Kernel: 6.8.2-3-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-linux
root=UUID=8a69f047-feee-46cf-81a1-d299eb173883 rw rootflags=subvol=@
sysrq_always_enabled=1 mitigations=off amd_pstate=active
amdgpu.ppfeaturemask=0xffffffff tsc=reliable clocksource=tsc nowatchdog
nmi_watchdog=0 initrd=@\boot\initramfs-linux-cachyos.img
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P5.10
date: 10/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3673 high: 3841 min/max: 550/4687 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3692 2: 3628 3: 3707
4: 3597 5: 3615 6: 3707 7: 3841 8: 3632 9: 3732 10: 3599 11: 3691 12: 3646
bogomips: 88801
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-2 empty: HDMI-A-1,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 4980x2513 display-ID: 0
Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,top-left res: 1396x785 size: N/A modes: N/A
Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
navi22 LLVM 17.0.6 DRM 3.57 6.8.2-3-cachyos) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 23 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: Sony INZONE H9 / H7
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 054c:0e53
class-ID: 0a00
API: ALSA v: k6.8.2-3-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4.2:10 chip-ID: 7392:c611
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 3.64 TiB used: 3.95 TiB (108.7%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
used: 795.69 GiB (85.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 44.3 MiB (14.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 31.26 GiB used: 4.49 GiB (14.4%)
System Temperatures: cpu: 55.5 C mobo: 35.0 C gpu: amdgpu temp: 57.0 C
mem: 60.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 2023 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.18 vbat: 3.28 gpu: amdgpu watts: 28.00
Memory: total: 32 GiB available: 31.26 GiB used: 22.08 GiB (70.6%)
Processes: 544 Power: uptime: 4h 59m states: freeze,mem,disk
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: 2818 pm: pacman pkgs: 2773 libs: 634 tools: octopi,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 45 Compilers: clang: 17.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
running-in: alacritty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-11
Last full system update: 2024-03-31 β»
ever since alacrity switched to the toml format I always had problems with the config (even though I did a alacritty migrate as suggested)
I would get
File: /tmp/Alacritty-1310078.log
[0.000247833s] [WARN ] [alacritty_config_derive] Unused config key: size
[0.000414661s] [WARN ] [alacritty_config_derive] Unused config key: save_to_clipboard
[0.000423040s] [WARN ] [alacritty_config_derive] Unused config key: window.dynamic_title
on every startup of alacrity
I never really paid attention to it until now where I want to try this color scheme GitHub - catppuccin/alacritty: π΄ Soothing pastel theme for Alacritty
so I ran curl -LO --output-dir ~/.config/alacritty https://github.com/catppuccin/alacritty/raw/main/catppuccin-mocha.toml
and added
import = [
# uncomment the flavour you want below:
#"~/.config/alacritty/catppuccin-latte.toml"
# "~/.config/alacritty/catppuccin-frappe.toml"
# "~/.config/alacritty/catppuccin-macchiato.toml"
"~/.config/alacritty/catppuccin-mocha.toml"
to the beginning of my ~/.config/alacritty/alacritty.toml
but nothing happened I am suspecting it is because of the errors I getting with the config (see above)
I tried rm the config file and then reopening alacrity but that produces a .yml file
running alacritty migrate converts it into a toml file but It still gives me the same warning and my color scheme does not apply
this is how the file looks currently
live_config_reload = true
save_to_clipboard = true
"window.dynamic_title" = true
[colors]
draw_bold_text_with_bright_colors = true
[colors.bright]
black = "0xa6896b"
blue = "0xF35645"
cyan = "0xFAD32F"
green = "0xEB3247"
magenta = "0xF6A73B"
red = "0x5F4149"
white = "0xeec49a"
yellow = "0xBC4349"
[colors.cursor]
cursor = "0xeec49a"
text = "0x0a1124"
[colors.normal]
black = "0x0a1124"
blue = "0xF35645"
cyan = "0xFAD32F"
green = "0xEB3247"
red = "0x5F4149"
white = "0xeec49a"
yellow = "0xBC4349"
[colors.primary]
background = "0x0a1124"
foreground = "0xeec49a"
[cursor]
style = "Underline"
[env]
TERM = "xterm-256color"
[font]
size = 12
[font.bold]
family = "FiraCode Nerd Font Mono"
[font.bold_italic]
size = 12.0
[font.italic]
[font.normal]
[[keyboard.bindings]]
action = "Paste"
key = "V"
mods = "Control|Shift"
action = "Copy"
key = "C"
action = "PasteSelection"
key = "Insert"
mods = "Shift"
action = "ResetFontSize"
key = "Key0"
mods = "Control"
action = "IncreaseFontSize"
key = "Equals"
mods = "Control"
key = "Plus"
mods = "Control"
action = "DecreaseFontSize"
key = "Minus"
mods = "Control"
key = "Minus"
mods = "Control"
[mouse]
hide_when_typing = true
[scrolling]
history = 10000
multiplier = 3
[shell]
args = ["--login"]
program = "/usr/bin/fish"
[window]
decorations = "full"
decorations_theme_variant = "Dark"
dynamic_padding = true
opacity = 0.6
title = "Alacritty@Garuda"
[window.class]
general = "Alacritty"
instance = "Alacritty"
[window.dimensions]
columns = 100
lines = 30
