i have replaced alacritty with alacritty-git , I got the speed back
then configured for opacity and changed font congifuration in alacritty.yml:
# Configuration for Alacritty, the GPU enhanced terminal emulator.
# Any items in the `env` entry below will be added as
# environment variables. Some entries may override variables
# set by alacritty itself.
env:
# TERM variable
# This value is used to set the `$TERM` environment variable for
# each instance of Alacritty. If it is not present, alacritty will
# check the local terminfo database and use `alacritty` if it is
# available, otherwise `xterm-256color` is used.
TERM: xterm-256color
window:
# Window dimensions (changes require restart)
# Specified in number of columns/lines, not pixels.
# If both are `0`, this setting is ignored.
dimensions:
columns: 100
lines: 30
# Window position (changes require restart)
# Specified in number of pixels.
# If the position is not set, the window manager will handle the placement.
#position:
# x: 0
# y: 0
# Window padding (changes require restart)
# Blank space added around the window in pixels. This padding is scaled
# by DPI and the specified value is always added at both opposing sides.
#padding:
# x: 0
# y: 0
# Spread additional padding evenly around the terminal content.
dynamic_padding: true
# Window decorations
# Values for `decorations`:
# - full: Borders and title bar
# - none: Neither borders nor title bar
# Values for `decorations` (macOS only):
# - transparent: Title bar, transparent background and title bar buttons
# - buttonless: Title bar, transparent background, but no title bar buttons
decorations: full
# Startup Mode (changes require restart)
# Values for `startup_mode`:
# - Windowed
# - Maximized
# - Fullscreen
# Values for `startup_mode` (macOS only):
# - SimpleFullscreen
#startup_mode: Windowed
# Window title
title: [email protected]
# Opacity
opacity: 0.6
# Window class (Linux/BSD only):
class:
# Application instance name
instance: Alacritty
# General application class
general: Alacritty
# GTK theme variant (Linux/BSD only)
# Override the variant of the GTK theme. Commonly supported values are `dark` and `light`.
# Set this to `None` to use the default theme variant.
gtk_theme_variant: dark
scrolling:
# Maximum number of lines in the scrollback buffer.
# Specifying '0' will disable scrolling.
history: 10000
# Scrolling distance multiplier.
multiplier: 3
# Font configuration
font:
# Normal (roman) font face
normal:
# Font family
# Default:
# - (macOS) Menlo
# - (Linux/BSD) monospace
# - (Windows) Consolas
family: FantasqueSansMono Nerd Font Mono
# The `style` can be specified to pick a specific face.
#style: Regular
# Bold font face
bold:
# Font family
# If the bold family is not specified, it will fall back to the
# value specified for the normal font.
#style: Bold
# Italic font face
italic:
# Font family
# If the italic family is not specified, it will fall back to the
#style: Italic
# Bold italic font face
bold_italic:
# Font family
# If the bold italic family is not specified, it will fall back to the
#style: Bold Italic
# Point size
# Offset is the extra space around each character. `offset.y` can be thought of
# as modifying the line spacing, and `offset.x` as modifying the letter spacing.
#offset:
# x: 0
# y: 0
# Glyph offset determines the locations of the glyphs within their cells with
# the default being at the bottom. Increasing `x` moves the glyph to the right,
# increasing `y` moves the glyph upwards.
#glyph_offset:
# x: 0
# y: 0
# Thin stroke font rendering (macOS only)
# Thin strokes are suitable for retina displays, but for non-retina screens
# it is recommended to set `use_thin_strokes` to `false`.
#use_thin_strokes: true
# If `true`, bold text is drawn using the bright color variants.
draw_bold_text_with_bright_colors: true
# Colors (Tomorrow Night)
#colors:
# Default colors
#primary:
# background: '#1d1f21'
# foreground: '#c5c8c6'
# Bright and dim foreground colors
# The dimmed foreground color is calculated automatically if it is not present.
# If the bright foreground color is not set, or `draw_bold_text_with_bright_colors`
# is `false`, the normal foreground color will be used.
#dim_foreground: '#828482'
#bright_foreground: '#eaeaea'
# Cursor colors
# Colors which should be used to draw the terminal cursor. If these are
# unset, the cursor color will be the inverse of the cell color.
#cursor:
# text: '#000000'
# cursor: '#ffffff'
# Vi mode cursor colors
# Colors for the cursor when the vi mode is active. If these are unset, the
# cursor color will be the inverse of the cell color.
#vi_mode_cursor:
# text: '#000000'
# cursor: '#ffffff'
# Selection colors
# Colors which should be used to draw the selection area. If selection
# background is unset, selection color will be the inverse of the cell colors.
# If only text is unset the cell text color will remain the same.
#selection:
# text: '#eaeaea'
# background: '#404040'
# Normal colors
#normal:
# black: '#1d1f21'
# red: '#cc6666'
# green: '#b5bd68'
# yellow: '#f0c674'
# blue: '#81a2be'
# magenta: '#b294bb'
# cyan: '#8abeb7'
# white: '#c5c8c6'
# Bright colors
#bright:
# black: '#666666'
# red: '#d54e53'
# green: '#b9ca4a'
# yellow: '#e7c547'
# blue: '#7aa6da'
# magenta: '#c397d8'
# cyan: '#70c0b1'
# white: '#eaeaea'
# Dim colors
# If the dim colors are not set, they will be calculated automatically based
# on the `normal` colors.
#dim:
# black: '#131415'
# red: '#864343'
# green: '#777c44'
# yellow: '#9e824c'
# blue: '#556a7d'
# magenta: '#75617b'
# cyan: '#5b7d78'
# white: '#828482'
# Indexed Colors
# The indexed colors include all colors from 16 to 256.
# When these are not set, they're filled with sensible defaults.
# Example:
# `- { index: 16, color: '#ff00ff' }`
#indexed_colors: []
# Visual Bell
# Any time the BEL code is received, Alacritty "rings" the visual bell. Once
# rung, the terminal background will be set to white and transition back to the
# default background color. You can control the rate of this transition by
# setting the `duration` property (represented in milliseconds). You can also
# configure the transition function by setting the `animation` property.
# Values for `animation`:
# - Ease
# - EaseOut
# - EaseOutSine
# - EaseOutQuad
# - EaseOutCubic
# - EaseOutQuart
# - EaseOutQuint
# - EaseOutExpo
# - EaseOutCirc
# - Linear
# Specifying a `duration` of `0` will disable the visual bell.
#visual_bell:
# animation: EaseOutExpo
# duration: 0
# color: '#ffffff'
#selection:
#semantic_escape_chars: ",│`|:\"' ()[]{}<>\t"
# When set to `true`, selected text will be copied to the primary clipboard.
save_to_clipboard: true
# Allow terminal applications to change Alacritty's window title.
window.dynamic_title: true
cursor:
# Cursor style
# Values for `style`:
# - ▇ Block
# - _ Underline
# - | Beam
style: Underline
# Vi mode cursor style
# If the vi mode cursor style is `None` or not specified, it will fall back to
# the style of the active value of the normal cursor.
# See `cursor.style` for available options.
#vi_mode_style: None
# If this is `true`, the cursor will be rendered as a hollow box when the
# window is not focused.
#unfocused_hollow: true
# Thickness of the cursor relative to the cell width as floating point number
# from `0.0` to `1.0`.
#thickness: 0.15
# Live config reload (changes require restart)
live_config_reload: true
# Shell
# You can set `shell.program` to the path of your favorite shell, e.g. `/bin/fish`.
# Entries in `shell.args` are passed unmodified as arguments to the shell.
# Default:
# - (macOS) /bin/bash --login
# - (Linux/BSD) user login shell
# - (Windows) powershell
shell:
program: /usr/bin/fish
args:
- --login
# Startup directory
# Directory the shell is started in. If this is unset, or `None`, the working
# directory of the parent process will be used.
#working_directory: None
# WinPTY backend (Windows only)
# Alacritty defaults to using the newer ConPTY backend if it is available,
# since it resolves a lot of bugs and is quite a bit faster. If it is not
# available, the the WinPTY backend will be used instead.
# Setting this option to `true` makes Alacritty use the legacy WinPTY backend,
# even if the ConPTY backend is available.
#winpty_backend: false
# Send ESC (\x1b) before characters when alt is pressed.
#alt_send_esc: true
mouse:
# Click settings
# The `double_click` and `triple_click` settings control the time
# alacritty should wait for accepting multiple clicks as one double
# or triple click.
#double_click: { threshold: 300 }
#triple_click: { threshold: 300 }
# If this is `true`, the cursor is temporarily hidden when typing.
hide_when_typing: true
#url:
# URL launcher
# This program is executed when clicking on a text which is recognized as a URL.
# The URL is always added to the command as the last parameter.
# When set to `launcher: None`, URL launching will be disabled completely.
# Default:
# - (macOS) open
# - (Linux/BSD) xdg-open
# - (Windows) explorer
#launcher:
# program: xdg-open
# args: []
# URL modifiers
# These are the modifiers that need to be held down for opening URLs when clicking
# on them. The available modifiers are documented in the key binding section.
#modifiers: None
# Mouse bindings
# Mouse bindings are specified as a list of objects, much like the key
# bindings further below.
# To trigger mouse bindings when an application running within Alacritty captures the mouse, the
# `Shift` modifier is automatically added as a requirement.
# Each mouse binding will specify a:
# - `mouse`:
# - Middle
# - Left
# - Right
# - Numeric identifier such as `5`
# - `action` (see key bindings)
# And optionally:
# - `mods` (see key bindings)
#mouse_bindings:
# - { mouse: Middle, action: PasteSelection }
# Key bindings
# Key bindings are specified as a list of objects. For example, this is the
# default paste binding:
# `- { key: V, mods: Control|Shift, action: Paste }`
# Each key binding will specify a:
# - `key`: Identifier of the key pressed
# - A-Z
# - F1-F24
# - Key0-Key9
# A full list with available key codes can be found here:
# https://docs.rs/glutin/*/glutin/event/enum.VirtualKeyCode.html#variants
# Instead of using the name of the keys, the `key` field also supports using
# the scancode of the desired key. Scancodes have to be specified as a
# decimal number. This command will allow you to display the hex scancodes
# for certain keys:
# `showkey --scancodes`.
# Then exactly one of:
# - `chars`: Send a byte sequence to the running application
# The `chars` field writes the specified string to the terminal. This makes
# it possible to pass escape sequences. To find escape codes for bindings
# like `PageUp` (`"\x1b[5~"`), you can run the command `showkey -a` outside
# of tmux. Note that applications use terminfo to map escape sequences back
# to keys. It is therefore required to update the terminfo when changing an
# escape sequence.
# - `action`: Execute a predefined action
# - ToggleViMode
# - Copy
# - Paste
# - PasteSelection
# - IncreaseFontSize
# - DecreaseFontSize
# - ResetFontSize
# - ScrollPageUp
# - ScrollPageDown
# - ScrollLineUp
# - ScrollLineDown
# - ScrollToTop
# - ScrollToBottom
# - ClearHistory
# - Hide
# - Minimize
# - Quit
# - ToggleFullscreen
# - SpawnNewInstance
# - ClearLogNotice
# - ClearSelection
# - ReceiveChar
# - None
# (`mode: Vi` only):
# - Open
# - Up
# - Down
# - Left
# - Right
# - First
# - Last
# - FirstOccupied
# - High
# - Middle
# - Low
# - SemanticLeft
# - SemanticRight
# - SemanticLeftEnd
# - SemanticRightEnd
# - WordRight
# - WordLeft
# - WordRightEnd
# - WordLeftEnd
# - Bracket
# - ToggleNormalSelection
# - ToggleLineSelection
# - ToggleBlockSelection
# - ToggleSemanticSelection
# (macOS only):
# - ToggleSimpleFullscreen: Enters fullscreen without occupying another space
# (Linux/BSD only):
# - CopySelection: Copies into selection buffer
# - `command`: Fork and execute a specified command plus arguments
# The `command` field must be a map containing a `program` string and an
# `args` array of command line parameter strings. For example:
# `{ program: "alacritty", args: ["-e", "vttest"] }`
# And optionally:
# - `mods`: Key modifiers to filter binding actions
# - Command
# - Control
# - Option
# - Super
# - Shift
# - Alt
# Multiple `mods` can be combined using `|` like this:
# `mods: Control|Shift`.
# Whitespace and capitalization are relevant and must match the example.
# - `mode`: Indicate a binding for only specific terminal reported modes
# This is mainly used to send applications the correct escape sequences
# when in different modes.
# - AppCursor
# - AppKeypad
# - Alt
# A `~` operator can be used before a mode to apply the binding whenever
# the mode is *not* active, e.g. `~Alt`.
# Bindings are always filled by default, but will be replaced when a new
# binding with the same triggers is defined. To unset a default binding, it can
# be mapped to the `ReceiveChar` action. Alternatively, you can use `None` for
# a no-op if you do not wish to receive input characters for that binding.
# If the same trigger is assigned to multiple actions, all of them are executed
# at once.
key_bindings:
# (Windows, Linux, and BSD only)
- { key: C, mods: Control|Shift, action: Copy }
- { key: Insert, mods: Shift, action: PasteSelection }
- { key: Key0, mods: Control, action: ResetFontSize }
- { key: Equals, mods: Control, action: IncreaseFontSize }
- { key: Plus, mods: Control, action: IncreaseFontSize }
- { key: Minus, mods: Control, action: DecreaseFontSize }
#debug:
# Display the time it takes to redraw each frame.
#render_timer: false
# Keep the log file after quitting Alacritty.
#persistent_logging: false
# Log level
# Values for `log_level`:
# - None
# - Error
# - Warn
# - Info
# - Debug
# - Trace
#log_level: Warn
# Print all received window events.
#print_events: false
# Custom colorscheme fitting Sweetified theme
colors:
primary:
background: '0x0a1124'
foreground: '0xeec49a'
cursor:
text: '0x0a1124'
cursor: '0xeec49a'
normal:
black: '0x0a1124'
red: '0x5F4149'
green: '0xEB3247'
yellow: '0xBC4349'
blue: '0xF35645'
magenta: '0xF6A73B'
cyan: '0xFAD32F'
white: '0xeec49a'
bright:
black: '0xa6896b'
red: '0x5F4149'
green: '0xEB3247'
yellow: '0xBC4349'
blue: '0xF35645'
magenta: '0xF6A73B'
cyan: '0xFAD32F'
white: '0xeec49a'
but still one problem is left that it is still too much minimized.
what should i do
