I've faced this issue for the longest time. Scrolling is perfect under all power profiles when under a Wayland session but there is an obstinate jitter for the "Balanced" and "Power Saver" power profiles under X11 session.
```text
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d5b774b2-54ac-458b-a078-f474ae961f5d
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=aaea27cb-5d83-4c3c-ab0a-c4fc3dbf923c loglevel=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0 Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: TUF Z270 MARK 2 v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 1301 date: 03/14/2018
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: discharging
Info: model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S family: 6
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 4200 high: 4201 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 4200 2: 4200 3: 4201 4: 4200 bogomips: 27999
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 compositor: gnome-shell driver:
X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: BenQ RL2455 serial: <filter> built: 2016
res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: vboxnet0 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 11.15 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00WN4A0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 223.79 GiB size: 223.79 GiB (100.00%) used: 11.15 GiB (5.0%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 223.79 GiB size: 223.79 GiB (100.00%) used: 11.15 GiB (5.0%) fs: btrfs
ID-4: /var/log raw-size: 223.79 GiB size: 223.79 GiB (100.00%) used: 11.15 GiB (5.0%)
ID-5: /var/tmp raw-size: 223.79 GiB size: 223.79 GiB (100.00%) used: 11.15 GiB (5.0%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 256 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 246 Uptime: 14m wakeups: 3 Memory: 7.63 GiB used: 2.55 GiB (33.4%) Init: systemd
v: 251 tool: systemctl Compilers: gcc: 12.1.0 Packages: 1322 pacman: 1318 lib: 363 flatpak: 4
Client: shell wrapper v: 5.1.16-release inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-28
Last full system update: 2022-05-28 ↻
