Hello, after last linux-firmware and kernel upgrades I have situation that after Grub menu system stops with that info like on screenshot:
I have to hit
Enter to start launching system.Journal logs:
gru 18 11:19:22 emilka-matebook kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20230628/dswload2-162)
gru 18 11:19:22 emilka-matebook kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
gru 18 11:19:22 emilka-matebook kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
gru 18 11:19:22 emilka-matebook kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
gru 18 11:19:24 emilka-matebook kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 10
gru 18 11:19:25 emilka-matebook bluetoothd[636]: Failed to set mode: Not Supported (0x0c)
gru 18 11:19:25 emilka-matebook bluetoothd[636]: Failed to set mode: Failed (0x03)
gru 18 11:19:25 emilka-matebook bluetoothd[636]: Too small Add Device complete event
Kernel: 6.6.65-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw rootflags=subvol=@
resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3 ibt=off
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1300
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1300 serial: <superuser required>
part-nu: C178 uuid: <superuser required> UEFI: HUAWEI v: 1.06
date: 09/14/2020
ID-1: BAT0 charge: 35.9 Wh (73.1%) condition: 49.1/54.9 Wh (89.4%)
volts: 7.9 min: 7.6 model: SUNWODA HB4593R1ECW-22S0 type: Li-ion
serial: <filter> status: discharging cycles: 581
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
bogomips: 71890
Device-1: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Huaqin driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 33.0 C
Device-2: IMC Networks HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:5451
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0893 built: 2019 res: 2160x1440
dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76") diag: 356mm (14")
ratio: 3:2 modes: max: 2160x1440 min: 640x480
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
Audio vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Huaqin driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Huaqin driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.65-1-lts status: kernel-api tools: N/A
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 1358:c123
Local Storage: total: 476.94 GiB used: 183.93 GiB (38.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1027 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21117000 temp: 33.9 C scheme: GPT
used: 183.93 GiB (39.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 7.14 GiB used: 643 MiB (8.8%) priority: 100
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 8 GiB note: est. available: 7.14 GiB used: 4.56 GiB (64.0%)
Processes: 380 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.83 GiB services: gsd-power,
Packages: 1843 pm: pacman pkgs: 1799 libs: 462
tools: gnome-software,pamac,paru pm: flatpak pkgs: 44 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: gnome-terminal
inxi: 3.3.36
System install date: 2022-04-09
Last full system update: 2024-12-17
Failed units: syncthing@przemyslaw.service
