested to use piper. Mouse not support by piper. The buttons due work. Tested by opening gedit and pressing each of the buttons. Produced numbers as output. Not finding any useful information via websearch.
Kernel: 6.1.5-273-tkg-pds arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: intel_pstate=passive split_lock_detect=off
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=f8b64331-9f73-4b5e-8666-683f1b7a55e6 rw [email protected]
nvidia_drm.modeset=1
cryptdevice=UUID=2e774d55-b39d-4dc3-ab93-dd9d934dd845:luks-2e774d55-b39d-4dc3-ab93-dd9d934dd845
root=/dev/mapper/luks-2e774d55-b39d-4dc3-ab93-dd9d934dd845 quiet splash
nosgx rd.udev.log_priority=3 vt.global_cursor_default=0
resume=/dev/mapper/luks-452ae4ef-dbd7-40fd-8185-ce7166dceb2c loglevel=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_wayland vt: 2 dm:
1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Garuda Linux
Type: Laptop System: Micro-Star product: GP63 Leopard 8RD v: REV:1.0
Mobo: Micro-Star model: MS-16P6 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16P6IMS.109 date: 05/22/2019
ID-1: BAT1 charge: 38.7 Wh (93.0%) condition: 41.6/53.4 Wh (77.8%)
volts: 11.8 min: 10.9 model: MSI Corp. MS-16P6 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3765 high: 4100 min/max: 800/4100 scaling:
driver: intel_cpufreq governor: performance cores: 1: 4100 2: 4001 3: 4000
4: 3580 5: 4100 6: 800 7: 4100 8: 4100 9: 4100 10: 4100 11: 4100 12: 4100
bogomips: 52858
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 525.78.01
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:7
chip-ID: 5986:211b class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_wayland driver: X: loaded: intel,nvidia dri: i965
Monitor-1: HDMI-A-2 res: 1360x768 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-1.4:9 chip-ID: 0d8c:0012
class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: C-Media USB Audio Device type: USB
Sound API: ALSA v: k6.1.5-273-tkg-pds running: yes
IF: wlan0 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
bt-service: disabled rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 1.84 TiB used: 828.47 GiB (43.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: SATA SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 61.3 temp: 33 C scheme: MBR
ID-1: / raw-size: 914.2 GiB size: 914.2 GiB (100.00%) used: 399 GiB (43.6%)
mapped: luks-2e774d55-b39d-4dc3-ab93-dd9d934dd845
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.2 GiB size: 914.2 GiB (100.00%)
used: 399 GiB (43.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 914.2 GiB size: 914.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.2 GiB size: 914.2 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.01 GiB used: 0 KiB (0.0%)
mapped: luks-452ae4ef-dbd7-40fd-8185-ce7166dceb2c
System Temperatures: cpu: 56.0 C pch: 62.0 C mobo: N/A
Processes: 363 Uptime: 1h 41m wakeups: 11 Memory: 15.47 GiB
used: 5.11 GiB (33.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages:
pm: pacman pkgs: 2464 libs: 572
tools: cylon,gnome-software,pamac,paru,trizen,yay pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-12-17
Last full system update: 2023-01-14 ↻
