Hi All,
Much like some that have been posted already. I rebuilt my laptop (Dell XPS 9380) a few weeks ago, and have found a few issues since.
The system, when booting, will sporadically freeze - and at different points. There have been times when this has been on the grub screen (I see the countdown, and it will stop at 1s and no longer continue), others prior to even reaching grub, and some where it will lock up while attempting to load the system post grub.
The times when I have managed to get the system to load the log in screen, I had to unplug the USBC hubs from the laptop - which, as you will imagine, is highly inconvenient to have to unplug & plug in the hubs again each and every boot.
Once booted, though, the system generally runs fine. However, there are occasions where processes will, again, seemingly lock up, and have to wait for the application to refresh itself before I can do anything. I have monitored the system in a terminal at the time, and there does not appear to be heavy load when this has occurred.
Similarly, I have observed times where I have locked my laptop, and it will not unlock, as it has frozen (although the clock still updates...), meaning a full boot cycle.
I followed another thread, and have just installed & enabled the throttled package, as well as disabling/masking the thermald service.
I was running the previous iteration of Garuda (prior to chaotic-aur going down), where the system seemed to perform perfectly without these issues, and so I am not entirely sure what else has been updated to introduce the problem.
Here are the system details, which are typically requested. Any assistance would be much appreciated.
System: Kernel: 5.10.6-110-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=3de39916-9c34-4acc-866d-49bb17413863 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: XPS 13 9380 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 088MRW v: A01 serial: <filter> UEFI: Dell v: 1.11.0 date: 07/06/2020
Battery: ID-1: BAT0 charge: 47.5 Wh condition: 47.5/52.0 Wh (91%) volts: 8.5/7.6 model: SMP DELL G8VCF6C type: Li-poly
serial: <filter> status: Full
CPU: Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32026
Speed: 4453 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 4453 2: 4403 3: 4279 4: 4554 5: 4278 6: 4334 7: 4297
8: 4289
Graphics: Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 0c45:6723
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (40.0x11.2") s-diag: 1054mm (41.5")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
Monitor-2: DP1 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.2 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Device-2: Microdia USB Live camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-6.2:6 chip ID: 0c45:6536
Device-3: C-Media TONOR TC-777 Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-6.1:5
chip ID: 0d8c:0134
Device-4: FiiO K3 type: USB driver: snd-usb-audio bus ID: 1-6.4:9 chip ID: 2972:0047
Sound Server: ALSA v: k5.10.6-110-tkg-bmq
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Bigfoot Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel port: efa0 bus ID: 02:00.0
chip ID: 168c:003e
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 476.94 GiB used: 23.51 GiB (4.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC611 NVMe 512GB size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11001111 temp: 47.9 C
Partition: ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 23.51 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 23.51 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 23.51 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw size: 476.64 GiB size: 476.64 GiB (100.00%) used: 23.51 GiB (4.9%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A
Info: Processes: 281 Uptime: 9m wakeups: 28 Memory: 15.32 GiB used: 7.32 GiB (47.8%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1365 lib: 311 Shell: fish v: 3.1.2 running in: konsole inxi: 3.2.01
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2020.12.03 true PCI
local/intel-compute-runtime 20.48.18558-1
Intel(R) Graphics Compute Runtime for oneAPI Level Zero and OpenCL(TM) Driver
local/intel-gmmlib 20.4.1-1
Intel Graphics Memory Management Library
local/intel-graphics-compiler 1:1.0.5435-1
Intel Graphics Compiler for OpenCL
local/intel-media-driver 20.4.5-1
Intel Media Driver for VAAPI — Broadwell+ iGPUs
local/intel-opencl-clang 11.0.0-1
Wrapper library around clang that can compile OpenCL C kernels to SPIR-V modules
local/intel-ucode 20201118-1
Microcode update files for Intel CPUs
local/intellij-idea-community-edition 2:2021.3.1-2
IDE for Java, Groovy and other programming languages with advanced refactoring features
local/ipw2100-fw 1.3-10
Intel Centrino Drivers firmware for IPW2100
local/ipw2200-fw 3.1-8
Firmware for the Intel PRO/Wireless 2200BG
local/lib32-libva-intel-driver 2.4.1-1
VA-API implementation for Intel G45 and HD Graphics family (32-bit)
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-opencl-mesa 20.3.2-1
OpenCL support for AMD/ATI Radeon mesa drivers (32-bit)
local/lib32-vulkan-intel 20.3.2-1
Intel's Vulkan mesa driver (32-bit)
local/lib32-vulkan-radeon 20.3.2-1
Radeon's Vulkan mesa driver (32-bit)
local/libmfx 20.5.1-1
Intel Media SDK dispatcher library
local/libva-intel-driver 2.4.1-1
local/libva-utils 2.10.0-1
Intel VA-API Media Applications and Scripts for libva
local/libvdpau 1.4-1
local/mhwd-amdgpu 19.1.0-1
MHWD module-ids for amdgpu
local/mhwd-nvidia 455.45.01-2
mhwd-nvidia pci id
local/mhwd-nvidia-390xx 390.138-1
mhwd-nvidia-390xx pci id
local/neard 0.16-2
Intel's Near Field Communication manager
local/opencl-mesa 20.3.2-2
local/throttled 0.8-2
Workaround for Intel throttling issues in Linux.
local/vulkan-intel 20.3.2-2
local/vulkan-radeon 20.3.2-2
local/whois 5.5.7-1
Intelligent WHOIS client
local/xf86-video-amdgpu 19.1.0-2 (xorg-drivers)
X.org amdgpu video driver
local/xf86-video-intel 1:2.99.917+914+ga511f22c-1 (xorg-drivers)
X.org Intel i810/i830/i915/945G/G965+ video drivers
local/xf86-video-nouveau 1.0.16-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
/etc/X11/xorg.conf.d/00-keyboard.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
EndSection
ls: cannot access '/etc/modules-load.d/*.conf': No such file or directory
/etc/modprobe.d/nobeep.conf
# Prevent annoying beep from the pc speaker.
blacklist pcspkr
/etc/modprobe.d/noime.conf
# Intel VPRO remote access technology driver.
blacklist mei
blacklist mei_me
/var/log/Xorg.0.log
[ 4.870] Current Operating System: Linux liam-xps139380 5.10.6-110-tkg-bmq #1 TKG SMP PREEMPT Sun, 10 Jan 2021 18:01:03 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 4.871] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan 12 12:21:17 2021
[ 4.874] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 4.874] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 4.874] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 4.885] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 4.896] (WW) Warning, couldn't open module fbdev
[ 4.896] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 4.896] (WW) Warning, couldn't open module vesa
[ 4.896] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 4.897] (WW) Falling back to old probe method for modesetting
[ 4.925] (II) Initializing extension MIT-SCREEN-SAVER
[ 5.347] (II) XINPUT: Adding extended input device "ELAN292F:00 04F3:292F" (type: TOUCHSCREEN, id 15)
[ 74.046] (EE) event26 - SEMITEK USB-HID Gaming Keyboard: client bug: event processing lagging behind by 16ms, your system is too slow
[ 127.625] (EE) event26 - SEMITEK USB-HID Gaming Keyboard: client bug: event processing lagging behind by 18ms, your system is too slow
[ 337.164] (EE) event26 - SEMITEK USB-HID Gaming Keyboard: client bug: event processing lagging behind by 31ms, your system is too slow
