Ananicy-rules-git and ananicy-git are in conflict
When I go install something from ADD/removes then I got this
Please see the following attachment...
 Preparing...
Synchronizing package databases...
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: harfbuzz will be installed before its freetype2 dependency
Warning: libglvnd will be installed before its mesa dependency
Failed to prepare transaction:
conflicting dependencies:
- ananicy-rules-git and ananicy-git are in conflict
Nothing can be installed from app store, same problem shows.
If someone got this before and resolved help me out.
You probably have ananicy-cpp installed, which depends on ananicy-rules-git. What makes you want to install ananicy? We do prefer text output instead of pictures here, they are hardly nice to hard.
I just installed Gardua Gnome completely new OS, Previously I used Gnome-40, But again I reinstalled this os again
This problem did arise from when I went to install Firefox from Add/Remove soft store
sudo pacman -Rdd ananicy-git && sudo pacman -Syu
After executing sudo pacman -Rdd ananicy-git && sudo pacman -Syu
No packages been upgraded.
Following is terminal output at end of the process.
downloading required keys...
:: Import PGP key 0706B90D37D9B881, "Chaotic-AUR Wild Bear Node <wildbear.node@chaotic.cx>"? [Y/n] y
error: key "0706B90D37D9B881" could not be looked up remotely
:: Import PGP key 1736C918F59A5673, "Alexander Epaneshnikov <alex19ep@archlinux.org>"? [Y/n] y
:: Import PGP key A85E811EB4CA2E08, "Caleb Maclennan <alerque@archlinux.org>"? [Y/n] y
:: Import PGP key 57F3D9CC660431DD, "Pedro Henrique Lara Campos <root@pedrohlc.com>"? [Y/n] y
:: Import PGP key E0959FEA8B550539, "George Rawlinson <grawlinson@archlinux.org>"? [Y/n] y
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
Download of firefox (96.0-1) finished
Checking keyring...
Downloading required keys...
Error: key "0706B90D37D9B881" could not be looked up remotely
Error: required key missing from keyring
Failed to commit transaction
Oh boy, that looks like the system is either outdated as hell or broken for some reason. The first would explain why ananicy-git is installed though :eyes:
Open up Garuda Assistant and click the keyring option at the opening page, then try again. This will get the recent signing keys which are required to install the packages :slight_smile:
This is Garuda Assistant, in which should I select for, please tell
Okay, that screenshot confirms your system is hella outdated :stuck_out_tongue: Its in fact outdated enough to not contain the version of Garuda Assistant which introduced that button :eyes:
Here is the command that would usually be run using the option:
pacman-key --init && pacman -Qs archlinux-keyring && pacman-key --populate archlinux; pacman -Qs chaotic-keyring && pacman-key --populate chaotic; pacman -Qs blackarch-keyring && pacman-key --populate blackarch
Make sure to run Garuda Assistant again after doing a full system update and see the changes :smiley:
I did run this whole command and then again went to upgrade whole system but the result is same, shows...
Checking keyring...
Oh well, there was no keyring getting updated in the previous command, lol. Then, we need to fetch the keyrings key first, then update it:
sudo pacman-key --recv-key FBA220DFC880C036 --keyserver keyserver.ubuntu.com
sudo pacman-key --lsign-key FBA220DFC880C036
sudo pacman -U 'https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-keyring.pkg.tar.zst'
Then, sudo pacman -Sy archlinux-keyring followed by sudo pacman -Syu
You did not include your inxi -Faz as requested in our help request template. Please include this missing info.
  Kernel: 5.11.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
    root=UUID=0416a7bf-cc96-40d8-826e-0412b715f758 rw rootflags=subvol=@
  Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
    Distro: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B365M GAMING HD v: x.x
    serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F1
    date: 05/30/2019
  Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xDE
    desc: 1x9 MiB
  Speed (MHz): avg: 2930 high: 3750 min/max: 800/4100 scaling:
    driver: intel_pstate governor: performance cores: 1: 2014 2: 2732 3: 3750
    4: 3121 5: 3451 6: 2513 bogomips: 34798
  Type: l1tf
    IBRS_FW, STIBP: disabled, RSB filling
    vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 01:00.0
  Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
    display-ID: :1 screens: 1
    s-diag: 582mm (22.9")
  Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
    size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
  Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Sound Server-1: ALSA v: k5.11.1-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
    vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 07:00.0
  Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
    bus-ID: 1-3:3 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
  IF: wlp0s20f0u3 state: up mac: <filter>
    driver: btusb v: 0.8 bus-ID: 1-9:6 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.13 TiB used: 258.33 GiB (22.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TEUTONS model: PLATIUM SSD 240GB
    type: SSD serial: <filter> rev: 0817 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
    model: WD10 SPZX-24Z10T0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> scheme: MBR
  ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
    used: 14.85 GiB (6.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  Kernel: swappiness: 133 (default 60) cache-pressure: 75 (default 100)
  ID-1: swap-1 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram0
  ID-2: swap-2 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram1
  ID-3: swap-3 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram2
  ID-4: swap-4 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram3
  ID-5: swap-5 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram4
  ID-6: swap-6 type: zram size: 2.6 GiB used: 4.2 MiB (0.2%)
    priority: 32767 dev: /dev/zram5
  System Temperatures: cpu: 57.0 C mobo: 16.8 C gpu: amdgpu temp: 47.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 755
  Processes: 342 Uptime: 10h 9m wakeups: 0 Memory: 15.58 GiB
  used: 4.38 GiB (28.1%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1199 lib: 324 Shell: fish
  v: 3.3.1 running-in: gnome-terminal inxi: 3.3.11
Thanks for your ultimate assistance.
