After every system restart the thunar first start is sloooowww. For checking what is wrong i started it in terminal and i get this error.
thunar
(thunar:2843): Gtk-WARNING **: 19:14:04.112: Attempting to read the recently used resources file at '/home/robi/.local/share/recently-used.xbel', but the parser failed: Failed to open file “/home/robi/.local/share/recently-used.xbel”: Permission denied.
ThunarThumbnailer: Failed to retrieve supported types: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Some idea how can i fix this?
Thank you.
inxi:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=095c9f1d-4e23-42b2-aa42-36402880711e rw rootflags=subvol=@
quiet resume=UUID=4b8a0d61-7df0-445b-9329-0c5cf2f2c346 loglevel=3 ibt=off
Type: Laptop System: Dell product: Vostro 3580 v: N/A
Mobo: Dell model: 0PMTCG v: A00 serial: <superuser required> UEFI: Dell
v: 1.27.0 date: 11/16/2023
ID-1: BAT0 charge: 29.3 Wh (100.0%) condition: 29.3/42.0 Wh (69.8%)
volts: 12.6 min: 11.4 model: BYD DELL 1VX1H97 type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
stepping: 0xC (12) microcode: 0xF8
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 512 high: 700 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 700 3: 700 4: 400
5: 700 6: 400 7: 400 8: 400 bogomips: 28800
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3
chip-ID: 1bcf:2b98 class-ID: 0e02
compositor: Hyprland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 4480x1080
display-ID: 1
Monitor-1: HDMI-A-1 pos: right model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2014 res: 2560x1080 hz: 60 dpi: 112 gamma: 1.2
scale: 1 size: 677x290mm (26.65x11.42") diag: 628mm (24.7") modes:
max: 2560x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x38ed built: 2015
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 scale: 1
modes: 1920x1080
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:3ea0 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
bus-ID: 0000:00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:01:00.0
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:02:00.0
chip-ID: 168c:0042 class-ID: 0280
IF-ID-2: wguk133t state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0cf3:e009
driver: intel_nvme_remap v: N/A port: 4060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.36 TiB used: 20.13 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B tech: SSD serial: <filter> fw-rev: 10410106 temp: 22.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
serial: <filter> fw-rev: 3R17 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM 024 HN-M101M
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 2AR2 scheme: MBR
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 10.5 GiB (17.5%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 162.16 GiB size: 162.16 GiB (100.00%)
used: 9.63 GiB (5.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 10.5 GiB (17.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.01 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 61.0 C pch: 55.0 C mobo: 42.0 C
Fan Speeds (rpm): cpu: 2689
Processes: 289 Uptime: 20m wakeups: 0 Memory: total: 8 GiB
available: 7.63 GiB used: 4.24 GiB (55.6%) Init: systemd v: 255
pm: pacman pkgs: 1455 libs: 421 tools: paru Shell: fish v: 3.7.0
running-in: foot inxi: 3.3.31
Garuda (2.6.23-1):
System install date: 2024-01-21
Last full system update: 2024-02-06
