An update bugs out my Display Port audio
This evening I was notified to update 56 packages, one of them appears to bug out my audio driver, I have already restored the snapshot to confirm this.
The Audio device after update is called : “Line Out (Built-in Audio Analog Stereo)”, while before the update it was “HDMI/DisplayPort 3( TU106 High Definition Audio Controller)”
After updating one of the following packages causes this:
beautyline 20210907-1 -> 20211026-1
bluedevil 1:5.23.1-1 -> 1:5.23.2-1
breeze 5.23.1-1 -> 5.23.2-1
breeze-gtk 5.23.1-1 -> 5.23.2-1
c-ares 1.17.2-1 -> 1.18.0-1
discover 5.23.1-1 -> 5.23.2-1
drkonqi 5.23.1-1 -> 5.23.2-1
filezilla 3.56.0-1 -> 3.56.1-1
garuda-assistant 2.3.0-1 -> 2.3.2-1
garuda-hotfixes 1.0.0-2 -> 1.0.3-1
garuda-update 1.2.4-1 -> 1.2.5-1
goverlay-git 0.6.3.r7.ga6f420e-1 -> 0.6.3.r8.gc56a75a-1
imagemagick 7.1.0.11-1 -> 7.1.0.12-1
kactivitymanagerd 5.23.1-1 -> 5.23.2-1
kde-cli-tools 5.23.1-1 -> 5.23.2-1
kde-gtk-config 5.23.1-1 -> 5.23.2-1
kdecoration 5.23.1-1 -> 5.23.2-1
kdeplasma-addons 5.23.1-1 -> 5.23.2-1
kgamma5 5.23.1-1 -> 5.23.2-1
khotkeys 5.23.1-1 -> 5.23.2-1
kinfocenter 5.23.1-1 -> 5.23.2-1
kmenuedit 5.23.1-1 -> 5.23.2-1
kscreen 5.23.1-1 -> 5.23.2-1
kscreenlocker 5.23.1-1 -> 5.23.2-1
ksshaskpass 5.23.1-1 -> 5.23.2-1
ksystemstats 5.23.1-1 -> 5.23.2-1
kwallet-pam 5.23.1-1 -> 5.23.2-1
kwayland-integration 5.23.1-1 -> 5.23.2-1
kwayland-server 5.23.1-1 -> 5.23.2-1
kwin 5.23.1-2 -> 5.23.2-1
kwrited 5.23.1-1 -> 5.23.2-1
layer-shell-qt 5.23.1-1 -> 5.23.2-1
libfilezilla 0.34.1-1 -> 0.34.2-1
libkscreen 5.23.1-1 -> 5.23.2-1
libksysguard 5.23.1-1 -> 5.23.2-1
linux-wifi-hotspot 4.3.2-1 -> 4.3.3-1
milou 5.23.1-1 -> 5.23.2-1
npm 8.1.0-1 -> 8.1.1-1
plasma-browser-integration 5.23.1-1 -> 5.23.2-1
plasma-desktop 5.23.1-1 -> 5.23.2-1
plasma-disks 5.23.1-1 -> 5.23.2-1
plasma-firewall 5.23.1-1 -> 5.23.2-1
plasma-integration 5.23.1-1 -> 5.23.2-1
plasma-nm 5.23.1-1 -> 5.23.2-1
plasma-pa 5.23.1-1 -> 5.23.2-1
plasma-systemmonitor 5.23.1-1 -> 5.23.2-1
plasma-thunderbolt 5.23.1-1 -> 5.23.2-1
plasma-vault 5.23.1-1 -> 5.23.2-1
plasma-workspace 5.23.1-1 -> 5.23.2-1
plasma-workspace-wallpapers 5.23.1-1 -> 5.23.2-1
polkit-kde-agent 5.23.1-1 -> 5.23.2-1
powerdevil 5.23.1-1 -> 5.23.2-1
protontricks-git 1.6.1.r0.gc5255fe-1 -> 1.6.1.r1.g758147d-1
sddm-kcm 5.23.1-1 -> 5.23.2-1
signal-desktop 5.20.0-1 -> 5.21.0-1
systemsettings 5.23.1-1 -> 5.23.2-1
xdg-desktop-portal-kde 5.23.1-1 -> 5.23.2-1
Before update:
System:    Kernel: 5.14.14-2-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/.snapshots/68/snapshot/boot/vmlinuz-linux-cacule
root=UUID=ac38aefa-a9bb-4285-b85a-dd00f1b36218 quiet splash rd.udev.log_priority=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,subvol=@/.snapshots/68/snapshot
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME Z390-P v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2417 date: 06/03/2019
CPU:       Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 34814
Speed: 3835 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 3835 2: 2889 3: 3078 4: 3041
5: 3467 6: 1303
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f08 class-ID: 0300
Device-2: Pixart Imaging PAC731x Trust Webcam type: USB driver: gspca_pac7302,snd-usb-audio
bus-ID: 1-11:4 chip-ID: 093a:2621 class-ID: 0102
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DP-2 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Pixart Imaging PAC731x Trust Webcam type: USB driver: gspca_pac7302,snd-usb-audio
Sound Server-1: ALSA v: k5.14.14-2-cacule running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 2.04 TiB used: 68.85 GiB (3.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB size: 223.58 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.82 GiB (7.4%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 25.4 MiB (26.7%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.82 GiB (7.4%) fs: btrfs
ID-4: /var/log raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.82 GiB (7.4%) fs: btrfs
ID-5: /var/tmp raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.82 GiB (7.4%) fs: btrfs
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 63 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Info:      Processes: 270 Uptime: 11m wakeups: 0 Memory: 15.55 GiB used: 3.84 GiB (24.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1955 apt: 1 pacman: 1949
lib: 547 flatpak: 5 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
After update:
System:    Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ac38aefa-a9bb-4285-b85a-dd00f1b36218
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 34798
Speed: 3869 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 3869 2: 4047 3: 4001 4: 4034
5: 4072 6: 4003
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Drives:    Local Storage: total: 2.04 TiB used: 68.82 GiB (3.3%)
Partition: ID-1: / raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.79 GiB (7.4%) fs: btrfs
ID-3: /home raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.79 GiB (7.4%) fs: btrfs
ID-4: /var/log raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.79 GiB (7.4%) fs: btrfs
ID-5: /var/tmp raw-size: 931.52 GiB size: 931.52 GiB (100.00%) used: 68.79 GiB (7.4%) fs: btrfs
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
I'd like to report here, and hope I'm in the right thread, that I also experience problems with they audio after yesterday's updates (and I've checked the "Package conflict between pipewire-media-session & wireplumber" discussion and the garuda-hotfix issue as well and related suggested fixes)
I use an external USB card, btw.
After the update, we were saying, any audio and video is not working. Streaming video and audio hang, media players don't reproduce anything. Only VLC plays the video but with no audio.
When I log out and login again switching from X11 to Wayland it now plays the video but the sound cards are not recognized at all.
i get this message when launching any player or browser, I don't know whether it's related
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Again, I hope it's the right discussion and it's pertinent, as it's the only similar issue I have found after this very same update.
EDIT: I installed pipewire-media-session and the problem has gone. Sorry for having another duplicate of a few other threads I've seen yesterday and today :confused:
Weird the hotfix appeared this morning again & that fixed it. Im confused how the hotfix didnt go through the first time. And im 99% sure that i didnt restore any snapshots before it.
I see a couple of hours ago a new version of the hotfix was released to resolve the conflict differently.
Maybe this was what you needed to fix your issue...
2 posts were merged into an existing topic: Audio system is not working after Wireplumber update
