Like the topic says I am having a Display issue, but I think mine is bit more unique, if this is a duplicate please kindly post the duplicate.
I am new to Garuda Linux, and Arch Based Linux. I come from a headless Debian based background so displays is something I never deal with.
Firstly, the display was working. I have 4 displays in total. 3, 1920x1080 displays and 1, 2K display, the 2K display being the trouble. I just installed some programs the only anomaly programs I can think of installing was snap, otherwise everything else was in the AUR like chrome, or an App Image Lychee, Prusa Slicers. I had rebooted the system fine, but when it went to sleep and I woke it up my 2k display didn't turn on.
However it would load the Grub and show the Kernel launch, and even the splash screen. However as soon as the desktop load, the display turns off, If I shutdown, during the final stage of shutdown will the display turn on just to turn back off when the system stops.
When I unplug and plug in the display. The display manager sees that there is something, and says "A new output has been added" the display manager flickers, like when you make a change and applying, but the display still doesn't show up.
I tried load an old snap from before I installed of my programs, no dice. As well tried a different display manager, nothing.
I do see a fault in the journal, but not sure what to make of it and google seems to show that error being all over the place.
inxi -SGMCxxxaz
System: Kernel: 5.12.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=00d6e101-297c-4075-9867-31dbc67a087b
systemd.unified_cgroup_hierarchy=1 resume=UUID=25ce81d7-f5cd-4f36-ac84-08a46efb0d96 loglevel=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME Z270-A v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0906 date: 03/22/2017
CPU: Info: Quad Core model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 67200
Speed: 4501 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4501 2: 4512 3: 4504 4: 4500
5: 4044 6: 4492 7: 4500 8: 4500
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 4080x1920 s-dpi: 93 s-size: 1113x524mm (43.8x20.6") s-diag: 1230mm (48.4")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 94 size: 517x323mm (20.4x12.7") diag: 610mm (24")
Monitor-2: DP-1 res: 1080x1920
Monitor-3: DP-5 res: 1080x1920 hz: 75
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31 direct render: Yes
mhwd --pci -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-dkms 2020.12.19 false PCI
xrandr
Screen 0: minimum 8 x 8, current 4080 x 1920, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+1080+760 (normal left inverted right x axis y axis) 517mm x 323mm
1920x1080 75.00*+ 60.00 59.94 50.00 60.00 50.04
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1080x1920+0+0 left (normal left inverted right x axis y axis) 517mm x 323mm
1920x1080 75.00 + 60.00* 59.94 50.00 60.00 50.04
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x800 59.81
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-2 connected (normal left inverted right x axis y axis)
2560x1440 59.95 + 144.00 120.00 74.97
1920x1080 74.91 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1280x800 59.81
1152x864 59.96
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected 1080x1920+3000+0 right (normal left inverted right x axis y axis) 517mm x 323mm
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x800 59.81
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
journalctl -b -p3 --no-pager --no-hostname
-- Journal begins at Wed 2021-07-07 21:37:34 CDT, ends at Thu 2021-07-08 12:20:01 CDT. --
Jul 08 11:15:19 kernel:
Jul 08 11:15:20 systemd-tmpfiles[494]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
Jul 08 11:15:49 pipewire-media-session[2416]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut
Jul 08 11:32:11 pipewire-pulse[2417]: server 0x55e23e692290: client 0x55e23e6f4b30 [Google Chrome] error -104 (Connection reset by peer)
Jul 08 11:33:20 kernel: NVRM: GPU at PCI:0000:01:00: GPU-8dbdc467-3ff7-2ff5-b693-461742d36a0d
Jul 08 11:33:20 kernel: NVRM: GPU Board Serial Number:
Jul 08 11:33:20 kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=8173, Ch 00000050, intr 10000000. MMU Fault: ENGINE GRAPHICS GPCCLIENT_T1_2 faulted @ 0x1_0374f000. Fault is of type FAULT_PTE ACCESS_TYPE_READ
