Hello,
i am currently using garuda gnome edition.
after this update
:: Replace kauth with extra/kauth5? [Y/n] Y
:: Replace kconfig with extra/kconfig5? [Y/n] Y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] Y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] Y
:: Replace knotifications with extra/knotifications5? [Y/n] Y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] Y
resolving dependencies...
Packages (12) kauth-5.105.0-1 [removal] kauth5-5.110.0-1 kconfig-5.105.0-1 [removal] kconfig5-5.110.0-1
kcoreaddons-5.105.0-1 [removal] kcoreaddons5-5.110.0-1 kitemmodels-5.105.0-1 [removal] kitemmodels5-5.110.0-1
knotifications-5.105.0-1 [removal] knotifications5-5.110.0-1 kwindowsystem-5.105.0-1 [removal]
kwindowsystem5-5.110.0-1
Total Installed Size: 10.99 MiB
Net Upgrade Size: -0.38 MiB
i can’t play videos and audio files.
system details
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=62211d77-6391-48ef-8d2c-fcd39f55c4f7 rw rootflags=subvol=@ quiet quiet
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1 Distro: Garuda Linux
Type: Laptop System: Dell product: Vostro 3491 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: Dell model: 073DJG v: A00 serial: <superuser required> UEFI: Dell v: 1.26.0
date: 03/13/2023
ID-1: BAT0 charge: 27.7 Wh (100.0%) condition: 27.7/42.0 Wh (65.9%) volts: 12.6 min: 11.4
model: BYD DELL 1VX1H06 type: Li-poly serial: <filter> status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake gen: core 10 level: v4
note: check built: 2019-21 process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
microcode: 0xBC
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 160 KiB
desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2239 high: 3400 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 2759 2: 3400 3: 1957 4: 840 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel arch: Gen-11
process: Intel 10nm built: 2019-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-6:6 chip-ID: 0c45:671e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1 compositor: gnome-shell driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99") s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0xb68d built: 2019 res: 1366x768 hz: 60 dpi: 112
gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel UHD Graphics (ICL
GT1) driver: mesa intel v: 23.2.1-arch1.1 device-ID: 8086:8a56 surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.1 (LLVM
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-10:7 chip-ID: 0cf3:e009 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 4.2 lmp-v: 8 status: discoverable: no
pairing: no
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060
bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 945.99 GiB used: 28.87 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
fw-rev: SDM3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: Mass Storage Device size: 14.48 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
serial: <filter> scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 28.87 GiB (3.1%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 28.87 GiB (3.1%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 28.87 GiB (3.1%) fs: btrfs
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 28.87 GiB (3.1%) fs: btrfs
ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 70.0 C mobo: 51.0 C
Fan Speeds (rpm): cpu: 3367
Processes: 227 Uptime: 24m wakeups: 46862 Memory: total: 16 GiB note: est. available: 15.4 GiB
used: 2.65 GiB (17.2%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1141 libs: 374 tools: pamac,paru Client: shell wrapper
v: 5.1.16-release inxi: 3.3.30
System install date: 2023-10-02
Last full system update: 2023-10-03
Help me.
