After rebooting, I'm stuck to a logging screen loop
Hello there,
I'll appreciate some guidance here, for a new logging issue I have:
After rebooting, I'm stuck to a logging screen loop.
The only way to enter my Hyprland session, is to log from the TTY and start Hyprland.
Any advices on the way to fix this?
BTW, thank for your Garuda/Hyprland ISO, It's a great combo.
Please, post your garuda-inxi.
Please read
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Ooops!
                   .%;888:8898898:                jlt@jlt
                 x;XxXB%89b8:b8%b88:              -------
              .8Xxd                8X:.           OS: Garuda Linux x86_64
            .8Xx;                    8x:.         Host: X570 DARK
          .tt8x          .d            x88;       Kernel: 6.4.10-zen2-1-zen
       .@8x8;          .db:              xx@;     Uptime: 9 mins
     ,tSXXΒ°          .bbbbbbbbbbbbbbbbbbbB8x@;    Packages: 1456 (pacman)[stable]
   .SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;    Shell: fish 3.6.1
 ,888S                                     pd!    Display: 3440x1440
8X88/                                       q     Display: 1920x1200
8X88/                                             WM: Hyprland (Wayland)
GBB.                                              Theme: Sweet-Dark [GTK2/3/4]{?3} {3} [Plasma], {?}{7}
 x%88        d888@8@X@X@X88X@@XX@@X@8@X.          Icons: BeautyLine [GTK2/3/4]
   dxXd    dB8b8b8B8B08bB88b998888b88x.           Terminal: alacritty 0.12.2
    dxx8o                      .@@;.              Terminal Font: FiraCode Nerd Font Mono 12.0
      dx88                   .t@x.                CPU: AMD Ryzen 9 5950X (32) @ 5.083398 GHz
        d:SS@8ba89aa67a853Sxxad.                  GPU: NVIDIA GeForce GTX 980 Ti
          .d988999889889899dd.                    Memory: 1.93 GiB / 31.27 GiB
                                                  β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ
 ╭─jlt@jlt in ~
 ╰─λ garuda-inxi
  Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=d5b403e4-a649-4498-adf1-47da2f467742 rw rootflags=subvol=@
  Desktop: Hyprland info: waybar vt: 3 dm: SDDM Distro: Garuda Linux
  Type: Desktop System: EVGA product: X570 DARK v: N/A
  Mobo: EVGA model: X570 DARK v: 1.2.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: 1.09 date: 12/27/2022
  ID-1: hidpp_battery_0 charge: 94% condition: N/A volts: 4.1 min: N/A
    model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: full
  Device-1: hidpp_battery_1 model: Logitech MX Keys for Mac serial: <filter>
    charge: 100% (should be ignored) rechargeable: yes status: full
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3406 high: 3600 min/max: 2200/5083 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
    3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3600
    12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400
    20: 3400 21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400
    28: 3400 29: 3400 30: 3400 31: 3400 32: 3400 bogomips: 217612
  Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: ASUSTeK driver: nouveau
    v: kernel non-free: 535.xx+ status: current (as of 2023-08) arch: Maxwell
    code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-3,HDMI-A-1
    empty: DP-1,DP-2,DVI-I-1 bus-ID: 0b:00.0 chip-ID: 10de:17c8 class-ID: 0300
    temp: 57.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: Hyprland driver: X: loaded: nouveau unloaded: modesetting
    alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau d-rect: 5360x1440
    display-ID: 1
  Monitor-1: DP-3 pos: right model: Acer XR341CK serial: <filter>
    built: 2015 res: 3440x1440 hz: 75 dpi: 107 gamma: 1.2 scale: 1
    size: 819x363mm (32.24x14.29") diag: 896mm (35.3") modes: max: 3440x1440
    min: 640x480
  Monitor-2: HDMI-A-1 pos: primary,left model: Dell U2412M serial: <filter>
    built: 2013 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2 scale: 1
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
    max: 1920x1200 min: 720x400
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  Device-1: NVIDIA GM200 High Definition Audio vendor: ASUSTeK
    link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1 chip-ID: 10de:0fb0
  Device-2: AMD Starship/Matisse HD Audio vendor: eVga.com.
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: ASUSTek ASUS Xonar Essence One
    lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0b05:17a8 class-ID: 0300
  API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
  IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-3: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
  IF-ID-1: eno1 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 8087:0029
  Local Storage: total: 3.18 TiB used: 21.39 GiB (0.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Seagate
    model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 614900WD temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 33.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
    used: 21.39 GiB (4.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
  System Temperatures: cpu: 42.1 C mobo: N/A gpu: nouveau temp: 56.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 0
  Processes: 715 Uptime: 9m wakeups: 4 Memory: total: 32 GiB
  available: 31.27 GiB used: 2.37 GiB (7.6%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1456 libs: 371 tools: pamac,paru,yay Shell: fish
  v: 3.6.1 running-in: alacritty inxi: 3.3.29
  System install date:     2023-08-18
  Last full system update: 2023-08-18
  Failed units:            fancontrol.service
You can’t type in the text field for the password, or after typing you got again the log in window?
Did you check in .config/hypr/hyprland.conf, if the
kb_layout = ??
fit to your language?
The login screen seem to work normaly.
I type my password, clic validate, but return to the log window after a few seconds of screen flashing\weirdness.
kb_layout = us
kb_model = logitech-mx-keys-mac
follow_mouse = 1
exec-once = hyprctl setcursor Sweet-cursors 28
sensitivity = 0
numlock_by_default = true
My language was set to: en_ca and add no login issue.
I remove it and only let US.
It change nothing :frowning:
I'm playing with Hyprland for about 4 weeks now.
I realy love it. It's slim, fast, fun to configure and surprisingly stable for a beta software, but I add to reinstall it many time,because of that login issue.
It's always the same: It's start great, no issue to log in, I configure it, play with it and suddently after a logout or a reboot, bam!, I'm not able to log in anymore? It append to me with Garuda, but also with pure Arch install.
Here is my journal of error, there is a lot of error, maybe it can help. It's quite criptic to me:
Thank's a lot for your help
Aug 18 01:02:29 jlt kernel: amd_gpio AMDI0030:00: Invalid config param 0014
Aug 18 01:02:29 jlt systemd-vconsole-setup[337]: /usr/bin/setfont failed with exit status 71.
Aug 18 01:02:29 jlt systemd-vconsole-setup[560]: /usr/bin/setfont failed with exit status 71.
Aug 18 01:02:30 jlt kernel: hid-generic 0003:0B05:17A8.0001: No inputs registered, leaving
Aug 18 01:02:30 jlt systemd-vconsole-setup[802]: /usr/bin/setfont failed with exit status 71.
Aug 18 01:02:30 jlt kernel: MXM: GUID detected in BIOS
Aug 18 01:02:30 jlt kernel: nouveau 0000:0b:00.0: bus: MMIO write of 80000122 FAULT at 10eb14 [ PRIVRING ]
Aug 18 01:02:33 jlt kernel: irq 137 handler nvkm_intr+0x0/0x240 [nouveau] enabled interrupts
Aug 18 01:02:33 jlt kernel: Modules linked in: qrtr cmac algif_hash algif_skcipher af_alg bnep vfat fat hid_logitech_hidpp joydev mousedev iwlmvm mac80211 libarc4 btusb btrtl iwlwifi btbcm btintel btmtk cfg80211 bluetooth ecdh_generic snd_usb_audio snd_usbmidi_lib snd_rawmidi snd_seq_device mc ch341 igc crc16 rfkill hid_logitech_dj snd_hda_codec_realtek nouveau snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi intel_rapl_msr intel_rapl_common snd_hda_intel snd_intel_dspcfg edac_mce_amd snd_intel_sdw_acpi snd_hda_codec i2c_algo_bit kvm_amd drm_ttm_helper ttm snd_hda_core kvm snd_hwdep drm_display_helper snd_pcm snd_timer usbhid cec irqbypass snd rapl mxm_wmi wmi_bmof video k10temp soundcore acpi_cpufreq i2c_piix4 mac_hid fuse dm_mod loop zram ip_tables x_tables crct10dif_pclmul nvme crc32_pclmul polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel sha512_ssse3 aesni_intel crypto_simd nvme_core ccp cryptd xhci_pci sp5100_tco xhci_pci_renesas nvme_common wmi btrfs blake2b_generic libcrc32c crc32c_generic crc32c_intel xor
Aug 18 01:02:33 jlt kernel:  raid6_pq uinput crypto_user
Aug 18 01:02:33 jlt kernel: CPU: 9 PID: 0 Comm: swapper/9 Not tainted 6.4.10-zen2-1-zen #1 e8b2b837ec1c2defdc2433867b8f88ff2562c2cf
Aug 18 01:02:33 jlt kernel: Hardware name: EVGA Corp. X570 DARK/X570 DARK, BIOS 1.09 12/27/2022
Aug 18 01:02:33 jlt kernel: RIP: 0010:__handle_irq_event_percpu+0x1be/0x1d0
Aug 18 01:02:33 jlt kernel: Code: e4 5b 5d 44 89 e0 41 5c 41 5d 41 5e e9 6b fb e4 00 48 8b 13 44 89 ee 48 c7 c7 80 e0 a2 87 c6 05 bd da 04 02 01 e8 62 6f f4 ff <0f> 0b eb a0 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 90 90 90 90
Aug 18 01:02:33 jlt kernel: RSP: 0018:ffffb0f300450f60 EFLAGS: 00010282
Aug 18 01:02:33 jlt kernel: RAX: 0000000000000000 RBX: ffff96f08267dc00 RCX: 0000000000000000
Aug 18 01:02:33 jlt kernel: RDX: ffff96f79ec6e3c0 RSI: ffff96f79ec616c0 RDI: 0000000000000300
Aug 18 01:02:33 jlt kernel: RBP: 0000000000000001 R08: 0000000000000001 R09: 00000000ffffffea
Aug 18 01:02:33 jlt kernel: R10: ffff96f79e950000 R11: ffff96f7bf279240 R12: 0000000000000000
Aug 18 01:02:33 jlt kernel: R13: 0000000000000089 R14: ffff96f087215000 R15: 0000000000000000
Aug 18 01:02:33 jlt kernel: FS:  0000000000000000(0000) GS:ffff96f79ec40000(0000) knlGS:0000000000000000
Aug 18 01:02:33 jlt kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 18 01:02:33 jlt kernel: CR2: 00007f212109f010 CR3: 0000000138548000 CR4: 0000000000750ee0
Aug 18 01:02:33 jlt kernel: PKRU: 55555554
Aug 18 01:02:33 jlt kernel: Call Trace:
Aug 18 01:02:33 jlt kernel:  <IRQ>
Aug 18 01:02:33 jlt kernel:  ? __warn+0x81/0x1b0
Aug 18 01:02:33 jlt kernel:  ? __handle_irq_event_percpu+0x1be/0x1d0
Aug 18 01:02:33 jlt kernel:  ? report_bug+0x202/0x270
Aug 18 01:02:33 jlt kernel:  ? native_apic_mem_read+0xc/0x20
Aug 18 01:02:33 jlt kernel:  ? handle_bug+0x3c/0x80
Aug 18 01:02:33 jlt kernel:  ? exc_invalid_op+0x19/0xc0
Aug 18 01:02:33 jlt kernel:  ? asm_exc_invalid_op+0x1a/0x20
Aug 18 01:02:33 jlt kernel:  handle_irq_event+0x3b/0x80
Aug 18 01:02:33 jlt kernel:  handle_edge_irq+0x9a/0x260
Aug 18 01:02:33 jlt kernel:  __common_interrupt+0x46/0xc0
Aug 18 01:02:33 jlt kernel:  common_interrupt+0x81/0xa0
Aug 18 01:02:33 jlt kernel:  </IRQ>
Aug 18 01:02:33 jlt kernel:  <TASK>
Aug 18 01:02:33 jlt kernel:  asm_common_interrupt+0
x26/0x40
Aug 18 01:02:33 jlt kernel: RIP: 0010:cpuidle_enter_state+0xcc/0x830
Aug 18 01:02:33 jlt kernel: Code: ba 7e 1a ff e8 05 f2 ff ff 8b 53 04 49 89 c6 0f 1f 44 00 00 31 ff e8 f3 4b 19 ff 45 84 ff 0f 85 c4 02 00 00 fb 0f 1f 44 00 00 <45> 85 ed 0f 88 9e 02 00 00 49 63 f5 4c 89 f2 48 8d 04 76 48 8d 04
Aug 18 01:02:33 jlt kernel: RSP: 0018:ffffb0f3001c7e90 EFLAGS: 00000246
Aug 18 01:02:33 jlt kernel: RAX: ffff96f79ec73f00 RBX: ffff96f08733a000 RCX: 0000000000000000
Aug 18 01:02:33 jlt kernel: RDX: 0000000000000009 RSI: fffffffb8e46d54b RDI: 0000000000000000
Aug 18 01:02:33 jlt kernel: RBP: 0000000000000002 R08: 0000000000000002 R09: 0000000025a5a65f
Aug 18 01:02:33 jlt kernel: R10: 0000000000000129 R11: 0000000000000008 R12: ffffffff8834b760
Aug 18 01:02:33 jlt kernel: R13: 0000000000000002 R14: 0000000145060420 R15: 0000000000000000
Aug 18 01:02:33 jlt kernel:  cpuidle_enter+0x2d/0x40
Aug 18 01:02:33 jlt kernel:  do_idle+0x1d8/0x230
Aug 18 01:02:33 jlt kernel:  cpu_startup_entry+0x1d/0x20
Aug 18 01:02:33 jlt kernel:  start_secondary+0x12b/0x150
Aug 18 01:02:33 jlt kernel:  secondary_startup_64_no_verify+0x10b/0x10b
Aug 18 01:02:33 jlt kernel:  </TASK>
Aug 18 01:02:38 jlt sddm-helper[3296]: gkr-pam: unable to locate daemon control file
Aug 18 01:02:38 jlt systemd[3299]: Failed to start Profile-sync-daemon.
Aug 18 01:02:39 jlt systemd-coredump[3534]: Process 3332 (Hyprland) of user 1000 dumped core.
                                            Stack trace of thread 3332:
                                            #0  0x00007f14c048e83c n/a (libc.so.6 + 0x8e83c)
                                            #1  0x00007f14c043e668 raise (libc.so.6 + 0x3e668)
                                            #2  0x00007f14c04264b8 abort (libc.so.6 + 0x264b8)
                                            #3  0x000055ce6d61b09a _Z25handleUnrecoverableSignali (Hyprland + 0xa209a)
                                            #4  0x00007f14c043e710 n/a (libc.so.6 + 0x3e710)
                                            #5  0x00007f14c048e83c n/a (libc.so.6 + 0x8e83c)
                                            #6  0x00007f14c043e668 raise (libc.so.6 + 0x3e668)
                                            #7  0x00007f14c04264b8 abort (libc.so.6 + 0x264b8)
                                            #8  0x00007f14c04263dc n/a (libc.so.6 + 0x263dc)
                                            #9  0x00007f14c0436d26 __assert_fail (libc.so.6 + 0x36d26)
                                            #10 0x00007f14c103a733 n/a (libwlroots.so.12032 + 0x51733)
                                            #11 0x00007f14c103c820 n/a (libwlroots.so.12032 + 0x53820)
                                            #12 0x00007f14c103cab5 n/a (libwlroots.so.12032 + 0x53ab5)
                                            #13 0x00007f14c10559e1 wlr_output_commit_state (libwlroots.so.12032 + 0x6c9e1)
                                            #14 0x00007f14c1055e6b wlr_output_commit (libwlroots.so.12032 + 0x6ce6b)
                                            #15 0x000055ce6d7564cb _ZN13CHyprRenderer13renderMonitorEP8CMonitor (Hyprland + 0x1dd4cb)
                                            #16 0x000055ce6d6ca3c0 _Z13handleWrappedP11wl_listenerPv (Hyprland + 0x1513c0)
                                            #17 0x00007f14c0fa001e wl_signal_emit_mutable (libwayland-server.so.0 + 0xa01e)
                                            #18 0x00007f14c0fa1a23 wl_event_loop_dispatch_idle (libwayland-server.so.0 + 0xba23)
                                            #19 0x00007f14c0fa1b3d wl_event_loop_dispatch (libwayland-server.so.0 + 0xbb3d)
                                            #20 0x00007f14c0fa22d7 wl_display_run (libwayland-server.so.0 + 0xc2d7)
                                            #21 0x000055ce6d60a5d6 main (Hyprland + 0x915d6)
                                            #22 0x00007f14c0427cd0 n/a (libc.so.6 + 0x27cd0)
                                            #23 0x00007f14c0427d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                            #24 0x000055ce6d61af35 _start (Hyprland + 0xa1f35)
                                            Stack trace of thread 3351:
                                            #0  0x00007f14c04894ae n/a (libc.so.6 + 0x894ae)
                                            #1  0x00007f14c048bd40 pthread_cond_wait (libc.so.6 + 0x8bd40)
                                            #2  0x00007f14bd6c781c n/a (nouveau_dri.so + 0xc781c)
                                            #3  0x00007f14bd71472c n/a (nouveau_dri.so + 0x11472c)
                                            #4  0x00007f14c048c9eb n/a (libc.so.6 + 0x8c9eb)
                                            #5  0x00007f14c051123c n/a (libc.so.6 + 0x11123c)
                                            Stack trace of thread 3352:
                                            Stack trace of thread 3353:
                                            #0  0x00007f14c0512e28 accept4 (libc.so.6 + 0x112e28)
                                            #1  0x000055ce6d6ecbac n/a (Hyprland + 0x173bac)
                                            #2  0x00007f14c08e1943 execute_native_thread_routine (libstdc++.so.6 + 0xe1943)
                                            #3  0x00007f14c048c9eb n/a (libc.so.6 + 0x8c9eb)
                                            #4  0x00007f14c051123c n/a (libc.so.6 + 0x11123c)
                                            ELF object binary architecture: AMD x86-64
Aug 18 01:02:39 jlt systemd[3299]: Failed to start Portal service (Hyprland implementation).
Aug 18 01:02:40 jlt systemd[3299]: Failed to start Portal service (Hyprland implementation).
Aug 18 01:02:41 jlt systemd[3299]: Failed to start Portal service (Hyprland implementation).
Aug 18 01:02:49 jlt sudo[3694]:      jlt : a password is required ; TTY=tty3 ; PWD=/home/jlt ; USER=root ; COMMAND=/usr/bin/true
Aug 18 01:03:17 jlt kded5[6086]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
                                 Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aug 18 01:03:17 jlt systemd-coredump[6089]: Process 6086 (kded5) of user 1000 dumped core.
                                            Stack trace of thread 6086:
                                            #0  0x00007f7c8388e83c n/a (libc.so.6 + 0x8e83c)
                                            #1  0x00007f7c8383e668 raise (libc.so.6 + 0x3e668)
                                            #2  0x00007f7c838264b8 abort (libc.so.6 + 0x264b8)
                                            #3  0x00007f7c840a0098 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa0098)
                                            #4  0x00007f7c8473f3f2 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f3f2)
                                            #5  0x00007f7c8473fa69 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa69)
                                            #6  0x00007f7c8429c195 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29c195)
                                            #7  0x00007f7c8473fb16 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb16)
                                            #8  0x00007f7c85175b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
                                            #9  0x000055b190ce6c7e n/a (kded5 + 0x6c7e)
                                            #10 0x00007f7c83827cd0 n/a (libc.so.6 + 0x27cd0)
                                            #11 0x00007f7c83827d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                            #12 0x000055b190ce70b5 n/a (kded5 + 0x70b5)
                                            Stack trace of thread 6087:
                                            #0  0x00007f7c839039df __poll (libc.so.6 + 0x1039df)
                                            #1  0x00007f7c82d6cc2f n/a (libglib-2.0.so.0 + 0xb7c2f)
                                            #2  0x00007f7c82d0d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x580e2)
                                            #3  0x00007f7c842eb51c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eb51c)
                                            #4  0x00007f7c8429b404 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29b404)
                                            #5  0x00007f7c840f73b6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf73b6)
                                            #6  0x00007f7c84ddca9a n/a (libQt5DBus.so.5 + 0x18a9a)
                                            #7  0x00007f7c840f35da n/a (libQt5Core.so.5 + 0xf35da)
                                            #8  0x00007f7c8388c9eb n/a (libc.so.6 + 0x8c9eb)
                                            #9  0x00007f7c8391123c n/a (libc.so.6 + 0x11123c)
Aug 18 01:03:17 jlt kded5[6101]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Aug 18 01:03:17 jlt systemd-coredump[6110]: Process 6101 (kded5) of user 1000 dumped core.
                                            Stack trace of thread 6101:
                                            #0  0x00007f3e9fc8e83c n/a (libc.so.6 + 0x8e83c)
                                            #1  0x00007f3e9fc3e668 raise (libc.so.6 + 0x3e668)
                                            #2  0x00007f3e9fc264b8 abort (libc.so.6 + 0x264b8)
                                            #3  0x00007f3ea04a0098 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa0098)
                                            #4  0x00007f3ea0b3f3f2 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f3f2)
                                            #5  0x00007f3ea0b3fa69 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa69)
                                            #6  0x00007f3ea069c195 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29c195)
                                            #7  0x00007f3ea0b3fb16 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb16)
                                            #8  0x00007f3ea1575b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
                                            #9  0x000055a70a6cdc7e n/a (kded5 + 0x6c7e)
                                            #10 0x00007f3e9fc27cd0 n/a (libc.so.6 + 0x27cd0)
                                            #11 0x00007f3e9fc27d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                            #12 0x000055a70a6ce0b5 n/a (kded5 + 0x70b5)
                                            Stack trace of thread 6102:
                                            #0  0x00007f3e9fd039df __poll (libc.so.6 + 0x1039df)
                                            #1  0x00007f3e9f16cc2f n/a (libglib-2.0.so.0 + 0xb7c2f)
                                            #2  0x00007f3e9f10d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x580e2)
                                            #3  0x00007f3ea06eb51c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eb51c)
                                            #4  0x00007f3ea069b404 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29b404)
                                            #5  0x00007f3ea04f73b6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf73b6)
                                            #6  0x00007f3ea11faa9a n/a (libQt5DBus.so.5 + 0x18a9a)
                                            #7  0x00007f3ea04f35da n/a (libQt5Core.so.5 + 0xf35da)
                                            #8  0x00007f3e9fc8c9eb n/a (libc.so.6 + 0x8c9eb)
                                            #9  0x00007f3e9fd1123c n/a (libc.so.6 + 0x11123c)
Aug 18 01:04:08 jlt systemd[3299]: Failed to start Portal service.
Aug 18 01:28:19 jlt kded5[73247]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Aug 18 01:28:19 jlt systemd-coredump[73251]: Process 73247 (kded5) of user 1000 dumped core.
                                             Stack trace of thread 73247:
                                             #0  0x00007fd279e8e83c n/a (libc.so.6 + 0x8e83c)
                                             #1  0x00007fd279e3e668 raise (libc.so.6 + 0x3e668)
                                             #2  0x00007fd279e264b8 abort (libc.so.6 + 0x264b8)
                                             #3  0x00007fd27a6a0098 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa0098)
                                             #4  0x00007fd27ad3f3f2 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f3f2)
                                             #5  0x00007fd27ad3fa69 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa69)
                                             #6  0x00007fd27a89c195 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29c195)
                                             #7  0x00007fd27ad3fb16 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb16)
                                             #8  0x00007fd27b775b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
                                             #9  0x000055594c075c7e n/a (kded5 + 0x6c7e)
                                             #10 0x00007fd279e27cd0 n/a (libc.so.6 + 0x27cd0)
                                             #11 0x00007fd279e27d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                             #12 0x000055594c0760b5 n/a (kded5 + 0x70b5)
                                             Stack trace of thread 73248:
                                             #0  0x00007fd279f039df __poll (libc.so.6 + 0x1039df)
                                             #1  0x00007fd27936cc2f n/a (libglib-2.0.so.0 + 0xb7c2f)
                                             #2  0x00007fd27930d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x580e2)
                                             #3  0x00007fd27a8eb51c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eb51c)
                                             #4  0x00007fd27a89b404 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29b404)
                                             #5  0x00007fd27a6f73b6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf73b6)
                                             #6  0x00007fd27b3faa9a n/a (libQt5DBus.so.5 + 0x18a9a)
                                             #7  0x00007fd27a6f35da n/a (libQt5Core.so.5 + 0xf35da)
                                             #8  0x00007fd279e8c9eb n/a (libc.so.6 + 0x8c9eb)
                                             #9  0x00007fd279f1123c n/a (libc.so.6 + 0x11123c)
Aug 18 01:28:19 jlt kded5[73269]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Aug 18 01:28:19 jlt systemd-coredump[73278]: Process 73269 (kded5) of user 1000 dumped core.
                                             Stack trace of thread 73269:
                                             #0  0x00007f680188e83c n/a (libc.so.6 + 0x8e83c)
                                             #1  0x00007f680183e668 raise (libc.so.6 + 0x3e668)
                                             #2  0x00007f68018264b8 abort (libc.so.6 + 0x264b8)
                                             #3  0x00007f68020a0098 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa0098)
                                             #4  0x00007f680273f3f2 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f3f2)
                                             #5  0x00007f680273fa69 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa69)
                                             #6  0x00007f680229c195 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29c195)
                                             #7  0x00007f680273fb16 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb16)
                                             #8  0x00007f6803175b9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
                                             #9  0x0000556634a2ac7e n/a (kded5 + 0x6c7e)
                                             #10 0x00007f6801827cd0 n/a (libc.so.6 + 0x27cd0)
                                             #11 0x00007f6801827d8a __libc_start_main (libc.so.6 + 0x27d8a)
                                             #12 0x0000556634a2b0b5 n/a (kded5 + 0x70b5)
                                             Stack trace of thread 73271:
                                             #0  0x00007f6801bd1828 n/a (libdbus-1.so.3 + 0x22828)
                                             #1  0x00007f6801bd17d5 n/a (libdbus-1.so.3 + 0x227d5)
                                             #2  0x00007f6801bd176b n/a (libdbus-1.so.3 + 0x2276b)
                                             #3  0x00007f6801bd19ed n/a (libdbus-1.so.3 + 0x229ed)
                                             #4  0x00007f6801bd1b35 _dbus_validate_body_with_reason (libdbus-1.so.3 + 0x22b35)
                                             #5  0x00007f6801be9865 n/a (libdbus-1.so.3 + 0x3a865)
                                             #6  0x00007f6801bd4d64 _dbus_message_loader_queue_messages (libdbus-1.so.3 + 0x25d64)
                                             #7  0x00007f6801bdd074 n/a (libdbus-1.so.3 + 0x2e074)
                                             #8  0x00007f6801bdd25d n/a (libdbus-1.so.3 + 0x2e25d)
                                             #9  0x00007f6801bde30f n/a (libdbus-1.so.3 + 0x2f30f)
                                             #10 0x00007f6801bde629 n/a (libdbus-1.so.3 + 0x2f629)
                                             #11 0x00007f6801bc51d7 n/a (libdbus-1.so.3 + 0x161d7)
                                             #12 0x00007f6802e0c7cf n/a (libQt5DBus.so.5 + 0x2a7cf)
                                             #13 0x00007f68022d1637 n/a (libQt5Core.so.5 + 0x2d1637)
                                             #14 0x00007f68022d2e34 _ZN15QSocketNotifier9activatedE17QSocketDescriptorNS_4TypeENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2d2e34)
                                             #15 0x00007f68022d2f78 _ZN15QSocketNotifier5eventEP6QEvent (libQt5Core.so.5 + 0x2d2f78)
                                             #16 0x00007f680229c6dc _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x29c6dc)
                                             #17 0x00007f68022ea276 n/a (libQt5Core.so.5 + 0x2ea276)
                                             #18 0x00007f6800d0fa31 g_main_context_dispatch (libglib-2.0.so.0 + 0x5aa31)
                                             #19 0x00007f6800d6ccc9 n/a (libglib-2.0.so.0 + 0xb7cc9)
                                             #20 0x00007f6800d0d0e2 g_main_context_iteration (libglib-2.0.so.0 + 0x580e2)
                                             #21 0x00007f68022eb51c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eb51c)
                                             #22 0x00007f680229b404 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29b404)
                                             #23 0x00007f68020f73b6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf73b6)
                                             #24 0x00007f6802dfaa9a n/a (libQt5DBus.so.5 + 0x18a9a)
                                             #25 0x00007f68020f35da n/a (libQt5Core.so.5 + 0xf35da)
                                             #26 0x00007f680188c9eb n/a (libc.so.6 + 0x8c9eb)
                                             #27 0x00007f680191123c n/a (libc.so.6 + 0x11123c)
? What you changed?
Can you, for test, change your password to 123 (not num pad)? :slight_smile:
Please post
localectl
and
locale
Just use
kb_layout = us
    kb_variant =
    kb_model =
    kb_options =
    kb_rules =
    follow_mouse = 1
touchpad {
    natural_scroll = true
    tap-to-click = true
    disable_while_typing = true
My language is set to en_US, sorry.
 ╭─jlt@jlt in ~
 ╰─λ localectl
System Locale: LANG=en_US.UTF-8
    VC Keymap: us
   X11 Layout: us
 ╭─jlt@jlt in ~ took 55ms
 ╰─λ locale
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
I've change my Hyprland config as ask: No succes here : :frowning:
I've change my password: Didn't change anything.
Configure it: I had change a lot my Hyprland/Waybar config. The changes were made incremently and test.
I've backup them. When I add to reinstall a system, I simply replace the config with my BackUp. It's working nice till now. no issus with the running of Hyprland.
I will try to revert to the original config and come back to you.
Thank's
I've revert to the original config: SUCCESS!
Now, I have to figure out what I did wrong.
Advices?
Many time thank's for your help
Just do not change :slight_smile: , I think it is
You can change, for testing, only one thing after the other (do not paste the backup), until it break :smiley:
I was able to revert to a 2 days old backup with success, I must have mess something yesterday...
Now, I have to find what I did, that prevent me to login.
At least, I didn't lost all I did...
I had in mind something more dramatic that prevent me to login...
I like a lot Hyprland, it'a a breeze to change config and backup it.
For anyone that might find this useful; Here is everything that you can configure in XKB: List of all setxkbmap configuration options (including models/layout/etc) Β· GitHub
indeed, quite usefull.
Thank you for sharing!
