Any safe procedure in order to resize /home?
I’m getting out of space in /home. I want to resize in order to resize /home, but in a safe method. Also I want to ask for Swap partition, Is right 44GB Swap with 32GB RAM?
Thanks.
Kernel: 6.12.21-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3bc50495-a163-4556-a425-04d021d06cf2 rw rootflags=subvol=@
quiet resume=UUID=ad190a20-0362-44a1-9e8b-2a8b404739af loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Dell product: Precision 7530 v: N/A
Mobo: Dell model: 0425K7 v: A00 serial: <superuser required> part-nu: 0831
uuid: <superuser required> UEFI: Dell v: 1.40.1 date: 02/19/2025
ID-1: BAT0 charge: 91.2 Wh (100.0%) condition: 91.2/97.0 Wh (94.0%)
volts: 12.8 min: 11.4 model: SMP DELL 0WMRC7B type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Coffee Lake
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
ports: active: eDP-1 empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Dell
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 10de:1cbb class-ID: 0300
Device-3: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7 chip-ID: 0bda:5650
gpu: i915,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: C24X3F built: 2024 res:
mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: LG Display 0x0540 built: 2017 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
GT2) device-ID: 8086:3e9b memory: 15.19 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: N/A device-ID: 8086:3e9b
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: Quadro P1000
driver: N/A device-ID: 10de:1cbb surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
API: ALSA v: k6.12.21-1-lts status: kernel-api with: aoss
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 6f:00.0
IF: wlp111s0 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
Local Storage: total: 953.87 GiB used: 773.88 GiB (81.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS001TD9TNI-L2A0B size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11010C10 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 102.54 GiB size: 102.54 GiB (100.00%)
used: 91.01 GiB (88.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 37.3 MiB (1.9%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 341.8 GiB size: 341.8 GiB (100.00%)
used: 319.4 GiB (93.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 102.54 GiB size: 102.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 102.54 GiB size: 102.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 40.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 54.0 C mobo: N/A
Memory: total: 32 GiB available: 31.1 GiB used: 7.17 GiB (23.0%)
Processes: 366 Power: uptime: 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.38 GiB services: org_kde_powerdevil,
Packages: 1944 pm: pacman pkgs: 1917 libs: 551 tools: octopi,paru
pm: flatpak pkgs: 27 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date:     2024-07-31
Last full system update: 2025-04-07
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
zram0       254:0    0  31,1G  0 disk [SWAP]
nvme0n1     259:0    0 953,9G  0 disk
├─nvme0n1p1 259:1    0 102,5G  0 part /root
│                                     /var/cache
│                                     /var/log
│                                     /var/tmp
│                                     /srv
├─nvme0n1p2 259:2    0 341,8G  0 part /home
├─nvme0n1p3 259:3    0 466,8G  0 part /mnt/d0feae6b-4ec6-4d5d-aff8-bd763326fa60
├─nvme0n1p4 259:4    0  40,8G  0 part [SWAP]
└─nvme0n1p5 259:5    0     2G  0 part /boot/efi
lsblk -f
NAME        FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
zram0       swap   1     zram0 9c0a9482-eaf8-4c89-b016-175b88ac1bb9                [SWAP]
nvme0n1
├─nvme0n1p1 btrfs              3bc50495-a163-4556-a425-04d021d06cf2   10,8G    89% /root
│        /var/cache
│        /var/log
│        /var/tmp
│        /srv
├─nvme0n1p2 btrfs              00d43efc-00bf-40cf-ad9e-5da3802febcc   21,7G    93% /home
├─nvme0n1p3 btrfs              d0feae6b-4ec6-4d5d-aff8-bd763326fa60  100,9G    78% /mnt/d0feae6b-4ec6-4d5d-aff8-bd763326fa60
├─nvme0n1p4 swap   1           ad190a20-0362-44a1-9e8b-2a8b404739af                [SWAP]
└─nvme0n1p5 vfat   FAT32       6BED-4543                               1,9G     2% /boot/efi
inxi -p
ID-1: / size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 1.95 GiB used: 37.3 MiB (1.9%) fs: vfat
dev: /dev/nvme0n1p5
ID-3: /home size: 341.8 GiB used: 319.42 GiB (93.5%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /mnt/d0feae6b-4ec6-4d5d-aff8-bd763326fa60 size: 466.8 GiB
used: 363.44 GiB (77.9%) fs: btrfs dev: /dev/nvme0n1p3
ID-5: /root size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-6: /srv size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-7: /var/cache size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-8: /var/log size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-9: /var/tmp size: 102.54 GiB used: 91.01 GiB (88.8%) fs: btrfs
dev: /dev/nvme0n1p1
ID-10: swap-2 size: 40.78 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p4
This question is a also a never ending story…
my mind: If you need a swap file (example suspend to disk)
1 to 3 times as much swap space as physical storage should have.
your swap 44GB = ok
If you going out of space inside your home folder.
small option
delete your cache folder (/home/(user)/cache → reboot or relogin then.
Use Garuda Assistent to delete the caches.
No save mode..sorry
Backup home folder …boot into live iso and shrink / resize the relevant partitions. Pls be carefull if you do this.
Some questions about your home folder now.
What you insert there ? Is it gaming / multimedia / office / work ?
Best and safest option (if possible):
insert intern a new nvme / sata (sdd or hdd) or use a usb device.
intern → partition correctly with btrfs or ext4 (my mind) (partitionmanger)
usb → the same + make the entrys inside fstab or use partitionmanager to do this
Make/copy the relevant links inside home + folder to the new partition.
I prefer self no autostart if i work with usb devices. If you do this → your choice and no entrys you must doing
Thanks @gampel, I will do what you say.
