Anyone using a OLED monitor? How do you protect against burn in?
Posting this in the community instead of issues & assistance because its more of a question for discussion rather than an issue.
Since Garuda is more gaming focused I was wondering if anyone here was using an OLED monitor as their main display? I recently got the Alienware 32 inch 4k OLED and love the picture quality. My only fear with OLED is the burn in potential, which if you look online you will see people arguing over how big of a deal it is on modern monitors but I digress.
If you are running an OLED monitor do you use anything to try to minimize burn in? On Windows I was using Wallpaper engine to use dynamic wallpapers, but unfortunately it is not available on Linux. I also have my screen set to turn off after a minute of inactivity to make sure I don’t leave anything static on my screen for too long. Other than that I just use my monitor as normal and let it do its refresh every 4 hours or so depending on if I’m in the middle of something.
So any fellow OLED gamers using Garuda? How has your experience been with it?
@triple07
This script, if you use X11 window manager instead of Wayland, can prevent monitor burn, and also show off your photos. That is how i do it. i wrote a script to manage my photos.
i monitor my input, if idle, my script will begin to show random photos, out of my Picture directory, and will put the computer, or monitor, to sleep after a predetermined idle time is detected.
(i made an installer out of my script, for Debian at the time, but i quickly modified it for Garuda. If you are using X11 this should work fine. Giving you a screensaver that responds to your mouse being idle, ( but will not start screensaver if sound is going so you can watch videos without the screensaver coming on.) Simply copy the code on an empty screensaver.sh file, and install the dependencies listed at the beginning of the script, and give the new file permission, modify the default settings if need be at the begiining of the Script, and run it. (i like using Geany to do so.)
(If you install it and then autostart it, you can protect your monitor from burn in, and see your favourite photos coming past in style when your computer is idle.)
Cheers.
#!/usr/bin/bash
#run this script to install it in the DefaultDirPath directory.
#After installing run screensaver2.sh in the DefaultDirPath directory. (line 15)
#This slideshow aims at filling the screen keeping the images in ratio, and blurring the black background with the same image.
# When an image is displayed it is removed from the photo list. When the photo list runs out a new one will be automatically generated.
# sound (line 18) and or shuffling (line 19) can be switched on or off. If you want to modify the Default instalation directory please use line 16 to do so, Picture Directory the same on line 15.
#you can autostart this script once installed if you change the values to your liking beforehand on the screensaver2 in the installation directory,or now before you install the screensaver.
#default values
re='^[0-9]+$' #check if input is a number
idlewaittime=18 #time in seconds to wait before starting to display the images
DefaultPicDir=$HOME"/Pictures/" #default image directory
DefaultDirPath=$HOME"/Scripts/screensaverfiles" #default running files directory
BlurredImagesDir=$DefaultDirPath"/tempphotodir/" #temp directory for background images
speak="on" #determine if the speech engine is switched on.
shuffle="on"
blur="28x28" #value to blur background image
sleeper=7 #time in the value of 'period' before next image is shown
blankscreen=3600 #3600 seconds is 1 hour before blanking screen.
wait=.14 #value to pause between loading the images. (try a greater value if your computer has trouble loading the images at this speed.)
period=1.4 #times the value of 'sleeper' awaiting next photo. (line 21)
passed=0
righton=0
blank=0
desktop="KDE"
#dependecies.  These are the essential apps needed to run this photoslide screensaver. if not installed yet please do so now by changing the value of to pass=1
pass=0
if [ $pass = 1 ];then
#install with pacman
sudo pacman -Syu geany xprintidle xdotool wmctrl feh arandr imagemagick feh zenity
#install these files with bauh; pico2wave-shell, pixelcolor, ddccontrol
sudo bauh
fi
#distro info
DistroBasedOn='Arch Linux';PSUEDONAME="Garuda";echo "Installing a screensaver on ""$DistroBasedOn"" ""$PSUEDONAME";
#text to speech function
speaking() {
	echo 'Entering speaking';
	eval 'pico2wave -l en-GB -w $HOME"/speaking.wav" "${speech}" &';sleep .28;
	eval 'play -q  $HOME"/speaking.wav" &';speech="";sleep .777;
	if [ -s $HOME"/speaking.wav" ];then rm $HOME"/speaking.wav";
	fi;
};echo 'You can turn speech off. By modifying the value speak=on to speak=off on line 18';speech='You can turn speech off. By modifying the value speak on line 18';speaking;sleep 5;
#checking running directories. Creating them if they don't exist and copying screensaver.sh in it as screensaver2.sh
if ! [ -s $DefaultDirPath"/tempphotodir" ];then
speech='Do you want to install the screensaver';
if [ $speak = "on" ];then speaking;fi;
answer=`zenity --forms --width=700 --title="Installing The Screensaver" --text="The default directories will be made" --separator="," --text="                    The default directory is:"$DefaultDirPath"    " --separator="," --add-entry="Please Answer (y)es or (n)o" `;
if [ $answer = 'n' ] || [ $answer = 'N' ] || [ ${#answer} -lt 1 ];then
speech='canceling the installation. Please modify your Default Directory Path on line 16';
if [ $speak = "on" ];then speaking;fi;sleep 4;exit;
elif [ $answer = 'y' ] || [ $answer = 'Y' ];then speech='Adding the new installation directories!';
if [ $speak = "on" ];then speaking;fi;sleep 2;fi;
if ! [ -s $HOME"/Scripts" ];then mkdir $HOME"/Scripts";fi;
if ! [ -s $HOME"/Scripts/screensaverfiles" ];then mkdir $HOME"/Scripts/screensaverfiles";fi;
mkdir $HOME"/Scripts/screensaverfiles/tempphotodir";cp "./screensaver.sh" $DefaultDirPath"/screensaver2.sh";chmod a+x $DefaultDirPath"/screensaver2.sh";
fi;
#loading image files into an array - creating photo list from the DefaultPicDir
loadfiles() {
	echo 'Entering loadfiles'
	echo 'Please be patient';
	echo 'Making a photo list of your photos';
	echo 'this process could take some time!';
	echo 'Depending on the size of your photo collection!';
	speech='Preparing your photo list. This may take some time depending on the size of your photo collection.';
	sleep 3;unset array;
	if [ -s $DefaultDirPath"/orderedphotos.txt" ];then rm $DefaultDirPath"/orderedphotos.txt";rm $DefaultDirPath"/oldphotos.txt";rm $DefaultDirPath"/photolist.txt";
	fi;
	printf "%s\n" "$blank" > $DefaultDirPath"/oldphotos.txt";check=`find "$DefaultPicDir" -type f -exec echo {} \;`;xxxx=0;
	while IFS='F' read -ra ADDR;do
	for photoname in "${ADDR[@]}";do photo=${photoname: -4};
	if [ "${photo^^}" = ".JPG" ] || [ "${photo^^}" = '.PNG' ];then
	xxxx=$(( xxxx + 1 ));array[${#array[*]}]="$photoname";echo $xxxx")"$photoname;
	fi;
	done;done <<< "$check";
	if [ ${#check} -lt 1 ];then
	speech='there are no images in this directory. Please choose picture default directory with images';
	rm -rf $DefaultDirPath;sleep 7;exit;
	else speech='there are '$xxxx' images in your photo list.';
	sleep 4;printf "%s\n" "${array[@]}" > $DefaultDirPath"/orderedphotos.txt";printf "%s\n" "${array[@]}" > $DefaultDirPath"/photolist.txt";fi;
	setupfiles=0;xxxx=0;
if ! [ -s $DefaultDirPath"/photolist.txt" ];then
speech="Are your photos in this directory?";
answer=`zenity --forms --width=700 --title=" Making a photo list of your pictures." --text="Your images are in this directory?  "$DefaultPicDir --separator="," --add-entry="Please Answer (y)es or (n)o" `;
speech='canceling any further installation. Please modify Your Picture Default Directory on line 15';
speech='Making New Photolist.';
speaking;
fi;
sleep 2;fi;
loadfiles;
fi
if ! [ $PWD = $DefaultDirPath ] && [ -s $DefaultDirPath"/tempphotodir" ];then
speech='Please run the Screensaver 2 file directly from your default directory';
echo "";echo "Please run the Screensaver2.sh file directly in the "$DefaultDirPath" folder";sleep 2;
else righton=1;
fi
#loading photolist.
readarray -t array < $DefaultDirPath"/photolist.txt";
#Randomly shuffling the photolist
shuffle() {
	echo 'Entering shuffle';
	speech='I will shuffle your photo entries into a random order. You can turn shuffle off. Just modify the default shuffle value on line 19.';
	local i tmp RANGE rand rand2;RANGE=$(( ${#array[*]} - 1 ));
	if [ $RANGE = -1 ];then
	readarray -t array < $DefaultDirPath"/photolist.txt";RANGE=$(( ${#array[*]} - 1 ));
	fi;
	echo 'shuffling '$RANGE' images';
	if [ $RANGE -lt  3 ];then
	loadfiles;readarray -t array < $DefaultDirPath"/photolist.txt";RANGE=$(( ${#array[*]} - 1 ));
	fi;
	size=$(( RANGE + 1 ));i2=0;
	for ((i=size-1; i>0; i--)); do
	while :;do no=$((no+1));rand=$((0 + RANDOM % $RANGE));rand2=$((0 + RANDOM % $RANGE));
	if ! [ $rand = $rand2 ];then break;
	else echo 'Bypassed identical shuffle move';i2=$(( i2 + 1 ));sleep 2;
	fi;
	done;
	tmp=${array[i]};
	array[i]=${array[rand]};
	array[rand]=$tmp;tmp=${array[i2]};
	array[i2]=${array[rand2]};
	array[rand2]=$tmp;i2=$(( i2 + 1 ));
	echo $no") ""shuffling entry "$i" to entry "$rand;
	echo $no") ""shuffling entry "$i2" to entry "$rand2;
	done;
	echo $((RANGE+1))" Photos in the file list ("$DefaultDirPath"/photolist.txt).";
#get the idenity number of mouse and keyboard
inputdevices() {
	echo 'Entering inputdevices'
	KeyboardId=`xinput --list --long | grep XIKeyClass | head -n 1 | egrep -o '[0-9]+'`;
	MouseId=`xinput --list --long | grep XIButtonClass | head -n 1 | egrep -o '[0-9]+'`;
	echo $KeyboardId"=Keyboard Id < inputdevices2 > Mouse Id="$MouseId;
};inputdevices
#Getting screen width and screen height.
ScreenWidth=$(xrandr --current | grep '*' | uniq | awk '{print $1}' | cut -d 'x' -f1);
echo "Screen Width="$ScreenWidth
ScreenHeight=$(xrandr --current | grep '*' | uniq | awk '{print $1}' | cut -d 'x' -f2);
len=${#ScreenHeight};if [ ${ScreenHeight:$((len-1)):1} = "i" ];then
ScreenHeight=${ScreenHeight:0:$((len-1))};
fi;
echo "Screen Height="$ScreenHeight;
echo "Linux Version="$version;echo "Distro Name="$PSUEDONAME;echo 'Desktop='$desktop;
if [ $righton = 0 ];then
answer=`zenity --forms --width=700 --title="  Do you want to run the screensaver from here?" --text="Do you want to run the screensaver?" --separator="," --add-entry="Please Answer (y)es or (n)o" `;
speech='Canceling! Load your screensaver from the default Directory';if [ $speak = "on" ];then
speaking;
fi;
sleep 5;
exit;
elif [ $answer = 'y' ] || [ $answer = 'Y' ];then speech='Loading screensaver';if [ $speak = "on" ];then speaking;fi;
sleep 3;
cd $DefaultDirPath;
eval '$DefaultDirPath"/screensaver2.sh" &';sleep 28;
exit;
fi;fi
startscreensaver=`date +%s`;speech="The Screensaver is up and running!";if [ $speak = "on" ];then speaking;fi;sleep 4
#panel up on KDE Desktop
KDEpanelup() {
	echo 'Entering KDEpanelup'
	qdbus org.kde.plasmashell /PlasmaShell org.kde.PlasmaShell.evaluateScript "panels()[0].hiding = \"null\"";
	qdbus org.kde.plasmashell /PlasmaShell evaluateScript "p = panelById(panelIds[0]); p.maximumLength = '$ScreenWidth'";
	qdbus org.kde.plasmashell /PlasmaShell evaluateScript "p = panelById(panelIds[0]); p.minimumLength = '$ScreenWidth'";
#panel down on KDE
KDEpaneldown() {
	echo 'Entering KDEpaneldown'
	qdbus org.kde.plasmashell /PlasmaShell org.kde.PlasmaShell.evaluateScript "panels()[0].hiding = \"$value\"";
	qdbus org.kde.plasmashell /PlasmaShell evaluateScript "p = panelById(panelIds[0]); p.maximumLength = '7'";
	qdbus org.kde.plasmashell /PlasmaShell evaluateScript "p = panelById(panelIds[0]); p.minimumLength = '7'";
	qdbus org.kde.plasmashell /PlasmaShell evaluateScript "p = panelById(panelIds[0]); p.alignment = \"left\"";
};value="dodgewindows";#autohide;windowsgobelow;windowscover;dodgewindows;null;
#screensaver main control function
screensaver() { checksound=`pw-dump`;
	if [[ "$checksound" = *"running"* ]] ;then eval $(xdotool getmouselocation --shell);xx=$X;yy=$Y;xdotool mousemove 0 0;xdotool mousemove $xx $yy;return;fi;
	sleeperbak=$sleeper;
	echo "entering screensaver";
	mxx=$X;myy=$Y;readarray -t oldphotos < $DefaultDirPath"/oldphotos.txt";
	pidbak1=0;pidbak2=0;pass=1;
	if [ $desktop = "KDE" ];then KDEpaneldown;elif [ $desktop = "Unity" ];then UbuntuHidePanel;elif [ $desktop = "LXQt" ];then LubuntuHidePanel;fi;
	while : ; do
	screensaver1;
	for R in `seq 1  $sleeper`;do
	if [ $X -lt $(( mxx - 21 )) ] || [ $X -gt $(( mxx + 7 )) ] || [ $Y -lt $(( myy - 7 )) ] || [ $Y -gt $(( myy + 7 )) ];then
	break 2;
	fi;
	sleep $period;KDEpaneldown;
	done;done;
	while : ; do winpid3=`xdotool search --class "one"`;winpid4=`xdotool search --class "two"`;
	if ! [ ${winpid3:-null} = null ];then xdotool windowclose $winpid3;
	elif ! [ ${winpid4:-null} = null ];then xdotool windowclose $winpid4;
	elif [ ${winpid4:-null} = null ] && [ ${winpid3:-null} = null ];then
	break;
	fi;
	sleep .035;
	done;statetime=`date +%s`;
	printf "%s\n" "${oldphotos[@]}" > $DirPath"oldphotos.txt";
	printf "%s\n" "${array[@]}" > $DirPath"ourphotos.txt";
	unset oldphotos;unset array;sleeper=$sleeperbak;period=1.600;pass=0;begintime=`date +%s`;
	KDEpanelup;
#manipulate photos
screensaver1() {
	echo 'Entering screensaver1'
	loadphoto;
	resized=$ScreenWidth"x"$ScreenHeight"!";
	if [ $width -gt $height ] && [ $rotate = 1 ];then
	width3=$width;height3=$height;width=$height3;height=$width3;
	fi;answer=`printf "%.*f\n" '1' $(python -c "print($width / $height)")`;
	if [ $width = $ScreenWidth ] && [ $height = $ScreenHeight ];then
	first='0) fit '$ScreenWidth"x"$ScreenHeight;width2=$ScreenWidth;height2=$ScreenHeight;
	elif [ $answer = 2.2 ] || [ $answer = 2.1 ] || [ $answer = 2.0 ] || [ $answer = 2.3 ] || [ $answer = 2.4 ];then
	height2=$height;width2=$width;
	else
	if [ $height -lt $ScreenHeight ] && [ $rotate = 0 ];then
	first='1) -lt ScreenHeight '$ScreenHeight;token=`printf "%.*f\n" '4' $(python -c "print($ScreenHeight / $height".00")")`;height2=`printf "%.*f\n" '0' $(python -c "print($height * $token)")`; width2=`printf "%.*f\n" '0' $(python -c "print($width * $token)")`;
	elif [ $height -gt $ScreenHeight ] && [ $rotate = 0 ];then
	first='2) -gt ScreenHeight '$ScreenHeight;token=`printf "%.*f\n" '4' $(python -c "print($height".00" / $ScreenHeight)")`;height2=`printf "%.*f\n" '0' $(python -c "print($height / $token)")`; width2=`printf "%.*f\n" '0' $(python -c "print($width / $token)")`;
	elif [ $height -gt $ScreenHeight ] && [ $rotate = 1 ];then
	first='3) -gt '$ScreenHeight' & rotate=1';token=`printf "%.*f\n" '4' $(python -c "print($height".00" / $ScreenHeight)")`;height2=`printf "%.*f\n" '0' $(python -c "print($height / $token)")`; width2=`printf "%.*f\n" '0' $(python -c "print($width / $token)")`;
	elif [ $rotate = 1 ] && [ $height -lt $ScreenHeight ];then
	first='4) -lt ScreenHeight '$ScreenHeight' & rotate=1';token=`printf "%.*f\n" '4' $(python -c "print($ScreenHeight".00" / $height)")`;height2=`printf "%.*f\n" '0' $(python -c "print($height * $token)")`;width2=`printf "%.*f\n" '0' $(python -c "print($width * $token)")`;
	fi;fi;
	photoname3=$(basename "$photoname");
	if [ -s $BlurredImagesDir$photoname3"7" ];then
	notify-send -t 3333 'found blurred image';sleep .1;
	else
	if [ $height -gt $width ];then
	magick convert -resize $ScreenHeight -colors 49 $photoname $BlurredImagesDir$photoname3"7";mogrify -blur $blur $BlurredImagesDir$photoname3"7";
	else magick convert -resize $resized -colors 49 $photoname $BlurredImagesDir$photoname3"7";mogrify -blur $blur $BlurredImagesDir$photoname3"7";
	fi;
	fi;
	photoname2=$BlurredImagesDir$photoname3"7";width3=$((ScreenWidth-width2));width4=$((width3/2));
	if [ ${#pid2a} -gt 1 ];then
	if [ ${#pid2} -gt 0 ];then kill -9 $pid2;
	fi;
	pid2a=0;
	fi;
	if [ $width -lt $ScreenWidth ] && [ $height -lt $ScreenHeight ] && [ $rotate = 0 ];then
	 eval 'feh -x  --hide-pointer --class "one" --geometry $ScreenWidth"x"$ScreenHeight+0+0  $photoname2 & pid1=$!';sleep $wait;
	 eval 'feh -x --class "two" --hide-pointer --zoom fill --geometry $width2"x"$ScreenHeight+$width4+0 -B black $photoname & pid2=$!';
	 elif [ $rotate = 0 ] && [ $height -gt $ScreenHeight ];then
	 eval 'feh -x --class "one"  --hide-pointer --geometry $ScreenWidth"x"$ScreenHeight+0+0 $photoname2 & pid1=$!';sleep $wait;
	 eval 'feh -x  -. --class "two"  --hide-pointer --geometry $width2"x"$ScreenHeight+$width4+0 -B Black $photoname & pid2=$!';
	 eval 'feh -x --zoom fill  --hide-pointer --class "one" --geometry $ScreenWidth"x"$ScreenHeight+0+0 $photoname2 & pid1=$!';sleep $wait;eval 'feh -x -. --hide-pointer --geometry $width2"x"$ScreenHeight+$width4+0 --class "two"  -B black $photoname & pid2=$!';
	 elif [ $height -lt $ScreenHeight ] && [ $rotate = 1 ];then
	 eval 'feh -x --zoom fill --hide-pointer --class "one"  --geometry $ScreenWidth"x"$ScreenHeight+0+0   $photoname2 & pid1=$!';sleep $wait;fi;start=`date +%s`;sleep .777;windowname=$(xdotool getactivewindow getwindowname);if ! [[ "$windowname" = *"${photoname}"* ]];then
	 eval 'feh -x --class "two" --zoom fill  --hide-pointer  --geometry $width2"x"$ScreenHeight+$width4+0  -B black $photoname & pid2a=$!';
	 sleep $wait;
	 pixelcolour8=`pixelcolor --x 910 --y 2142 --hex`;
	 if [ $pixelcolour7 = $pixelcolour8 ];then
	 notify-send 'same colour';
	 if [ $value = "autohide" ];then
	 elif [ $value = "dodgewindows" ];then
	 value="windowscover";
	 elif [ $value = "windowscover" ];then
	 value="autohide";fi;
	 sleep .28;
	 KDEpaneldown;
	 sleep 1.4;
	 pixelcolour7=`pixelcolor --x 910 --y 2142 --hex`;
	 fi;
	 if [ ${#pid2} -gt 0 ];then kill -9 $pid2;fi;
	 else pid2a=0;winpid1=`xdotool search --pid $pid1`;
	 sleep $wait;
	 winpid2=`xdotool search --pid $pid2`;
	 sleep $wait;
	 xdotool windowfocus $winpid1;
	 sleep $wait;
	 xdotool windowfocus $winpid2;
	 fi;
	 id1=$(xdotool search --pid $pid1);
	 if ! [ $pid1 = $pidbak1 ] && [ $pass = 0 ];then
	 echo -e $RG'kill pid1!''\e[0m''\e[49m';kill -9 $pidbak1;
	 fi;
	 if ! [ $pid2 = $pidbak2 ] && [ $pass = 0 ];then
	 echo -e $RG'kill pid2!''\e[0m''\e[49m';kill -9 $pidbak2;
	 fi;
	 pass=0;
	 pidbak2=$pid2a;
	 else pidbak2=$pid2;
	 fi;pidbak1=$pid1;
	 	 screensaver=0;idle2=`xprintidle`;xdotool windowactivate $winpid2;
#Loading the image
loadphoto() { echo 'entering loadphoto';
	oldphotoNo="${#oldphotos[@]}";
	arrayNo="${#array[@]}";
	if [ $arrayNo -lt 1 ];then
	unset array;photofiles=1;loadfiles;readarray -t array < $DefaultDirPath"/photolist.txt";printf "%s\n"$blank" " > $DefaultDirPath"/oldphotos.txt";readarray -t oldphotos < $DefaultDirPath"/oldphotos.txt";
	else
	photofiles=0;
	fi;
	arrayNo="${#array[@]}";oldphotoNo="${#oldphotos[@]}";RANGE="${#array[@]}";
	while :;do
	number=$RANDOM;let "number %= $RANGE";photoname=${array[$number]};
	if [ ! -f "$photoname" ];then unset array[$number];fault=1;
	else
	if [[ !  -z  "$photoname"  ]];then
	oldphotos[${#oldphotos[*]}]="$photoname";unset array[$number];
	break;
	else
	fi;fi;
	sleep .1;done;
	array=("${array[@]}");oldphotos=("${oldphotos[@]}");loadfile2=0;getresolution;loadfile2=1;sleep .21
# getting the image resolution and if it is a landscape or portray.
getresolution() {
	echo 'Entering getresolution'
	rotate=0;
	SizePhoto1=0;
	answer=`identify "$photoname"`;
	x=0;x1=0;x2=0;
	while IFS=' ' read -ra ADDR;do
	for ii in "${ADDR[@]}";
	do x=$(( x + 1 ));
	if [ $x = 3 ];then photosize=$ii;
	if [ ${#photosize} = 9 ];then width=`echo -n $ii | head -c 4`;height=`echo -n $ii | tail -c 4`;
	elif [ ${#photosize} = 8 ];then
	if [[ $height =~ $re ]];then
	width=`echo -n $ii | head -c 3`;
	else
	width=`echo -n $ii | head -c 4`;height=`echo -n $ii | tail -c 3`;
	fi;
	elif [ ${#photosize} = 7 ];then
	width=`echo -n $ii | head -c 3`;height=`echo -n $ii | tail -c 3`;
	fi;
	break 2;fi;
	done;
	done <<< "$answer";
	if [ $loadfile2 = 0 ];then
	answer=`exiftool "$photoname"`;fi;
	if [ $height -gt $width ];then rotate=1;fi;
	if [[ "$answer" = *"Rotate 270 CW"* ]] && ! [ $height -gt $width ] || [[ "$answer" = *"Rotate 90 CW"* ]] && ! [ $height -gt $width ] || [[ $answer = *"Portray"* ]] && ! [ $height -gt $width ];then
	rotate=1;convert -resize $heightx$width -auto-orient "$photoname" "$photoname";fi;
#loading photolist.
#priming final screensaver values
if [ $shuffle = "on" ];then shuffle;fi #randomly shuffling your images
endscreensaver=`date +%s`;#setting idle time
eval $(xdotool getmouselocation --shell);#getting x, y value of the mouse cursor
xxx=$X
yyy=$Y
#running loop
while :;do
sleep 1
if [ $xxx = $X ] && [ $yyy = $Y ];then
endscreensaver=`date +%s`;echo $((endscreensaver-startscreensaver))" out of "$idlewaittime;
if [ $((endscreensaver-startscreensaver)) -gt $idlewaittime ];then
screensaver;
fi;
else xxx=$X;yyy=$Y;startscreensaver=`date +%s`;
fi
done
Nice! Thank you! I am currently using Wayland but I may switch back to X11 and use this script. Seems like a good way to keep from having any burn in and to just make it look nicer. I appreciate it.
i hope it will work okay. i quickly modified it for Arch , it was originally written for Debian, X11 window manger will work tho.
If you have any troubles let me know.
One thing i forgot to tell you is that i did not know what version of Garuda you use, and if you do use KDE, where your main panel is located. The panel in KDE has real issue popping up, unasked for. i fixed it for myself with an pixel command checking if the panel is visible, making sure i get the values, before i autohide it. So that when it pops up unexpectedly, and mars the photos on display, the script can correct it. So please let me know where you panel is, and what size it is, and i will reenter the command, to keep an eye on the panel. (i kept part of the code out, for i did not where to monitor for your panel. As the script is now, ever 1.4 seconds your panel is minimised, even if it is already minimised, to make sure it is minimised, if you understand what i mean.
Cheers.
