When I try to run anaconda navigator I run in to this:
" qt.glx: qglx_findConfig: Failed to finding matching FBConfig for QSurfaceFormat(version 2.0, options QFla
gs<QSurfaceFormat::FormatOption>(), depthBufferSize -1, redBufferSize 1, greenBufferSize 1, blueBufferSiz
e 1, alphaBufferSize -1, stencilBufferSize -1, samples -1, swapBehavior QSurfaceFormat::SingleBuffer, swa
pInterval 1, colorSpace QSurfaceFormat::DefaultColorSpace, profile QSurfaceFormat::NoProfile)
Could not initialize GLX
Aborted (core dumped)"
I have scoured the forums and google for three days now looking for a proper answer. I am a Gardua/Linux newbie.
rtracy ~ 15:44 garuda-inxi
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d0ff166a-692f-4546-a022-a127f4b87dbc rw rootflags=subvol=@
Desktop: GNOME v: 47.1 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: HP Laptop 14-dk1xxx v: N/A
Mobo: HP model: 879E v: 84.54 serial: <superuser required>
part-nu: 340V7UA#ABA uuid: <superuser required> UEFI: AMI v: F.70
date: 07/18/2023
ID-1: BAT0 charge: 38.4 Wh (100.0%) condition: 38.4/38.4 Wh (100.0%)
volts: 12.9 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: AMD Athlon Silver 3050U with Radeon Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache:
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
bogomips: 9183
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 04:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 59.0 C
Device-2: Sunplus Innovation NexiGo N930AF FHD Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1.4:8 chip-ID: 1bcf:2283 class-ID: 0102
Device-3: Chicony HP Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b62a
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: amdgpu
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: HP P24h G4
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: eDP-1 mapped: eDP note: disabled model: BOE Display 0x07b5
built: 2018 res: 1920x1080 dpi: 116 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 345mm (13.6") ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.0-devel
raven2 LLVM 18.1.8 DRM 3.59 6.12.1-zen1-1-zen) device-ID: 1002:15d8
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.295 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAVEN2) driver: mesa radv
v: 25.0.0-devel (git-82e68de681) device-ID: 1002:15d8 surfaces: xcb,xlib
device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits)
driver: mesa llvmpipe v: 25.0.0-devel (git-82e68de681) (LLVM 18.1.8)
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 8 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sunplus Innovation NexiGo N930AF FHD Webcam
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 0bda:b00a
Local Storage: total: 2.73 TiB used: 216.48 GiB (7.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P4CR324 temp: 42.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1.14 scheme: GPT
used: 33.42 GiB (3.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 13.56 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 2
System Temperatures: cpu: 58.8 C mobo: N/A gpu: amdgpu temp: 58.0 C
Memory: total: 16 GiB note: est. available: 13.56 GiB used: 2.52 GiB (18.6%)
Processes: 284 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.41 GiB services: gsd-power,
Packages: 1693 pm: pacman pkgs: 1673 libs: 463 tools: octopi,pamac,paru
pm: rpm pkgs: 0 pm: flatpak pkgs: 20 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
System install date: 2024-11-23
Last full system update: 2024-11-24
