Hello. I have this problem. Does anyone have similar problems and do you think if this is a hardware-specific trouble?
I am using CoreCtrl setup guide:
When i try to enable this grub boot option: amdgpu.ppfeaturemask=0xffffffff
and reboot i meet with 2 problems:
- CoreCtrl stops autostarting even if it’s enabled in it’s settings.
- I don’t get additional parameters in this app.
When i disable this boot option CoreCtrl ability to autostart remains.
My garuda-inxi:
Kernel: 6.11.7-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=2ac16174-9475-4394-9710-2e9d5d0d7863 rw rootflags=subvol=@
quiet loglevel=3 nowatchdog ibt=off
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: MAIBENBEN product: MaiBook X series v: Standard
Mobo: MAIBENBEN model: X558 v: Standard serial: <superuser required>
part-nu: X558 uuid: <superuser required> UEFI: American Megatrends LLC.
v: N.1.50MBB01 date: 08/20/2022
ID-1: BAT0 charge: 35.3 Wh (100.0%) condition: 35.3/46.7 Wh (75.6%)
volts: 12.5 min: 11.4 model: standard type: Li-ion serial: <filter>
status: full
microcode: 0xA50000C
Speed (MHz): avg: 1100 min/max: 400/4463 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1100 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 102242
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: AIstone Global driver: nvidia v: 565.57.01
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1,eDP-1
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: AIstone Global driver: amdgpu v: kernel
active: eDP-2 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 38.0 C
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 04f2:b711
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Monitor-1: eDP-2 mapped: eDP-1 model: BOE Display 0x090f built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.11.7-arch1-1-znver3) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 565.57.01
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM
Device-1: NVIDIA GA106 High Definition Audio vendor: AIstone Global
vendor: AIstone Global driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: AIstone Global driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
API: ALSA v: k6.11.7-arch1-1-znver3 status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: AIstone Global driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 0e8d:0608
Local Storage: total: 1.4 TiB used: 302.32 GiB (21.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: A-Data model: LEGEND 960
lanes: 4 tech: SSD serial: <filter> fw-rev: A231W74A temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: GPT
ID-1: / raw-size: 199.61 GiB size: 199.61 GiB (100.00%)
used: 23.63 GiB (11.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:9
ID-2: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:10
ID-3: /home raw-size: 632.86 GiB size: 632.86 GiB (100.00%)
used: 278.69 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:8
ID-4: /var/log raw-size: 199.61 GiB size: 199.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 199.61 GiB size: 199.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 20.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:7
System Temperatures: cpu: 49.6 C mobo: 42.0 C gpu: amdgpu temp: 39.0 C
Memory: total: 16 GiB note: est. available: 15.03 GiB used: 4.26 GiB (28.4%)
Processes: 367 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
image: 5.96 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1509 libs: 450 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-11-05
Last full system update: 2024-11-13
