I just got a new ROG Strix Go 2.4, it works great-- no issues. Just wondering if there's and way to see the battery status or control it via linux
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=194c833d-fc87-470e-bc3a-0a59d4bd7aa4 rw rootflags=subvol=@
resume=UUID=6128a838-a54f-40e2-80cb-b69e79085972 loglevel=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C35 v: 2.0
Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.73
date: 09/29/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: Discharging
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2478 high: 4351 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2250 2: 2166
3: 3336 4: 2068 5: 2199 6: 2200 7: 2057 8: 2056 9: 3597 10: 2199 11: 2199
12: 2198 13: 2085 14: 2084 15: 4351 16: 2199 17: 2134 18: 3599 19: 2198
20: 2119 21: 3602 22: 2201 23: 2200 24: 2195 bogomips: 182404
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Microdia Lumina Camera - Raw type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2:3 chip-ID: 0c45:0415
Device-3: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5:7 chip-ID: 046d:085c
Device-4: Microdia Dual Mode Camera (8006 VGA) type: USB
driver: hid-generic,usbhid bus-ID: 5-2.4:6 chip-ID: 0c45:8006
class-ID: 0301
Device-5: Sunplus Innovation CA FLINT type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 6-3:3 chip-ID: 1bcf:2c99
class-ID: 0102
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 90
size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0
5.15.12-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.3 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487
Device-3: Microdia Lumina Camera - Raw type: USB
Device-4: ASUSTek ROG STRIX Go 2.4 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:9 chip-ID: 0b05:18d6
Device-5: Logitech C922 Pro Stream Webcam type: USB
Device-6: Sunplus Innovation CA FLINT type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
v: kernel port: f000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-4:5 chip-ID: 8087:0029 class-ID: e001
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 1-6:8 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci1 rfk-id: 2 state: up address: N/A
Hardware-1: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 2b:00.0 chip-ID: 1022:7916 rev: N/A class-ID: 0104
Hardware-2: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 2c:00.0 chip-ID: 1022:7916 rev: N/A class-ID: 0104
Local Storage: total: 1.45 TiB used: 293.39 GiB (19.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR021
temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
type: SSD serial: <filter> rev: 0KB3 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: A-Data
model: USB Flash Drive size: 28.91 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1.00 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: A-Data
model: USB Flash Drive size: 14.74 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 0.00 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 type: USB vendor: Transcend
model: JetFlash Transcend 64GB size: 58.84 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 206.11 GiB size: 429.68 GiB (208.47%)
used: 293.39 GiB (68.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 206.11 GiB size: 429.68 GiB (208.47%)
ID-4: /var/log raw-size: 206.11 GiB size: 429.68 GiB (208.47%)
ID-5: /var/tmp raw-size: 206.11 GiB size: 429.68 GiB (208.47%)
ID-1: swap-1 type: partition size: 17.16 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.6 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Processes: 567 Uptime: 2h 4m wakeups: 5 Memory: 15.6 GiB
used: 5.18 GiB (33.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1873 apt: 0 pacman: 1840 lib: 510
flatpak: 33 Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
