thanks a lot and sorry for the confusing. (it is all a little owerhelming)
I will open topics for the other issues.
thanks for the advice with fish. the error disappeared alsthough it does not look as beautiful anymore as before:
here is the garuda-inxi file output:
`perl: warning: Setting locale failed.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "nl_BE.UTF-8",
LC_NAME = "zh_CN.UTF-8",
LC_MONETARY = "en_BE.UTF-8",
LC_PAPER = "zh_CN.UTF-8",
LC_IDENTIFICATION = "zh_CN.UTF-8",
LC_TELEPHONE = "zh_CN.UTF-8",
LC_MEASUREMENT = "en_BE.UTF-8",
LC_TIME = "en_BE.UTF-8",
LC_NUMERIC = "zh_CN.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ccaaa6c4-1b6e-42b0-b7c4-6dd84c11fd62 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Convertible System: LENOVO product: 82QF v: Yoga 14c ARB7
serial: <superuser required> Chassis: type: 31 v: Yoga 14c ARB7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN
serial: <superuser required> part-nu: LENOVO_MT_82QF_BU_idea_FM_Yoga 14c
ARB7 uuid: <superuser required> UEFI: LENOVO v: K5CN40WW date: 04/17/2023
ID-1: BAT0 charge: 53.9 Wh (75.2%) condition: 71.7/71.0 Wh (101.0%)
power: 9.7 W volts: 16.1 min: 15.4 model: LGES L21L4PE0 type: Li-poly
serial: <filter> status: discharging cycles: 70
Info: model: AMD Ryzen 7 6800U with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 714 high: 2379 min/max: 400/4768 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 2379
4: 400 5: 400 6: 400 7: 400 8: 1337 9: 1541 10: 400 11: 1375 12: 400
13: 400 14: 400 15: 400 16: 400 bogomips: 86242
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1 bus-ID: 33:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 41.0 C
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b758
Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
s-diag: 698mm (27.48")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xa195 built: 2020
res: 2240x1400 hz: 60 dpi: 190 gamma: 1.2 size: 300x188mm (11.81x7.4")
diag: 354mm (13.9") ratio: 16:10 modes: max: 2240x1400 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.7-arch1.3
rembrandt LLVM 17.0.6 DRM 3.57 6.9.1-zen1-1-zen) device-ID: 1002:1681
memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 33:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 33:00.5
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 33:00.6
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:2 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Device-2: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 045e:0745 class-ID: 0300
Local Storage: total: 953.87 GiB used: 126.16 GiB (13.2%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 33.9 C scheme: GPT
ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 43.27 GiB (17.3%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:5
used: 94.4 MiB (31.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 201.61 GiB size: 201.61 GiB (100.00%)
used: 82.8 GiB (41.1%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:6
ID-4: /var/log raw-size: 250 GiB size: 250 GiB (100.00%)
used: 43.27 GiB (17.3%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:5
ID-5: /var/tmp raw-size: 250 GiB size: 250 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.34 GiB used: 1.07 GiB (8.0%)
System Temperatures: cpu: 43.8 C mobo: 42.0 C gpu: amdgpu temp: 41.0 C
Memory: total: 16 GiB note: est. available: 13.34 GiB used: 5.15 GiB (38.6%)
Processes: 398 Power: uptime: 37m states: freeze,mem,disk suspend: s2idle
image: 5.31 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 2301 pm: pacman pkgs: 2275 libs: 607 tools: gnome-software,
octopi, pamac, paru, yay pm: flatpak pkgs: 26 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2023-12-24
Last full system update: 2024-05-20 ↻
Failed units:`
