Hello, Everyone. New Garuda user. Ok, new linux user
I'm following a tutorial video about using anaconda for python. They went to the anaconda web site to download it, but I imagined using octopi was 'better' ? Does it matter?
Anyway, I got it installed well enough via konsole & fish shell but when i went to execute the conda command, it wasn't found. The video said if you have an error, run source ~/.bashrc
When I did, it complained about an equal sign not being valid in fish, suggesting that I use 'set' instead. So, i commented out the offending line and copied it with 'set' as a prefix.
ran source again, and it said no closure to an 'if' in the bashrc. I looked up and found that fish wants 'end' rather than 'fi', and started to change those, too.
But i'm now wondering whether this is what I'm supposed to be doing. I mean, if ever I decide to change my shell to bash or zsh, won't I have to undo what I'm doing now? That doesn't seem like I'm going about this the right way, so here I am to ask:
What's the right/better way for me to handle this situation? Should I just change my shell to bash? Or, is there a way to keep fish but still run bash scripts without having to edit them for differences?
Thanksin advance for your insights!
Oh, in order to be compliant with the forum rules, here's my garuda-inxi output:
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=fe2a04e0-7e03-49df-b233-906e6e1b68c0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Micro-Star product: Bravo 15 B5DD v: REV:1.0
Mobo: Micro-Star model: MS-158K v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E158KAMS.108 date: 08/04/2021
ID-1: BAT1 charge: 50.7 Wh (96.6%) condition: 52.5/52.0 Wh (101.0%)
volts: 12.8 min: 11.4 model: MSI Corp. MS-158K type: Li-ion serial: N/A
status: N/A
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2536 high: 3970 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1474 2: 1397
3: 3459 4: 3453 5: 3434 6: 3433 7: 2401 8: 3520 9: 2753 10: 1905 11: 1396
12: 1396 13: 1396 14: 1734 15: 3456 16: 3970 bogomips: 102211
STIBP: always-on, RSB filling
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA 1
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: none bus-ID: 03:00.0
chip-ID: 1002:7340 class-ID: 0380
Device-2: AMD Cezanne vendor: Micro-Star MSI driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
active: eDP-1 empty: none bus-ID: 07:00.0 chip-ID: 1002:1638
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-4:4
chip-ID: 5986:211b class-ID: 0e02
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-A-1-0 pos: right model: HP 2159
serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 479x269mm (18.86x10.59") diag: 549mm (21.6") ratio: 16:9 modes:
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: AU Optronics 0x80ed
built: 2017 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.5-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio vendor: Micro-Star MSI
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Micro-Star MSI
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 3-3:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 476.94 GiB used: 105.06 GiB (22.0%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 37.9 C scheme: GPT
used: 105.06 GiB (22.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.01 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 50.0 C mobo: N/A
GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 42.0 C mem: 0.0 C
fan: 65535 watts: 7.00
Processes: 377 Uptime: 5h 22m wakeups: 2 Memory: 15.02 GiB
used: 4.91 GiB (32.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1767
lib: 509 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.18
Garuda (2.6.4-1):
System install date: 2022-06-21
Last full system update: 2022-06-22
