Hi,
I couldn't find any topic about this, so I'm sorry if I've created this thread and there is one already.
I did a fresh install of garuda sway and after reboot it changed to different layout with blue sway wallpaper and none of the keyboard shortcuts work. I can't launch terminal, just switching between workspaces and resize shortcut work.
I've reinstalled the os three times and even downloaded iso again but I am stuck there...
SGS
2 September 2023 19:04
2
Please post garuda-inxi from terminal, maybe from garuda-assistant.
Did you set the time and locale settings in live ISO before you boot to login page (IDK if there exist one ) or the desktop?
Can you open a terminal and use
localectl
to see your language settings?
I can't open terminal. I've tried Czech language setting and when it happened I did a new fresh install with US language. It doesn't matter.
I could try install it again and post the output after that. But I will do it tomorrow.
Ok, I couldn't resist, so here is output.
System Locale: LANG=en_GB.UTF-8
LC_NUMERIC=cs_CZ.UTF-8
LC_TIME=cs_CZ.UTF-8
LC_MONETARY=cs_CZ.UTF-8
LC_PAPER=cs_CZ.UTF-8
LC_NAME=cs_CZ.UTF-8
LC_ADDRESS=cs_CZ.UTF-8
LC_TELEPHONE=cs_CZ.UTF-8
LC_MEASUREMENT=cs_CZ.UTF-8
LC_IDENTIFICATION=cs_CZ.UTF-8
VC Keymap: cz-lat2
X11 Layout: cz
SGS
2 September 2023 20:55
7
locale
LANG=de_DE.UTF-8
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY=de_DE.UTF-8
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
LC_ALL=
╭─sgs@hypr in ~ as 🧙 took 36ms
╰─λ localectl
System Locale: LANG=de_DE.UTF-8
VC Keymap: de
X11 Layout: de
VC Keymap: cz-lat2
X11 Layout: cz
localectl
LC_TIME=cs_CZ.UTF-8
LC_NAME=cs_CZ.UTF-8
VC Keymap: cz-lat2
X11 Layout: cz
Now, I can do anything, but I am not sure that if reboot, there could be changed everything again like look of the bar and wallpaper. And shortcuts not working...
SGS
2 September 2023 21:06
9
I do not know if there is the problem, can you use cz as keymap?
And what exactly change?
Wallpapers change some time, maybe you saw an old style in web/YT… ?
Edit
Try https://iso.builds.garudalinux.org/iso/garuda/sway/230820/
Saumalek:
Can you post your garuda-inxi
please?
This sounds like an issue with /home
. Do you have an unconventional setup with /home
The default garuda sway look was totally gone. There was just bar with numbers of "activities" on the left side and date on the right. The wallpaper changed to blue screen with title sway in the center plus a tree. And shortcuts were not working.
The only thing I changed was putting /etc/sway/config to ~/.config/sway/config to be able to change settings but I didn't change a thing.
root=UUID=b352b155-5336-430b-acd4-2a15fcf40967 rw rootflags=subvol=@
resume=UUID=61918371-994a-4710-9dca-e49a0ff6c1ee loglevel=3 ibt=off
Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: Dell product: Latitude 7310 v: N/A
Mobo: Dell model: 0KD96W v: A00 serial: <superuser required> UEFI: Dell
v: 1.19.0 date: 09/12/2022
ID-1: BAT0 charge: 5.8 Wh (33.7%) condition: 17.2/51.0 Wh (33.7%) volts: 7.3
min: 7.6 model: BYD DELL HRGYV05 type: Li-poly serial: <filter>
Info: model: Intel Core i7-10610U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2112 high: 2300 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 2300 8: 800 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell Latitude 7310
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5539
Display: wayland server: Xwayland v: 23.2.0 compositor: sway v: 1.8.1
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: LG Display 0x05db built: 2018 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 scale: 1 size: 294x165mm (11.57x6.5")
diag: 337mm (13.3") ratio: 16:9 modes: 1920x1080
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 505.85 GiB used: 10.38 GiB (2.1%)
model: PC SN520 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20240012 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: USB Flash Drive
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
used: 10.38 GiB (2.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-4: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.29 GiB used: 512 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.0 C mobo: 31.0 C
Fan Speeds (rpm): cpu: 0
Processes: 279 Uptime: 1h 22m wakeups: 26066 Memory: total: 16 GiB
note: est. available: 15.29 GiB used: 3 GiB (19.6%) Init: systemd v: 254
pm: pacman pkgs: 1175 libs: 337 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.29
System install date: 2023-09-02
Last full system update: 2023-09-02 ↻
Bingo, this would have overwritten the existing config. Without that, no shortcuts will be set up, no wallpaper (that blue one is the Sway "default), basically everything will be back to stock Sway.
This is a fully configured Sway already, so no need to do that step–~/.config/sway/config
already exists. Instead, edit the config to make the changes you wish.
Thank you very much, my bad.
I've read somewhere on forum that this should be made and was stupidly following that. It was probably outdated or something... Bud I could check if it's ok
Have a nice day
Actually, that is exactly what you should do if you are installing Sway from scratch--for example, if you are setting up an Arch installation. In the case of Garuda Linux, a lot of configuration has already been done.
I'm glad we could help crack the case. Welcome to the community @Saumalek .
system
Closed
4 September 2023 21:43
16
