It’s not major issues but I’ve noticed since going to kde 6.2 that if I connect to my soundbar via bluetooth and the pc goes to sleep I’m unable to connect again until I turn the soundbar off/on…this was not an issue before KDE 6.2. I tried deleting the soundbar and re-adding it and was unable to get the pc and soundbar to pair…I ended up reverting to an hourly snapshot so it was again paired. None of this is a show stopper but I recall reading about bluetooth changes in KDE 6.2 and wondered what the issue might be?
update1 It’s not just when coming out of sleep. If I disconnect from bluetooth and try to reconnect it fails or sometimes THINKS it’s connected but it isn’t.
Not sure it’s needed but I’ve attached my garuda-inxi.
Kernel: 6.11.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5ad7fecd-1a14-4590-8ce1-42685c5ee6c8 rw rootflags=subvol=@
quiet rd.luks.uuid=2bdec0d6-999c-4a5a-9278-70a5c8e236d9 loglevel=3
Desktop: KDE Plasma v: 6.2.0 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: AM08Pro_P5C5V19
date: 09/20/2023
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 15%
rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Speed (MHz): avg: 1356 min/max: 400/4829 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1356 2: 1356 3: 1356
4: 1356 5: 1356 6: 1356 7: 1356 8: 1356 9: 1356 10: 1356 11: 1356 12: 1356
13: 1356 14: 1356 15: 1356 16: 1356 bogomips: 102211
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-2,
Writeback-1 bus-ID: e5:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 52.0 C
Device-2: Sunplus Innovation Full HD webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.1.4.2:13
chip-ID: 1bcf:2284 class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-1 res: 2752x1152 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.59 6.11.3-zen1-1-zen) device-ID: 1002:1681
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: mesa radv v: 24.2.4-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.4-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: e5:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e5:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
bus-ID: e5:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sunplus Innovation Full HD webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.11.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0bda:b85b
Local Storage: total: 2.33 TiB used: 35.11 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU020TZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 003C temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: MZALQ512HALU-000L2
size: 476.94 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: N/A
serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 35.11 GiB (1.8%)
mapped: luks-2bdec0d6-999c-4a5a-9278-70a5c8e236d9
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 35.11 GiB (1.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 27.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.5 C mobo: 52.5 C gpu: amdgpu temp: 54.0 C
Memory: total: 28 GiB available: 27.15 GiB used: 8.04 GiB (29.6%)
Processes: 394 Power: uptime: 12h 18m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 10.85 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1533 libs: 396 tools: octopi,paru pm: appimage
pkgs: 0 Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: yakuake inxi: 3.3.36
System install date: 2024-09-26
Last full system update: 2024-10-11 ↻
Failed units: configure-printer@usb-003-015.service
