Hello.
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f2e0593b-9957-4cd7-ae92-50ff917d54b6
systemd.unified_cgroup_hierarchy=1 resume=UUID=442e4a39-4e7c-4961-8395-de24febbfd37 loglevel=3
pci=realloc intel_iommu=on
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: GAME GARAJ product: TRACER XL v: REV:1.0 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: GAME GARAJ model: TRACER XL v: REV:1.0 serial: <filter> BIOS: American Megatrends
v: E17F5IE2.100 date: 01/22/2021
Battery: ID-1: BAT1 charge: 51.1 Wh (100.0%) condition: 51.1/51.3 Wh (99.6%) volts: 12.9 min: 11.4
model: MSI BIF0_9 type: Li-ion serial: N/A status: Full
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4574 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4574 2: 4700 3: 3910 4: 4692
5: 4146 6: 4595 7: 4594 8: 3426 9: 4191 10: 4600 11: 4551 12: 4589
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Micro-Star MSI driver: nvidia
v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Monitor-1: eDP-1-1 res: 1920x1080 hz: 144 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74
direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF-ID-3: virbr1 state: down mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 1.36 TiB used: 785.1 GiB (56.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G size: 465.76 GiB
rev: S5Z44101 temp: 35.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Seagate model: Expansion size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 0712 scheme: GPT
Partition: ID-1: / raw-size: 448.75 GiB size: 448.75 GiB (100.00%) used: 294.19 GiB (65.6%) fs: btrfs
ID-2: /home raw-size: 448.75 GiB size: 448.75 GiB (100.00%) used: 294.19 GiB (65.6%) fs: btrfs
ID-3: /var/log raw-size: 448.75 GiB size: 448.75 GiB (100.00%) used: 294.19 GiB (65.6%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 448.75 GiB size: 448.75 GiB (100.00%) used: 294.19 GiB (65.6%)
ID-1: swap-1 type: partition size: 17.01 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.46 GiB used: 1024 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A gpu: nvidia temp: 50 C
Info: Processes: 408 Uptime: 38m wakeups: 1 Memory: 15.46 GiB used: 7.4 GiB (47.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2018 lib: 564
I have been trying to get a live wallpaper to work on garuda for a while now and nothing seems to be working. I have tried komorebi, wallset and livewallpaper but they all had problems. The one i had the least problems was wallset which worked but the default wallpaper was infront of it and it was in the background. Is there any way around this?
