Ananicy-cpp warning cgroup2
[sudo] password for twistedxenos:
  Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=ea1a68ec-d5b0-4b60-a0be-a89102ebe34d rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.4.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX HERO v: Rev 1.xx
    serial: <filter> part-nu: SKU uuid: 9df7b6e0-d7da-11dd-99f5-2c4d5499f2f7
    UEFI: American Megatrends v: 1301 date: 03/14/2018
  Info: model: Intel Core i7-7700K socket: LGA1151 bits: 64 type: MT MCP
    arch: Kaby Lake gen: core 7 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF8
  Speed (MHz): avg: 900 min/max: 800/4500:4800 base/boost: 4800/8300
    scaling: driver: intel_pstate governor: powersave volts: 1.3 V
    ext-clock: 100 MHz cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 bogomips: 67200
  Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: ASUSTeK
    driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: none
    off: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 01:00.0 chip-ID: 10de:2783
  Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.00x11.26")
    s-diag: 1551mm (61.05")
  Monitor-1: DP-1 note: disabled pos: right model: BenQ ZOWIE XL LCD
    serial: <filter> built: 2019 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 92 gamma: 1.2 size: 531x298mm (20.91x11.73") diag: 609mm (24")
  Monitor-2: DP-2 note: disabled pos: left model: BenQ ZOWIE XL LCD
  Monitor-3: HDMI-A-1 note: disabled pos: primary,center model: Samsung
    built: 2012 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 46 gamma: 1.2
    size: 1060x626mm (41.73x24.65") diag: 1021mm (40.2") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
    SUPER/PCIe/SSE2 memory: 11.71 GiB
  API: Vulkan v: 1.4.313 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4070 SUPER driver: nvidia v: 575.64 device-ID: 10de:2783
    surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 20.1.6 256 bits)
    driver: mesa llvmpipe v: 25.1.4-arch1.1 (LLVM 20.1.6)
  Device-2: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bc
  Device-3: SteelSeries ApS Arctis Nova 7
    lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 1038:2202 class-ID: 0300
  API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.6 status: n/a (root, process) with:
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:4
  Local Storage: total: 2.79 TiB used: 57.19 GiB (2.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: A-Data model: SX8200PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: S0118C temp: 34.9 C
  SMART: yes health: PASSED on: 4y 192d 16h cycles: 3,484
    read-units: 310,003,990 [158 TB] written-units: 370,045,716 [189 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
    model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
    fw-rev: 3.2.J.JE temp: 47.9 C scheme: GPT
  SMART: yes health: PASSED on: 171d 1h cycles: 498
    read-units: 36,315,422 [18.5 TB] written-units: 37,086,233 [18.9 TB]
  ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 57.19 GiB (3.0%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
    used: 632 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
    used: 57.19 GiB (3.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
    maj-min: 259:2
  ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
    maj-min: 259:2
  ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
    maj-min: 259:2
  System Temperatures: cpu: 32.2 C mobo: 30.3 C
  Fan Speeds (rpm): fan-3: 1284 fan-5: 1321
  Memory: total: 32 GiB available: 31.27 GiB used: 5.3 GiB (17.0%)
  Processes: 338 Power: uptime: 19m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1490 libs: 444 tools: octopi,paru Compilers:
    gcc: 15.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
    running-in: warp inxi: 3.3.38
Garuda (2.7.3-1):
  System install date:     2025-06-28
  Last full system update: 2025-06-29 โ†ป
  Windows dual boot:       Yes
โ— ananicy-cpp.service - Ananicy-Cpp - ANother Auto NICe daemon in C++
     Loaded: loaded (/usr/lib/systemd/system/ananicy-cpp.service; enabled; preset: disabled)
     Active: active (running) since Sun 2025-06-29 12:37:47 EEST; 11min ago
 Invocation: 311adf6961154353b5d00dcbfd0b1f61
   Main PID: 851 (ananicy-cpp)
      Tasks: 4 (limit: 38225)
     Memory: 13.7M (high: 16M, max: 64M, available: 2.2M, peak: 15M)
        CPU: 1.685s
     CGroup: /system.slice/ananicy-cpp.service
             โ””โ”€851 /usr/bin/ananicy-cpp start
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: Ananicy Cpp
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.303] [info] Starting Ananicy
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.304] [warning] cgroup2 at /sys/fs/cgroup/ananicy_test_cgroup2 doesn't have a cpu >
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.304] [info] Creating Cgroups...
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.304] [warning] Cgroups are not available on this platform (or are not enabled)
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.304] [info] Finished creating Cgroups...
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.305] [info] Doing a full scan
juuni 29 12:37:47 TwistedXenos-PC ananicy-cpp[851]: [2025-06-29 12:37:47.310] [info] Worker initialized with 1364 rules
After restarting ananicy-cpp:
     Active: active (running) since Sun 2025-06-29 12:49:45 EEST; 2s ago
 Invocation: 1dbb84a6d06b4fc990747da68c8e2373
   Main PID: 33387 (ananicy-cpp)
     Memory: 5.7M (high: 16M, max: 64M, available: 10.2M, peak: 5.9M)
        CPU: 84ms
             โ””โ”€33387 /usr/bin/ananicy-cpp start
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.467] [info] Config apply_ionice: true
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.467] [info] Config cgroup_load: true
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.467] [info] Config apply_sched: true
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.467] [info] Config apply_nice: true
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: Ananicy Cpp
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.472] [info] Starting Ananicy
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.473] [info] Creating Cgroups...
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.474] [info] Finished creating Cgroups...
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.474] [info] Doing a full scan
juuni 29 12:49:45 TwistedXenos-PC ananicy-cpp[33387]: [2025-06-29 12:49:45.480] [info] Worker initialized with 1364 rules
After every reboot I have to restart ananicy-cpp and it is kind of annoying and also sometimes I forget about it, so I was wondering if there is a way to fix this?
Looks a lot like this?
I guess there was no real solution in the end. The guy mentioned he was going to fix it, but that was over six months ago, so I just created an 'override.conf` file myself, and that solved the issue.
[Unit]
After=multi-user.target init.scope
[Service]
ExecStartPre=/bin/sleep 10
