My inxi copy/pasted from last week:
Kernel: 5.16.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6cafe1ae-53e0-4003-8e56-0566259c4051
rw rootflags=subvol=@ loglevel=3 quiet
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: All Series v: N/A serial: <superuser required>
Mobo: ASUSTeK model: H97M-E v: Rev X.0x serial: <superuser required> UEFI: American Megatrends
v: 2702 date: 03/28/2016
Info: model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x28
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3468 high: 3493 min/max: 800/3900 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3493 2: 3492 3: 3493 4: 3396 bogomips: 27937
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Device-2: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2
chip-ID: 046d:082c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.6x9.3") s-diag: 484mm (19.1")
Monitor-1: HDMI2 res: 1600x900 hz: 60 dpi: 58 size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.3.5 compat-v: 3.0
direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:8ca0 class-ID: 0403
Device-3: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:2
Sound Server-1: ALSA v: k5.16.7-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK AM1I-A
driver: r8169 v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Ralink RT5572 Wireless Adapter type: USB driver: rt2800usb bus-ID: 3-10:5
chip-ID: 148f:5572 class-ID: 0000 serial: <filter>
IF: wlp0s20u10 state: up mac: <filter>
Local Storage: total: 4.55 TiB used: 1.82 TiB (40.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5000AACS-00ZUB0 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1B01
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD40EFRX-68WT0N0 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A82 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD5000LPVX-80V0TT0
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 1A01 scheme: GPT
ID-1: / raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.82 TiB (44.4%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.82 TiB (44.4%) fs: btrfs
ID-4: /var/log raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.82 TiB (44.4%) fs: btrfs
ID-5: /var/tmp raw-size: 465.5 GiB size: 4.09 TiB (900.43%) used: 1.82 TiB (44.4%) fs: btrfs
ID-1: swap-1 type: zram size: 15.32 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 29.8 C mobo: 27.8 C
I have been doing daily updates by garuda-update and everything has been running smoothly. After doing my update today things seemed okay until I tried to start a Debian vm in virtualbox. It would not start, then locked up the computer. Upon restart my hdd was making a lot of noise and running constantly, just like it was doing last week when we had this same conversation (see [SOLVED] Btfrs and baloo_file_extractor issue). I have now disabled ALL btfrs utilities in the BTFRS Assistant and disabled baloo by balooctl disable.
I am now typing on my macbook, because my linux box is virtually unusable, due to pauses and locking up.
So...what just happened?
