So after another system update it happened again. This time I have intsalled the newest iso available on website. Bought another ssd drive -2 times larger than system partition (just for snapshots & backup purpose). What I have done differently this time - instead of manual creating partitions and seting up boot flags etc , allowed installer to handle that for me.
This way I'm expecting I've got subvolumes created properly.
Will keep posting regarding futher problems with upgrade.
It would seem to me you have a problem with your user’s ID and your group ID being different. IMO both should be 1000.
https://wiki.archlinux.org/index.php/Users_and_groups
For whatever reason, (my guess would be docker) somehow your gid has been altered. Are you using the guest account, or Multi-booting?
I suggest after reinstalling Garuda you refrain from installing timeshift and docker and then perform your updates. If you are using a more or less stock Garuda install this issue is unlikely to occur IMO, (or it would be commonly reported). It seems to me some misconfiguration on your part is causing this issue or there would be many similar reports, (if it was a Garuda configuration issue at fault).
If it doesn’t happen after a stock Garuda install and couple of update/reboot cycles then this would indicate a user initiated change is creating this problem. After installation only make one change at a time, then update and reboot to isolate the cause of your issue.
Edit:
If performing a new installation, be sure not to use autologin, and do not install the guest account package to limit the variables involved.
Alfter reinstalling what I see currently id looks pretty much the same according to groups:
id
uid=1000(zawier) gid=1001(zawier) groups=1001(zawier),50(games),971(realtime),972(libvirt),985(video),991(lp),992(kvm),994(input),998(wheel),1000(autologin)
Not many apps were installed yet, which is going to change soon. For my curiocity I have checked how it looks like in case of my Ubuntu system :
zawier@Brix-Ubuntu:~$ id
uid=1000(zawier) gid=1000(zawier) groups=1000(zawier),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),120(lpadmin),131(lxd),132(sambashare),136(docker)
So Ubuntu according to your opinion is correct. What’s more I have also docker and timeshift installed there :
zawier@Brix-Ubuntu:~$ docker --version
Docker version 20.10.12, build 20.10.12-0ubuntu4
Timeshift v21.09.1 by Tony George (teejeetech@gmail.com)
Bying honest I don’t know why in case of garuda distro my gid and group id are different. During installation of fresh system there literally is nothing what you can change about it. Just simple insert name , host name etc. So there is no my fault the system assigned it that way.
Ok, I will hold on with docker and TS right now until a couples of upgrades. But I just can’t believe that our community doesn’t use that software
I have read post regarding snapper on our forum and some folks claimed to stick with TS like me.
Ok, that’s weird since autologin is one of the options during installation and I have check it because I’m the only user of that account, so why to bother with login on system start up? Guest account - don’t remember to change anything about. It just exists without my integration.
My first approach included multi booting (grub + linux + windows). But from around 1 year my Linux system is independent (standard grub + garuda). In case when want to select windows system then I turn on windows ssd and turn off garuda ssd (I’m able to achieve it because on my pc front panel has manual switches). So let’s assume I just don’t have a multibooting ![]()
You do you ![]()
Here’s an old post of mine explaining how to change the uid/gid to 1000:
Thank you tgb, I'm going to change it, but here comes a questions:
-why on fresh install from newest iso those values are inccorrect while I didn't mess with them?
-do I need stil remove guest account? If yes , then why it's installing by default from installer?
I personally would remove the guest account and install it after you get your system straightened out if you really want it. It is installed by default in case you let others use your computer then they can’t snoop at your stuff. It is for extra security.
Just a complete guess, but I’d speculate it has something to do with Ubuntu being installed on your system.
Are you sharing directories or partitions with Ubuntu? Perhaps the installer detected there was already a user 1000 on the system, and therefore allocated the new user 1001.
Not at all. That’re 2 different machines. The only way they has could connect was either thru sshd or vnc. I wouln’d blame Ubuntu here while it has nothing common here. Faster KDE Connect where my phone is named “zawier” as well. But KDE Connect was set up after I have checked IDs. So the same story like with Ubuntu.
Just curious, what is gid 1000 being used for?
Sorry to post a screenshot of the command; Discourse is giving me a 403 error if I type out the path. ![]()
group between ~~~ seems the guilty. ![]()
cat /etc/grou | grep 1000
I bet it's the web application firewall interfering ![]()
If you do a Whoogle search for "403 site:meta.discourse.org" you will get a ton of hits for discussions about why this happens or how to get around it. Certain words or word combinations appear to trigger 403 for some people but not others, or some forums and not others. I don't understand specifically what triggers it.
In a lot of cases it appears this happens on purpose (precautionary measures against malicious behavior perhaps), but in our example here with /etc/group it just seems strange and unhelpful.
The values are not incorrect, or wrong. It’s only a cosmetic thing, not practical problem. It’s an Admin related issue and you can learn more about it in relevant wiki and man pages.
The only issue you probably have (or had) is permissions to your $HOME folder, especially (if not just only) ~/.Xauthority permissions. This happens when you login your account with sudo from TTY. I don’t know what is exactly your case, but it looks similar.
So, I suggest you read about permissions and how to not break your user account, just for prevention
Ok, then I have to ask one more time - why on newest iso during installation you won’t change it while it’s easy?
Why system allows for a such situation on fresh instance? I have done this time nothing wrong. Just followed by installer…
What do you mean? Yep, in past I’ve logged into TTY but don’t understand here sudo option. You mean for executing commands after login, right?
Tried to follow and here what comes:
╭─zawier@zawier in ~
╰─λ sudo pacman -R systemd-guest-user
[sudo] password for zawier:
error: target not found: systemd-guest-user
In TTY tried as well:
usermod -u 1000 user
groupmod -g 1000 user
In my case output as root in TTY is the same as regular console :
╭─zawier@zawier in ~ as 🧙 took 4s
[🔴] × usermod -u 1000 zawier
usermod: no changes
╭─zawier@zawier in ~ as 🧙 took 2ms
╰─λ groupmod -g 1000 zawier
groupmod: GID '1000' already exists
I have 5 DE Garuda Linux systems here on different hardware installed and I do updates several times a day, not all have the guest user installed but none have your problems.
I have now started a live ISO and the guest user is not enabled by default, id also fits.
SGS I truly believe you
You don't have to prove it.
My installer also has proper values:
However something changed my values into:
╰─λ id
My current ixin:
╰─λ garuda-inxi
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=a4e38db2-4f05-4c75-b466-24ea6c7771c6 rw rootflags=subvol=@
resume=UUID=87deb984-f5c7-4128-bda8-ec44cdaa4809 loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Gigabyte model: P55-US3L serial: <superuser required>
BIOS: Award v: FE date: 03/05/2010
Info: model: Intel Core i5 750 bits: 64 type: MCP arch: Nehalem gen: core 1
built: 2008-10 process: Intel 45nm family: 6 model-id: 0x1E (30)
stepping: 5 microcode: 0xA
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2812 high: 2846 min/max: 1197/2661 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2798 2: 2846
3: 2837 4: 2768 bogomips: 21318
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
STIBP: disabled, RSB filling
Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730] vendor: Gigabyte
driver: radeon v: kernel alternate: amdgpu arch: TeraScale 2
process: TSMC 32-40nm built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DVI-I-1,VGA-1 bus-ID: 01:00.0
chip-ID: 1002:68d8 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:3 chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
alternate: fbdev,vesa gpu: radeon display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: AOC 2757M serial: <filter>
built: 2012 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
OpenGL:
renderer: AMD REDWOOD (DRM 2.50.0 / 5.18.9-zen1-1-zen LLVM 14.0.6)
v: 3.3 Mesa 22.1.3 compat-v: 3.1 direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 1-1.2:3 chip-ID: 046d:0843
bus-ID: 00:1b.0 class-ID: 0102 chip-ID: 8086:3b56 class-ID: 0403
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series] vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 1002:aa60 class-ID: 0403
Device-3: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus-ID: 06:04.0 chip-ID: 1102:0007
class-ID: 0401
Device-4: Philips s SAA7131/SAA7133/SAA7135 Video Broadcast Decoder
vendor: Avermedia DVB-T Super 007 driver: saa7134 v: 0, 2, 17
bus-ID: 06:05.0 chip-ID: 1131:7133 class-ID: 0480
Device-5: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: ee00 bus-ID: 02:00.0
chip-ID: 10ec:818b class-ID: 0280
lanes: 1 port: ce00 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.37 TiB used: 39.59 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSDPR-CX400-01T-G2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 61.5 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: GOODRAM model: N/A size: 447.13 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 01.7 scheme: MBR
ID-1: / raw-size: 434.28 GiB size: 434.28 GiB (100.00%)
used: 32.41 GiB (7.5%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 434.28 GiB size: 434.28 GiB (100.00%)
ID-3: /var/log raw-size: 434.28 GiB size: 434.28 GiB (100.00%)
ID-4: /var/tmp raw-size: 434.28 GiB size: 434.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.68 GiB used: 1.5 MiB (0.0%)
ID-2: swap-2 type: partition size: 12.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 57.0 C mobo: N/A gpu: radeon temp: 57.5 C
Processes: 243 Uptime: 1h 15m wakeups: 0 Memory: 11.68 GiB
used: 3.4 GiB (29.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1775
lib: 515 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-07-01
Last full system update: 2022-07-06
My fish hisotry so far:
- cmd: hostnamectl
when: 1656707470
- cmd: sudo hostnamectl set-hostname zawier-garuda
when: 1656707518
- cmd: sudo nano /etc/hosts
when: 1656707548
paths:
- /etc/hosts
- cmd: pacman -Ss chrome
when: 1656707892
- cmd: sudo pacman -S chaotic-aur/google-chrome
when: 1656707953
- cmd: kate
when: 1656707998
- cmd: lsusb
when: 1656708613
- cmd: pacman -Ss remmina
when: 1657004198
- cmd: sudo pacman -S community/remmina
when: 1657004239
- cmd: sudo pacman -S remmina-plugin-rdesktop
when: 1657004772
- cmd: sudo pacman -Ss remmina-plugin-rdesktop
when: 1657004782
- cmd: sudo pacman -Ss freerdp
when: 1657004979
- cmd: sudo pacman -S community/freerdp
when: 1657005075
- cmd: pacman -S signal
when: 1657008218
- cmd: pacman -Ss signal
when: 1657008224
- cmd: sudo pacman - S community/signal-desktop
when: 1657008265
- cmd: sudo pacman -S community/signal-desktop
when: 1657008279
- cmd: pacman -Ss onlyoffice
when: 1657008418
- cmd: sudo pacman -S chaotic-aur/onlyoffice-bin
when: 1657008472
- cmd: pacman -Ss ksnip
when: 1657016783
- cmd: sudo pacman -S community/ksnip
when: 1657016816
- cmd: git clone https://gitlab.com/bztsrc/usbimager.git
when: 1657031120
- cmd: cd src/
when: 1657031203
paths:
- src/
- cmd: make
when: 1657031216
- cmd: make install
when: 1657031239
- cmd: ./make install
when: 1657031266
- cmd: sudo make install
when: 1657031275
- cmd: usbimager
when: 1657031308
- cmd: find $HOME ! -user $USER -type f
when: 1657031445
paths:
- $HOME
- cmd: cat /etc/passwd -
when: 1657031526
paths:
- /etc/passwd
- cmd: sudo pacman -Sy
when: 1657057741
- cmd: garuda-update
when: 1657057758
- cmd: sudo btrfs subvolume list
when: 1657058271
- cmd: sudo btrfs subvolume list /
when: 1657058278
paths:
- cmd: sudo pacman -S htop
when: 1657058978
- cmd: pacman -Ss snap
when: 1657059460
- cmd: pacman -Ss snapd
when: 1657059551
- cmd: cd /run/media/zawier/Dokumenty_BCK/Pobrane/
when: 1657059614
paths:
- /run/media/zawier/Dokumenty_BCK/Pobrane/
- cmd: git clone https://aur.archlinux.org/snapd.git
when: 1657059640
- cmd: cd snapd
when: 1657059659
paths:
- snapd
- cmd: makepkg -si
when: 1657059674
- cmd: snap --version
when: 1657059947
- cmd: snapd --version
when: 1657059995
- cmd: systemctl status snap
when: 1657060012
- cmd: sudo systemctl enable --now snapd.socket
when: 1657060043
- cmd: sudo systemctl start snapd.socket
when: 1657060079
- cmd: sudo ln -s /var/lib/snapd/snap /snap
when: 1657060128
paths:
- /var/lib/snapd/snap
- cmd: sudo snap install snap-store
when: 1657060364
- cmd: systemctl status snapd
when: 1657060424
- cmd: snap install TrackMania Nations Forever
when: 1657060895
- cmd: snap find trackmania
when: 1657060920
- cmd: snap install tmnationsforever
when: 1657060987
- cmd: sudo snap install tmnationsforever
when: 1657060993
paths:
- snap
- cmd: cut -d: -f1 /etc/passwd
when: 1657120837
paths:
- /etc/passwd
- cmd: getent passwd
when: 1657120883
- cmd: usermod -u 1000 zawier
when: 1657120919
- cmd: groupmod -g 1000 zawier
when: 1657120936
- cmd: id
when: 1657120943
- cmd: sudo pacman -R systemd-guest-user
when: 1657121371
when: 1657121550
when: 1657121554
- cmd: id
when: 1657137070
- cmd: garuda-inxi
when: 1657137109
As you see I have done nothing what could posible change IDs.
I don't trust any statistic that I haven't faked myself
But I don't have a reason to lie..
I just asking for help and that's why sending real data.
